12 kw rc motor
Re: 12 kw rc motor
Postby markobetti » Tue Apr 06, 2010 6:50 am
Tiberius wrote:Marko, Hal,
Nice work.
Do you have the other motor parameters, such as winding resistance and max speed?
I think you said Kv=75, is that still correct?
Nick
kv : 75 is correct , as we are aware
markobetti
Re: 12 kw rc motor
Postby HAL9000v2.0 » Tue Apr 06, 2010 6:53 am
All data I will put by the end of the month. I hope so.
There will be only one version and you can use them at least on 6 different ways. sensorless, sensored, watercooled, naturalcooled, To know how hot it is or to not know. And of coure all combination of this... :)
HAL9000v2.0
Re: 12 kw rc motor
Postby 12p3phPMDC » Tue Apr 06, 2010 9:39 am
That is fanatastic, great work Markobetti and HAL9000!
How is the water cooling done? Is there a tube in the valley of each slot below the windings?
Do the tubes terminate in a header/manifold? or is it one continuous tube?
Thanks for this effort, it's turning into a great motor!
Water cooling will be awesome!
"If you don't follow your dreams, you might as well be a vegetable." Burt Munro
The reasonable man adapts himself to the world;
the unreasonable one persists in trying to adapt the world to himself.
Therefore all progress depends on the unreasonable man.
-- George Bernard Shaw
12p3phPMDC
Re: 12 kw rc motor
Postby cell_man » Tue Apr 06, 2010 10:06 am
These motors are getting better and better. Good work guys 8)
Visit http://www.EM3ev.com/ for our Ebike Kits and in-house battery packs. Online Shipping quotes to most popular destinations, with automated PayPal checkout.
Browse the site or drop us a line via the contact page: http://em3ev.com/store/index.php?route= ... on/contact
cell_man
Re: 12 kw rc motor
Postby liveforphysics » Tue Apr 06, 2010 10:58 am
I'm thinking of getting 9. 8 for me, 1 for KiM. :)
-Luke
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Re: 12 kw rc motor
Postby michaelplogue » Tue Apr 06, 2010 2:27 pm
Would you be willing to make available your 3D model in a common format (such as OBJ)? I'd like to start playing around with mounting options.........
michaelplogue
Re: 12 kw rc motor
Postby 12p3phPMDC » Tue Apr 06, 2010 3:09 pm
Now we need some little high performance magnetically coupled water pumps and little heater cores for radiators!!
I wonder what kind of power you can get from a water cooled astro or HXT?
Somethings aren't worth the complexity, but
What would the limits be...? speed?
12p3phPMDC
Re: 12 kw rc motor
Postby liveforphysics » Tue Apr 06, 2010 4:03 pm
I think the power level should be able to be doubled or more with the water cooling. It depends on how the passages are routed, but this is an exciting time to be doing an EV motorcycle or light car conversion. :)
The fittings for the water cooling, something like -6AN/JIC would be perfect.
With a motor like this, for a bicycle, I think we can forget about needing gearing, slip a pair of broached ENO's over a quality strong rear hub, have a reasonable single stage reduction, like 7:1 perhaps. The sensors enable running real controllers at real voltages. This makes doing serious e-bikes so much more simple, cheaper and so much more potent than they were before this motor.
liveforphysics
Re: 12 kw rc motor
Postby nertog » Tue Apr 06, 2010 4:28 pm
HAL9000v2.0 wrote:
The dimensions will be the same but the shaft exits on other end.
motor is delta but it is no problem to leave all wires outside.
I agree that a fair bit of shaft length on both sides would be very nice. I don't think it adds much to the production costs and it will save some people a lot of trouble.
All wires outside would be great. The more options for us to choose, the better!
Thanks for the efforts! This seems to become a very promising product!!
nertog
10 µW
10 µW
Re: 12 kw rc motor
Postby 12p3phPMDC » Tue Apr 06, 2010 4:32 pm
I agree, -6AN/JIC would be just about perfect, black anodized. Some push lock Aeroquip hose and your golden. No hose clamps!
A little Al radiator with weld on -6AN would be nice along with a little swirl pot and pressure cap....
Double the power would be amazing power density even with the extra complexity.
12p3phPMDC
Re: 12 kw rc motor
Postby HAL9000v2.0 » Wed Apr 07, 2010 3:49 am
Here are .obj and .stp files. Someone please check the files. They work for me but...
I will not revel the cooling system jet. I can only say the it is right under stator plates and it is not pipe and it is not in axle, it is chunk of 6061-T6 alu with 2,5 hours CNC time :)
outrunner.zip
(596.94 KiB) Downloaded 120 times
HAL9000v2.0
Re: 12 kw rc motor
Postby Miles » Wed Apr 07, 2010 4:08 am
Hi Hal,
You saved as a SAT file, not an STP.... :wink:
Anyway, that and the OBJ both opened ok, for me.
Miles
Re: 12 kw rc motor
Postby HAL9000v2.0 » Wed Apr 07, 2010 4:13 am
Here it is...I just rename it :lol:
outrunner_asm.zip
(243 KiB) Downloaded 129 times
HAL9000v2.0
Re: 12 kw rc motor
Postby Miles » Wed Apr 07, 2010 4:13 am
:mrgreen:
Miles
Re: 12 kw rc motor
Postby liveforphysics » Wed Apr 07, 2010 5:04 am
That looks like a hell of a lot of extra work for those poor Chinamen. lol
All those radial passages will need to be tapped and pluged on the outside with grubscrews once the machining is finished as well.
Ton of labor time, machine time, and quite a lot of raw materials to build one of these monsters as well.
If you're really able to hit the $300/unit mark, this thing will be the greatest bargain in LEV motor history.
Thank you Mark and Hal for putting all the needed work and investment in this setup to get us hooked up.
These motors seem to be large enough to operate as a supercharger drive motor, so the sooner I can get a proto-type, the sooner I can get fabing up some brackets and a drive system to make an E-supercharger kit with this thing. :) If I can make something that can perform well and reliable in the real-world, this may mean triple digit order numbers of the motor from me.
liveforphysics
Re: 12 kw rc motor
Postby HAL9000v2.0 » Wed Apr 07, 2010 5:13 am
liveforphysics wrote:These motors seem to be large enough to operate as a supercharger drive motor, so the sooner I can get a proto-type, the sooner I can get fabing up some brackets and a drive system to make an E-supercharger kit with this thing. :) If I can make something that can perform well and reliable in the real-world, this may mean triple digit order numbers of the motor from me.
Now I see what it 8 pcs. for :)
Nice idea. Do you plan to go with reduction or better say multiplication gears? I use to try something similar with low pressure turbo but didn't have such machinery back then so it blows itself quite few times...
Can't wait to see results.
HAL9000v2.0
Re: 12 kw rc motor
Postby liveforphysics » Wed Apr 07, 2010 6:52 am
I've got a screw-type positive displacement internal compression supercharger laying on the floor of the tinkering room. 1.1L/revolution. RPM limit of 19,000rpm.
I figured I would throw an 11t motorcycle #520 chain sprocket on the supercharger input shaft, and a 25-30T #520 sprocket on the supercharger, make a bolt-together bracket setup. I figure I will need the voltage of 2x the safe no-load speed for the motor to not have the BEMF be decreasing the torque as RPM increases, because I need roughly flat torque, with linear power output increasing directly with RPM, so I kinda got fit motor to be running in just the up-hill starting part of the motors power curve.
It's not an easy burden for a motor, but it only needs to be thermally stable for 10-11seconds at a time, so I think it should be fine. :)
liveforphysics
Re: 12 kw rc motor
Postby liveforphysics » Wed Apr 07, 2010 6:53 am
HAL9000v2.0 wrote:Can't wait to see results.
Get a motor in my hands and you won't have to wait as long. :)
liveforphysics
Re: 12 kw rc motor
Postby markobetti » Wed Apr 07, 2010 7:28 am
markobetti
Re: 12 kw rc motor
Postby liveforphysics » Wed Apr 07, 2010 7:38 am
markobetti wrote:something like this : http://images.search.yahoo.com/images/v ... 0%26pstart
Bad link?
liveforphysics
Re: 12 kw rc motor
Postby markobetti » Wed Apr 07, 2010 8:03 am
heheh , not bad link, bad understanding .... sorry .
markobetti
Re: 12 kw rc motor
Postby markobetti » Wed Apr 07, 2010 8:12 am
oh yea it was bad link : http://www.akamoto.co.uk/electric-supercharger.asp this came to my mind ... but still i know it is
not what you were talking about
markobetti
Re: 12 kw rc motor
Postby gogo » Wed Apr 07, 2010 8:28 am
liveforphysics wrote:I've got a screw-type positive displacement internal compression supercharger laying on the floor of the tinkering room. 1.1L/revolution. RPM limit of 19,000rpm.
Like this but better?
http://www.ecycle.com/supercharger.html
gogo
Re: 12 kw rc motor
Postby liveforphysics » Wed Apr 07, 2010 8:34 am
markobetti wrote:oh yea it was bad link : http://www.akamoto.co.uk/electric-supercharger.asp this came to my mind ... but still i know it is
Nope, that electric supercharger is nothing but a gimick.
liveforphysics
Re: 12 kw rc motor
Postby liveforphysics » Wed Apr 07, 2010 8:38 am
I had never seen that one before, but yes, quite a lot like that. :)
Or like this, except not using 3x crap brushed starter motors. lol
liveforphysics
PreviousNext
Return to Motor Technology
Who is online
Users browsing this forum: briangv99 and 5 guests
