You beat me to it
Hopefully I will be able to get back to the shed later this week (Wife has been in hospital for an emergency operation).
Can't wait until you can suck more power from that motor.
dozentrio wrote:I have a 24fet that I was using with the 80-100 Turnigy motor. At 10s, it would spike to 120 amps (100 amp current limit I think I had). At 20s, it would hit the hardware current limit and cut out. Motor has 130kv. Hope that info is of some use to you!
Arlo1 wrote:I found so much improvement with burties bord!!!! I went from 5.96 - 8.34 HP over night! I gained 20km higher top speed at 20 less amps!!!!! I know I can brake 10 hp with a 24 fet its not even getting warm right now!
Zen_Shenron wrote:I have been following this thread for quite some time now. It started with trying to organize a group buy, but nothing has been mentioned about that in quite some time. I understand all the testing and experimenting that has been going on with the prototypes as being essential to get the motor rite, and find a controller that will work with this beast of a motor. I was just wondering if we are ever going to see this motor available to buy or have those plans been put on the back burner?
Arlo1 wrote:Im not done finding all the power a 24fet controller can make but here is a good comparison of burties board
ptd wrote:sorry if this is a little OT, but since these guys seem open to alternatives, does anyone think it's possible for them to make a 1/8 (or maybe 1/12) length stator, and then a 1kw motor ?
SplinterOz wrote:Arlo1 wrote:Im not done finding all the power a 24fet controller can make but here is a good comparison of burties board
Arlo1,
great work... is looking really good. You are getting up towards the torque levels we were getting. Should be heaps of fun on your little bike.
SplinterOz wrote:Ok so after repositioning the Halls and checking them we redid the heat soak test today.
140 degrees C on the motor
Just under 80 degrees on the controller
120amps on the phase wires (all now withing 5 amps of each other)
So that means around 15nM continuous from this motor. Note that is with ZERO cooling! no airflow nothing. We should be able to double that with cooling.
Users browsing this forum: Hillhater and 5 guests
