mdd0127 wrote:When I was messing with my little module on the astro, I got a very similar noise to that and similar high amp readings when I rotated the timing module beyond 15 degrees from where it was running perfectly. Also, when I did this, the direction of the motor reversed. I would try going through your hall/phase combos one more time, just in case, then maybe experiment with moving them back or forward one slot. It's really hard to tell where to put those things sometimes.
mdd0127 wrote:I'm also convinced that the placing the halls anywhere near the stator is just asking for magnetic interference/heat issues. I'll have an external sensor module done for the 12mm shaft motors soon so I can confirm that theory then.
marcexec wrote:mdd0127 wrote:When I was messing with my little module on the astro, I got a very similar noise to that and similar high amp readings when I rotated the timing module beyond 15 degrees from where it was running perfectly. Also, when I did this, the direction of the motor reversed. I would try going through your hall/phase combos one more time, just in case, then maybe experiment with moving them back or forward one slot. It's really hard to tell where to put those things sometimes.
Thanks, I will try that.mdd0127 wrote:I'm also convinced that the placing the halls anywhere near the stator is just asking for magnetic interference/heat issues. I'll have an external sensor module done for the 12mm shaft motors soon so I can confirm that theory then.
We will see about that- I will keep you guys posted.
marcexec wrote:That's cool, thank you. So I'll glue that in now.
To reverse direction (if I need to) I just swap two phases and the according halls, right?
I might go for Burtie's TA later on to optimize.
For now I'll focus on sth else.
gwhy! wrote:marcexec wrote:That's cool, thank you. So I'll glue that in now.
yes, if your halls are 120degrees apart then you only need to swap the phase wires but you will have to swap the hall wires also if they are not 120degrees apart or you can re-adjust the halls to bring it back in to correct timing ( you can also just about get away without swapping the hall wires at 60degree spacing ). As you have glued them in the motor then Im guessing they are 120 apart so you should be fine just swapping 2 of the phase wires.
whereswally606 wrote:Just managed to get a 80/100 working with my 48v golden motor controller. This is my first video upload to the sphere and also to youtube.
The motor is from Leaderhobby and is the EMP not turnigy.
this took me most of the day to cobble together but pretty much struck lucky with the hall wire combinations hit a good combo on the second try.
hope to get it on my norco savage soon, currently looking into double freewheel acs southpaw system.
Users browsing this forum: CNCAddict, Grey beard and 4 guests
