my inrunner build ? go ahead and laugh
Re: my inrunner build ? go ahead and laugh
Postby enoob » Mon Feb 01, 2010 2:52 pm
ok NOT the video i wanted to share but heres where its at .
I had it bolted to the bike and it took me half way around the block then i stripped part of the drive train. bike felt ballsy with more torque than what i used, after breaking it down to rebuild the drive train and try some other stators what you see in the vid is all it will do now. i have tried everything i can think of . i have a data cable and the esc is on the computer desk so if anyone seeing this wants some data let me know . there is no question the esc was having trouble out of the gate, and the data shows it as it logged a peak rpm of 18,000 and 60 amps. i can tell you it never saw that kind of rpm more likely 2000 max.
neither the motor or esc has gotten hot . not on the bike or bench .
data log shows prop strike at the point where it stopped working and failure to start for every attempt after that.
ive torn the motor down and it does look like one of the magnets rotated so im waiting for the epoxy to cure on that one and ill try again, but not for long. the kelly is lined up and primed for a try so that will be getting a solid shot at it today.
M.E.N.S ex pres and charter member.
enoob
Postby amberwolf » Mon Feb 01, 2010 3:17 pm
This is sensorless, right? Because it looks like what happens when sensors aren't working right.
My best guess is that something in the controller popped; if it uses current sensors on each channel perhaps one of them is no longer working. If current sensing is done via voltage across the FETs then one of the FETs (or sets of them) might not be working.
Is it getting signal on all three phase wires?
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby enoob » Mon Feb 01, 2010 3:24 pm
sensorless with the setup in the video yes
ill look at the log right now but otherwise how would i test if its getting signal from all 3 phases ?
and now my noob will really start to show :roll:
enoob
Postby Thud » Mon Feb 01, 2010 10:02 pm
enoob,
BUMMER!
I shake my head every time looking at my data downloads....I have over peaked on every run & been close to thermaling out the lil' Ice100 on a few runs also. I am running 2 extra 1000uf caps (63v) low esr I bought just for the castle controller.
Did you have any extra caps on your input side?
As much as I am impressed with these tiny controllers, I would have to blame myself when one pops in this application. we are really stessing these like this.
I have an e-crazy man on the way & 1 of methods cap & shunt kits to make it do whatever my mood is atm.I may need to buy some better transistors but will cross that bridge when I get there. (I really don't see myself going past 75v) Keep us updated. I assumed we haddn't heard from you because you were out in the wilderness blasting avalanches on the snowmobiles :D
(i hope our F&P's are more to our liking.....if AJ comes thru that is) :twisted:
get some......
Thud
Postby enoob » Tue Feb 02, 2010 3:02 am
:) i may be down but im not out yet. tonight will tell
no extra caps . rather quickly i think ive become unsatisfied with rc controllers for this purpose, if im gonna have to start doin mods that require a soldering iron i think ill look at other options that will let me run the voltage up as well. as for the sledding , not been the best year but i did get a bluebird day in with fresh powder and aint nothing like a day like that. for our friends that dont get snow fresh means what it says, after it falls you only have a limited time before it (depending on weather) sets up or develops a crust. fresh its fluffy and flows nice and you can run off a 10 foot cliff and the landing feels like plopping on the couch.
as for the f&p . i too am thinking alot about that potential and the outlaw in me REALLY wants one in the triangle of a chopper bike. i wont say no to anything from down under but preliminary testing with a brand new unit free from defect or damage may be a good thing, been back to the site you linked to a few times and may just pull the trigger on one of them if this unit wont spin with the kelly. i figure if the hub motors the other dudes are playing with can do 100v 100a that f&p should handle something similar and maybe more amps as we are using gears and keeping the motor closer to its rpm limit.? hopefully?
enoob
Postby Harold in CR » Mon Apr 19, 2010 9:10 pm
Was catching up on some GOOD reading, and found this thread. THEN, it leaves one hanging :roll: :roll: :roll:
Where's the "Rest of the story". :?: :?: :?: :?:
Thanks to Justin, the forum is open source and NON-commercialized.
http://www.costaricacraftwood.com
Harold in CR
Postby enoob » Mon Apr 19, 2010 10:31 pm
) indeed . its what i ask myself when i get another beer and pass the thing sitting on the shelf
It will rise again but for the time being i figured it best to put my effort into actually getting a working ebike under me . the goal is to have a working setup that will allow me to swap this motor into thereby making it the only question mark .
another month and ill be back at this one and the f&p im sitting on.
enoob
Postby Harold in CR » Tue Apr 20, 2010 8:05 am
Good to know it's in a "Resting" mode.
I'm off to Florida soon, for 15 days, and would like to carry anything back that will be useful in my quest for an E-vehicle of some sort. I would love to bring back the Motorcycle swingarm and related parts and the 500 Amp-30V aircraft starter-generator, for the E-3 wheel motorcycle build, when I find time to do IT.
I plan to cut up a few bikes for head posts and crank post sockets. Trying to figure a way to get my metal lathe and Milling machine down here. Got a larger horizontal bandsaw and wire feed Miller welder, sitting, doing nothing. :roll: :roll:
Probably be easier to sell out, here, and move back. :shock: :shock: :roll: :roll: NAAHHHHHHHHHHHHH
Just need the Bride to sell a house. That will free up my income for projects. :) :)
Harold in CR
Postby AussieJester » Sat May 08, 2010 4:18 pm
COOOOOOEEEEEEEEEE....enooobz where are you?
Has anyone been in contact with enoob this past week?
I got word his chopper with the MARS was up and running and he was having a fun on it but then i haven't heard from him for best part of a week, i usually speak with him each day on MSN
getting worried something has happened to him, if anyone is in contact with him by phone can you ring Chad and make sure all is well and report back...?
Cheers
KiM
AussieJester
Postby amberwolf » Sat Oct 09, 2010 4:22 pm
Anybody seen Enoob lately? Kinda worries me that he hasn't been around (hasn't even checked his PMs from what I can tell). I don't have any other way to contact him to find out. :(
amberwolf
Postby AussieJester » Sat Oct 09, 2010 5:17 pm
amberwolf wrote:Anybody seen Enoob lately? Kinda worries me that he hasn't been around (hasn't even checked his PMs from what I can tell). I don't have any other way to contact him to find out. :(
Used to talk to him daily on MSN and receive emails from him regularly, he hasn't logged into MSN in 6 months or sent a single email, gave up sending mails asking if all was well. Last i heared he was having problems with a boarder in an apartment under his own house that cleaned not only the apartment out but his house too. He said he was off to track the guurl down maybe he did something he shouldn't have and is on a 'vacation' at the gubmints expense :-S
KiM
AussieJester
Postby amberwolf » Sun Oct 10, 2010 2:00 am
That's not good. :( I really hope he's ok.
amberwolf
Postby sackspeed » Sun Oct 10, 2010 7:41 am
I catched an interresting article about new car alternators. The Valeo FG 18 is a hybrid (field+magnet) alternator. It seems to be possible to
get it work as motor with high eff. around 85%.
http://eprints2.insa-strasbourg.fr/177/1/Diplomarbeit.pdf
NuVinci + 1200W, Full suspension
sackspeed
Previous
Return to Motor Technology
Who is online
Users browsing this forum: devo1223 and 4 guests
