Arlo1 wrote:Im not done finding all the power a 24fet controller can make but here is a good comparison of burties board
ptd wrote:sorry if this is a little OT, but since these guys seem open to alternatives, does anyone think it's possible for them to make a 1/8 (or maybe 1/12) length stator, and then a 1kw motor ?
SplinterOz wrote:Arlo1 wrote:Im not done finding all the power a 24fet controller can make but here is a good comparison of burties board
Arlo1,
great work... is looking really good. You are getting up towards the torque levels we were getting. Should be heaps of fun on your little bike.
SplinterOz wrote:Ok so after repositioning the Halls and checking them we redid the heat soak test today.
140 degrees C on the motor
Just under 80 degrees on the controller
120amps on the phase wires (all now withing 5 amps of each other)
So that means around 15nM continuous from this motor. Note that is with ZERO cooling! no airflow nothing. We should be able to double that with cooling.
Nuts&Volts wrote:I may be mistaken, but I think he is loading it with a lathe.
Arlo1 wrote:Here is a chart bigmoose set up so I can add motor A,B,C and Motor A is collossus what I mesured for resistance and inductance. Motor B is adding some inductance to each phase to get a total of 40uH and motor C is a total of 60uH in each phase so... I will experiment with different windings to make as much internal inductance as possible. But you can see with a 24 fet controller it takes around 20-25 u-seconds for it to be game over for your fets! And at 95 u-seconds you are at a Kilo amp!!!
SplinterOz wrote:Man nice measurements... the electrical engineer dudes here will love it.
EBJ wrote:Awesome!
Good thing you didn't fall off running the kelly input. Must be strange riding a bike like that.
This thing sounds great!
SplinterOz wrote:EBJ wrote:Awesome!
First thing today wire up the real throttle. I was not game to put to much throttle in due to the "strange" control. I kept taking my right hand down to turn the throttle... however that hand I need for braking
EBJ wrote:SplinterOz wrote:EBJ wrote:Awesome!
Hey, at least you didn't twist the pot, do a wheelie, fly off the back, and have your bike full-throttle into something.
Funny how that's all I was thinking about after seeing the "test controls"... I imagine you were thinking that the whole time as well (likely the reason it didn't happen).
AussieJester wrote:Great work Splinter manSeems to have adequate acceleration for a commuter bike
too! lil more tweaking and i think you will have a great setup ...Good to finally
see one of these motors in an actual bike not just spun up on a bench
and analysed to death LoL..
KiM
Users browsing this forum: Miles and 2 guests
