Thud wrote:9 magnets seem to be a recuring theam in the halbauch array. Are there any other configurations?
If I am interpreting the graphics correctly the 9 will unite to make 1 pole.
rolf_w wrote:it shows: having the magnets embedded in iron prevents the magnetic flux from crossing the airgap - this is where you want it as this is where your current conducting coils are!
AussieJester wrote:You could always go 'ghetto' and get a tub of Devcon and spread this between the magnets would also help hold them in place...
KiM
enoob wrote:or is aluminum ok for this
rhitee05 wrote:So, a square-array is still more efficient, but it doesn't look like a round array is as bad as I thought it'd be without some steel. I'd say it's time for enoob to start making some metal shavings to see what happens in the real world.
paultrafalgar wrote:Don't want to distract you guys from your excellent thread, but take a moment to look at this video where Cedric Lynch (Godhead) explains why he uses rectangular magnets:
paultrafalgar wrote: Cedric Lynch (Godhead) explains why he uses rectangular magnets:
http://www.in.com/videos/watchvideo-ced ... 01603.html
Before you die of laughing at his manner, remember, he makes better electric motors and vehicles than anyone! Enjoy!
Thud wrote:here ya go enoob:
http://cgi.ebay.com/10-Neodymium-Magnet ... 53ddc19ad3
Jonathan in Hiram wrote:Eric,
I recall reading about a motor somewhere that had the poles angled at 45 degrees, supposedly it increased torque, something to do with maximizing the area of the air gap..
Would something like this produce more torque than the first design I showed?
ETA: One advantage I can see is that it can be made thinner than a lot of the other axial flux designs since the width of the iron is only the same as the longest part of the magnet.
That's often the case, but not necessarily so. You'd need to know the thermal rating, to be sure. Strictly, N48 and N42 have the same thermal rating:enoob wrote:may be wrong but i saw that those ones are n48 , while stronger the 42's apparently deal with heat a little better. so i took the bait.
Thud wrote:ENOOB!
I seem to have missed a dimension on the dia. of the ags in that drawing.
They are in fact .5"dia. i will repost a drawing with the 24 poles with 3/8"dia. in a moment.
Thud wrote:please see above edits. I thin i got mm
Miles wrote:That's often the case, but not necessarily so. You'd need to know the thermal rating, to be sure. Strictly, N48 and N42 have the same thermal rating:enoob wrote:may be wrong but i saw that those ones are n48 , while stronger the 42's apparently deal with heat a little better. so i took the bait.
http://www.kjmagnetics.com/specs.asp.
Jonathan in Hiram wrote:I recall reading about a motor somewhere that had the poles angled at 45 degrees, supposedly it increased torque, something to do with maximizing the area of the air gap..
paultrafalgar wrote:Before you die of laughing at his manner, remember, he makes better electric motors and vehicles than anyone! Enjoy!
Users browsing this forum: No registered users and 11 guests
