12 kw rc motor
Re: 12 kw rc motor
Postby Arlo1 » Tue Jan 10, 2012 4:21 pm
adam78 wrote:This controller might be able to run colossus but costs around 1800 USD and is only rated for 15s LiPo
The controller has been used in a small e-car they converted using a huge 40kW BLDC outrunner.
This motor needs to spin past 6000 rpm to get to its max efficiency. That meens at least 20s lipo or rewind i for lower inductance and higher kv? We need a 100v 600-1000 amp controller! Im working on it :)
Thanks Justin of http://www.ebikes.ca/
Also a thanks to Methy at http://www.methtek.com/ :)
And Dave who has some good deals on STUF
RC lipo and most other types of Lithium batteries you MUST know your individual cell voltages while charging and discharging.
Batteries of all kinds need respect they can burn your house down, so don't sleep with them under your bed or any other were you cant afford smoke or fire!
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Re: 12 kw rc motor
Postby markobetti » Sun Jan 29, 2012 5:52 am
Arlo , Splint i just may have invented the wind cooling system patent haahah :).... anyway its air-cooled...JUST TO LET YOU KNOW we re not stoping this developement...
http://youtu.be/MeNk2Fcag0w
markobetti
Re: 12 kw rc motor
Postby SplinterOz » Sun Jan 29, 2012 6:06 am
Nice... One question... does it still have the same bolt pattern for mounting? and the same diameter?
Actually that was two
SplinterOz
In the Capital of Australia
http://rgelectric.wordpress.com
SplinterOz
Re: 12 kw rc motor
Postby Arlo1 » Sun Jan 29, 2012 12:45 pm
I love you guys. Now someone fly to canada and help me finish this damb controller!!!
Arlo1
Re: 12 kw rc motor
Postby markobetti » Mon Jan 30, 2012 2:39 am
SplinterOz wrote:Nice... One question... does it still have the same bolt pattern for mounting? and the same diameter?
I will check , but dont worry - i have a solution for you to mount on the same place if required . One small change is needed but you will be able to use the same expensive and beautiful mount .
Best RGDS,
Marko
markobetti
Re: 12 kw rc motor
Postby markobetti » Mon Jan 30, 2012 2:40 am
Thanks Arlo , same goes for you :)
markobetti
Re: 12 kw rc motor
Postby markobetti » Mon Jan 30, 2012 7:12 am
Diameter same
markobetti
Re: 12 kw rc motor
Postby dangerzone » Tue Jan 31, 2012 8:56 am
c_a wrote:What is the real problem with the kellys?
I am building a 40kW peak motor and I like to use a kelly for the first tests...
And which controller did you have in mind to couple with that..?
dangerzone
Re: 12 kw rc motor
Postby Arlo1 » Tue Jan 31, 2012 10:13 am
Marko is working on testing a couple controllers as am I. All my spare time is now dedicated to making this motor fly!
Arlo1
Re: 12 kw rc motor
Postby dangerzone » Tue Jan 31, 2012 11:30 am
Arlo1 wrote:Marko is working on testing a couple controllers as am I. All my spare time is now dedicated to making this motor fly!
It would be nice to find something strong enough for that kind of rpm yet affordable at the same time... ;)
dangerzone
Re: 12 kw rc motor
Postby Arlo1 » Tue Jan 31, 2012 2:47 pm
Well get building it.... IF price is going to be the issue you may need to build it your self lol. Im doing everything I can to develop a cheep but effective controller.
Arlo1
Re: 12 kw rc motor
Postby gensem » Fri Jun 22, 2012 7:45 pm
Markobetti
Any update on the motor/controller?
A decent 25mph bike will cost around $1000.
A decent 35mph bike will cost around $2000.
A $1000 35mph bike will get you killed.
Justin we really appreciate what you did!
gensem
Re: 12 kw rc motor
Postby Bjorntsc » Thu Aug 16, 2012 6:02 pm
I am starting a project and need a motor.
Link to my thread:
http://www.endless-sphere.com/forums/viewtopic.php?f=28&t=42795
Bjorntsc
Re: 12 kw rc motor
Postby Arlo1 » Thu Aug 16, 2012 7:41 pm
Im still working on this and very close to dyno testing but..... 60+ hours of work per week for my money making work (to pay bills and debt) realy slows down getting to it! I dont know who else is working on it ATM. But hi power brushless motor controll is slowly becoming more avalible. I have BIG controller plans so I will keep you all posted.
Arlo1
Re: 12 kw rc motor
Postby Bjorntsc » Fri Aug 17, 2012 3:35 pm
It has been a while since anyone posted on this thread, so I gave it a push to try and get it moving again.
I was wondering if you know anything about the 7kW colossus on another thread?
Bjorntsc
Re: 12 kw rc motor
Postby Arlo1 » Tue Aug 28, 2012 1:27 am
You can push a thread all you want it is a hard to run motor you can buy it but there is no controllers under ~$5000 for it!
I made this controller and so far this is what I have. I have a ways to go but IM getting there!
Arlo1
Re: 12 kw rc motor
Postby Ratking » Tue Aug 28, 2012 3:31 am
Yeah, its turning on its own 8)
Good luck with your controller, would be fun to build a light bike with that motor.
Next project maybe?
Ratking
Re: 12 kw rc motor
Postby nechaus » Tue Aug 28, 2012 4:03 am
Im assuming my rc fatboy controller is going to be useless for ebikes
I would be interested in seeing how it runs that motor tho
Magic pie Dual Suspension
Peak 6kw Air cooled
Kelly controller (mini kbs series, smaller than a coke can, can do 80+ battery amps peak, Favorite small controller. Really punchy)
20s 16ah
60 kmh,
Safe, Beautiful handling.
nechaus
Re: 12 kw rc motor
Postby SplinterOz » Tue Aug 28, 2012 4:07 am
Just an update from my build thread.
Yes that is my bike, yes it goes, yes the Colossus is running fine.
Not as much getup as I would like... will be looking into that.
SplinterOz
SplinterOz
Re: 12 kw rc motor
Postby nechaus » Tue Aug 28, 2012 4:15 am
Wow
Im super impressed!
nice job!
Peak 6kw Air cooled
20s 16ah
60 kmh,
nechaus
Re: 12 kw rc motor
Postby SplinterOz » Tue Aug 28, 2012 4:59 am
nechaus wrote:Wow
Im super impressed!
nice job!
Thanks. :) should be registered in the next month or so.
SplinterOz
SplinterOz
Re: 12 kw rc motor
Postby nechaus » Tue Aug 28, 2012 5:08 am
What sort of power does it use for regular riding ?
watt hour per km
max amps ect...
Peak 6kw Air cooled
20s 16ah
60 kmh,
nechaus
Re: 12 kw rc motor
Postby SplinterOz » Tue Aug 28, 2012 5:12 am
These are all good questions... most can be found on my build thread
However have a look at this post within this thread .
SplinterOz
SplinterOz
Re: 12 kw rc motor
Postby nechaus » Tue Aug 28, 2012 5:20 am
I have been slowly going through the 100 + pages hehe :)
Peak 6kw Air cooled
20s 16ah
60 kmh,
nechaus
Re: 12 kw rc motor
Postby Arlo1 » Tue Aug 28, 2012 9:28 am
Ratking wrote:Yeah, its turning on its own 8)
Next project maybe?
I have 2 on the go a YSR 50 and a 1987 CBR 250R
Arlo1
PreviousNext
Return to Motor Technology
Who is online
Users browsing this forum: cr4zyu and 9 guests
