12 kw rc motor
Re: 12 kw rc motor
Postby markobetti » Fri Mar 05, 2010 6:20 am
No problem aussie , i will not sell it to you :) . I WILL GIVE THE ADRESS AND INFO TO EVERYBODY :> , SO EVERYBODY CAN BUY FOR THEMSELVES , OR YOU CAN MAKE A GROUP BUY IF FACTORY WILL INSIST ON QUANTITIES
Thats how i do it. Oh i hope its a real thing too....
markobetti
Re: 12 kw rc motor
Postby HAL9000v2.0 » Fri Mar 05, 2010 6:20 am
Hey,Marko. THis motor on picture definitly does not have planetaray gerbox. It doesn't have any gearbox. It is a normal outrunner.
This is the one you asked me about? I must have been looking at the wrong picture. 75 is definitly Kv not rpm for this one but the price is good.
HAL9000v2.0
Re: 12 kw rc motor
Postby markobetti » Fri Mar 05, 2010 6:24 am
YEAH , THIS IS THE ONE !!!!! PLANETARY GEARBOX... IS THE THING THE MANUFACTURER SAID THAT IT HAS IT...LATER ON , SHE DIDNT MENTION IT ... SO ,I DONT KNOW . BUT AS AUSSIE SAID...I LL RATHER THROW AWAY 250 BUCKS THAN JUST LOOK AT THE PICTURE:)))
markobetti
Re: 12 kw rc motor
Postby swbluto » Fri Mar 05, 2010 1:47 pm
BTW, 70-90 kV would probably be a good balance between motor speed, peak power and drive system requirements for a bike. Remember, not everyone will be running at 60+ Volts (Though no doubt a few will). The major problem with hub motors is that they have a really low kV and are limited by a poor "gear ratio", so they can't develop high power as easily(or as light, cheaply or efficiently).
swbluto
Re: 12 kw rc motor
Postby markobetti » Fri Mar 05, 2010 2:39 pm
swbluto.... i agree i think its ideal compromis this motors specifications . I have a problem finding kv of peletenber motor with the 11 kw power
Anybody knows specs ?
markobetti
Re: 12 kw rc motor
Postby nieles » Fri Mar 05, 2010 4:02 pm
nieles
Re: 12 kw rc motor
Postby markobetti » Fri Mar 05, 2010 4:13 pm
thanks niles... This motor is almost the same as plettenberg - think by rpm ratings that kv of plettenberg is a little bit bigger than this one, probably around 80 to 85
sweet
more info tommorow....
markobetti
Re: 12 kw rc motor
Postby nieles » Fri Mar 05, 2010 4:20 pm
the no-load rpm of the predator is 160 kv and at max efficiency around 130 kv
atleast according to the data on the site
nieles
Re: 12 kw rc motor
Postby 12p3phPMDC » Fri Mar 05, 2010 4:55 pm
Markobetti,
so who is the magic supplier???
"If you don't follow your dreams, you might as well be a vegetable." Burt Munro
The reasonable man adapts himself to the world;
the unreasonable one persists in trying to adapt the world to himself.
Therefore all progress depends on the unreasonable man.
-- George Bernard Shaw
12p3phPMDC
Re: 12 kw rc motor
Postby markobetti » Sun Mar 07, 2010 2:56 am
Hey guys, still waiting for motors.... will tell you all info shortly , please wait a little
markobetti
Re: 12 kw rc motor
Postby patrickza » Sun Mar 07, 2010 5:11 am
Hmm, 10kw is all that's needed for a powered paraglider... I'm so keen to get converting, but waiting for everything to be perfect. I need a prop RPM of 2500, so at 20s lipo I'd need about a 2 to 1 reduction. Maybe it would just need a delta wye conversion and then go direct drive for maximum effeciency.
Greyb.org, Cromotor, Headway 83.2v 20AH, Lyen 18 fet: viewtopic.php?f=3&t=45514
Kona Kahuna, x5305, Headway 76.8v 10AH, Crystalyte 72v48A: viewtopic.php?f=3&t=10256
Bladez Scoot, 450W motor putting out 3kW, Headway 38.4v 10AH, Lyen special controller: viewtopic.php?f=35&t=25872
patrickza
Re: 12 kw rc motor
Postby markobetti » Mon Mar 08, 2010 6:07 am
here s the motor picture
They will put high quality bearings , but no halls since they would need to open mould...
What do you say, opinions?
So i guess sensorless controllers is a way to go
markobetti
Re: 12 kw rc motor
Postby Jeremy Harris » Mon Mar 08, 2010 7:40 am
Fitting Hall sensors should be easy, especially as this motor has a fairly large stator. I'd say that fitting them as a DIY option is the way to go, all it'll take is for one of us to get one of these motors, do the install and then post some photos and instructions on here.
I may well be interested in one of these motors, so it may be that I'll be the Hall sensor mod guinea pig...........
Jeremy
Jeremy Harris
Re: 12 kw rc motor
Postby 12p3phPMDC » Mon Mar 08, 2010 10:18 am
The only thing that it seems to be missing is a shaft extending beyond the firewall side of the motor.
Taking power off of the prop side is more difficult. We may need to come up with a replacement shaft.
Looks great!! There will be a lot of folks intereseted in this setup.
Now all we need is a 200A 6 fet controller with hall sensors!
12p3phPMDC
Re: 12 kw rc motor
Postby markobetti » Mon Mar 08, 2010 1:31 pm
is that on the picture double bearings or am i not reading technical details good?
markobetti
Re: 12 kw rc motor
Postby 12p3phPMDC » Mon Mar 08, 2010 2:02 pm
That definitely has double bearings on both ends of the stator.
In addition, it has a skirt bearing.
All of those bearings = Well Supported Shaft and bell. :D
12p3phPMDC
Re: 12 kw rc motor
Postby markobetti » Sat Mar 13, 2010 2:41 am
FIRST OF ALL. STILL WAITING FOR MOTORS . I WILL GIVE ONE MOTOR TO HAL TO TEST IT IF HE WILL FIND TIME. WHAT DO YOU SAY HAL ? . FACTORY NUMBER AND ADRESS WILL GIVE YOU AFTER 20 OF THIS MONTH WHEN I RECIVE THE MOTOR(JUST TO BE SURE I GET IT , BEFORE THOUSOUNDS OF INQUIRES END UP ON THEIR MAIL :)). BUT IT WONT HELP YOU MUCH. FOR THE TWO MOTORS , MY FRIEND IN CHINA HAD SEVERAL CALLS AND TALKED ON PHONE JUST TO GET THEM ( THESE GUYS JUST WANT QUANTITIES AS I CAN SEE AND DONT REPLY VERY OFTEN TO MAIL) FIRST PRICE THEY OFFER 500 DOLLARS A PIECE ??? . SINCE EVERYBODY ASK ME IF I CAN SELL THEM THIS , I WILL TRY TO ORGANIZE A GROUP BUY FOR 100 PCS WITH FRIENDS IN CROATIA. THE PRICE WITHOUT SHIPPING FROM CHINA SHOULD BE AROUND 230- 270 DOLLARS .
PLEASE WRITE IF YOU ARE INTERESTED AND HOW MUCH PIECES WOULD YOU LIKE
markobetti
Re: 12 kw rc motor
Postby John in CR » Sat Mar 13, 2010 9:40 am
If HAL gives them a favorable report, put me down for 2 in the group buy.
John in CR
Re: 12 kw rc motor
Postby markobetti » Sun Mar 14, 2010 2:39 am
John in CR wrote:If HAL gives them a favorable report, put me down for 2 in the group buy.
Well , same here . If hal says they are good as they seem : great, if not ; then i just bought myself a pile of shit :) . Anyway , i am positive about this one , but lets wait and see . if they are good : they are going double on motorcycle ! and single for dh mtb :)
markobetti
Re: 12 kw rc motor
Postby liveforphysics » Sun Mar 14, 2010 3:13 am
4.5" diameter stator with 3" height.
If the efficiency is good, this single motor could easily be better than a pair of the big HXT motors.
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Re: 12 kw rc motor
Postby Jeremy Harris » Sun Mar 14, 2010 6:47 am
I'll certainly be up for one, maybe two, if they test out OK. I don't actually need 12Kw for the project I'm thinking of, but do want around 5 to 6kW continuous, so the extra headroom would probably be good for reliability.
Jeremy
Jeremy Harris
Re: 12 kw rc motor
Postby markobetti » Sun Mar 21, 2010 3:07 am
i GOT THE MOTOR !!!!!!!!!!!!!!
HE IS THE SICKEST THING I SAW :) :) :) : ): :) :) .... TODAY I WILL SEE HAL AND WE WILL TRY TO TEST IT. HERE ARE THE PICTURES . MOTOR CONSTRUCTION LOOKS OUTSTANDING
THIS MOTOR IS MADE FOR INDUSTRIAL APPLICATION FOR SURE , HE IS NOT SO LIGHT. HAS AROUND 5.5KG . DEFINITELY HAS A LOT OF SPACE FOR AIR FLOW ON UPPER AND DOWN PART OF THE STATOR
HERE ARE THE PICS : SIZE COMPARISON WITH CIGARETTES AND AGNI :)
markobetti
Re: 12 kw rc motor
Postby liveforphysics » Sun Mar 21, 2010 3:41 am
Unless you've got the worlds smallest hands and a miniture pack of cigerettes, I'm sold!
Who do I paypal?
BTW- I love that picture with the Agni next to this RC motor. It's like the looking at the past and the future.
liveforphysics
Re: 12 kw rc motor
Postby AussieJester » Sun Mar 21, 2010 5:30 am
Wholly snapping duck shit i MUST have one of these beauties!!! Luke forgets about
160km/hr e-bike 200km/hr babeee! Lets see those frock motor boys catch this bad boy :twisted:
liveforphysics wrote:
Who do I paypal?
^^Ditto
KiM
AussieJester
Next
Return to Motor Technology
Who is online
Users browsing this forum: Jaesin and 2 guests
