Doing the Math
Re: Doing the Math
Postby Kingfish » Thu Oct 28, 2010 2:27 pm
Layouts:
I am still wedded to the 32-pole/16:1 gearing of Plan-D and do not wish to part with much of the research. Plan-D in brief:
  • 32 Poles / 16:1
  • 30 Teeth / 10 teeth per phase
  • Magnet length = 20 mm (preferential designs for both 4 and 5 mm)
  • Each Copper winding is 3 mm wide x 33 turns
  • r = 90 mm / 0.090 m.
  • F = Ï„ / r = 33.9 / 0.090 m = 377 N
  • 2-Stators/3-Rotors
Working up a model for comparison, two new layouts using bar magnets are presented below in Figure 26.
  • Layout A: Plan-D (Halbach illustrated simply with 2-magnets per pole).
  • Layout B: Displays the use of 1.0 x 0.5-inch wide bar magnets with a small air gap in-between at the ID.
  • Layout C: Same as B except 2.0 x 0.5-inch wide bar magnets with a small air gap in-between at the ID.
  • The Yellow circle is the OD of a Nine Continent 280X hub motor for reference. Note that A & B fit neatly within the physical limits (as per design), whereas with C the actual finished assembly will increase the diameter from roughly 8 inches to nearly 10.
  • Because we are not using Halbach arrangements it is presumed that we must increase other physical quotients to make up for the deficiency. I took the liberty of drawing the length of the magnets of A across B & C for reference (two red lines).
  • Though B offers slightly longer lengths the Torque-arm is smaller and the magnets would need to be taller than 5 mm. The fact is I would not consider magnets less than ¼ inch (6.35 mm) high.
  • Layout C is better suited in that the average Torque-arm is essentially the same as in Plan-D, although the magnet length is larger and the goal of creating a motor smaller than a 9C would not be met.
  • There are shorter magnets; I can source 1.5-inch long magnets however that particular manufacturer has different heights and Gauss strengths.
  • As an alternative (not shown), use the 1.0-inch long magnets at the same Torque-arm radius as Plan-D and just move on.
Privately, Layout C appeals to me as a candidate for a motorcycle hub. :wink:
Clearly there are many factors we could play with. FEMM studies shortly.
~KF
* My 2WD Garden Wall
* Current ride: 2WD Disc EBikeKit (9C 2806-equivalent) / Dual Lyen 12FET / 15S6P LiPo when commuting.
* Going to California: 2011: Trip completed 8)
* Club Member: 40-mph & 101. 10k-Club: 9634 miles-to-date, 4144 as 2WD.
Kingfish
1 GW
1 GW
Re: Doing the Math
Postby BrushlessinSeattle » Fri Oct 29, 2010 3:16 am
Rhitee,
I'm fairly sure that the geometry will work. If you start with a ring of wedge magnets:
(25.85 KiB) Downloaded 123 times
...and then push them out along radial lines that bisect each magnet, you end up with rectangular gaps:
(32.42 KiB) Downloaded 123 times
In the gaps you could place horizontally magnetized block magnets. Im glad you questioned my use of diagonally magnetized block mags. It was a hunch, but after some Femming I discovered that simple block magnets at 90 degrees are more effective - thats a good thing.
KF,
It looks like your well on your way to a final design. I'll share my latest findings with you anyway - food for thought if nothing else.
Heres a Femm analysis at the midpoint (halfway between the inner and outer edges of the magnets):
(111.52 KiB) Not downloaded yet
Im using 1cm thick magnets and a 1cm airgap
The average flux density is around 0.74T. Its higher as you move towards the center and lower as you move outwards - this will be no surprise to you given your earlier work :)
If I were to remove the intermediate magnets and slap a big, 1cm thick, steel plate on each side, I would get about .79T. A little better but at the cost of lbs of weight. I have to ride up Pine St towards Capitol Hill!
Wedge shaped intermediates would be better but would need to be custom made. This array is far from perfect but it would be cheap to implement and could be significantly lighter than a back-plate design.
Having said all of that, Im a complete amateur when it comes to this stuff. If I've made mistakes please let me know :|
BrushlessinSeattle
100 µW
100 µW
Re: Doing the Math
Postby liveforphysics » Fri Oct 29, 2010 3:36 am
BrushlessinSeattle, Kingfish, (and other Seattle guys if they want)-
I bought a boatload of magnets to build halbach arrays for axial flux motors, and other materials, bearings, carbon fiber plate for the rotors, etc.
You're welcome to all stop-by sometime and have a little get together or BBQ to discuss/plan building some badass motors.
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Re: Doing the Math
Postby Arlo1 » Fri Oct 29, 2010 9:27 am
Im not invited :cry:
Thanks Justin of http://www.ebikes.ca/
Also a thanks to Methy at http://www.methtek.com/ :)
And Dave who has some good deals on STUF
RC lipo and most other types of Lithium batteries you MUST know your individual cell voltages while charging and discharging.
Batteries of all kinds need respect they can burn your house down, so don't sleep with them under your bed or any other were you cant afford smoke or fire!
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Re: Doing the Math
Postby Kingfish » Fri Oct 29, 2010 1:09 pm
I think a local tribe pow-wow is in order! Arlo, git on down here!
Luke, name a date/time and let’s go from there. Pot-luck? Tell us what you want us to bring.
Brushless, just a couple of questions:
  1. What is your targeted system geometry? Hub, out/inboard motor?
  2. What is the size of the driving wheel(s)?
  3. What is the top-speed that you intend?
  4. What is your target voltage?
From that information we will be able to provide more substantial feedback.
Pine St.-Capitol Hill: Oh I know that route! :wink: I thought a good urban hill-climber was the one Luke and I took after a day of exploring SeaFair, beginning at Lake-WA Blvd/Lake Park Dr (at the park) up McClellan then north on MLK to E. Madison @WOT, then SE up on over the hill and down past Broadway, and at this point we corked around looking for food and wound up at about 8th and Marion (sushi). They’re all big long steep hills we take for granted in a car. IMM, Seattle has steep hills that parallel SF: How about that winding-burner from Alaskan Way to 5th Ave up Marion? :shock: With the right voltage, battery, and controller (likely modified) ~ any urban hill is possible (and 2WD is better).
Smokin' KF
Kingfish
1 GW
1 GW
Re: Doing the Math
Postby Arlo1 » Fri Oct 29, 2010 1:24 pm
Kingfish wrote:I think a local tribe pow-wow is in order! Arlo, git on down here!
Smokin' KF
Im in I love pushing my self to lern as fast as possible and I have a axial flux project to start very soon so....
But I am looking at things and I dont see the benifate of a Halbach aray just yet and could someone explaing in laymans terms the reason it would be a benifit?
Arlo1
Re: Doing the Math
Postby Kingfish » Fri Oct 29, 2010 2:59 pm
Arlo, for sure friend :)
The single primary difference between a Halbach Array (HA) and traditional motor magnet arrangements is that the HA consists of at least two magnets to create a single pole, and minimum four magnets to create the N-S pairing. Excellent short-subject here:
http://en.wikipedia.org/wiki/Halbach_array
The primary value is that the magnetic field & associated flux density are flipped to one side as oppose to both sides experiencing forces. The field is not precisely doubled, though in layman’s terms it is effectively so, and this lends itself to significantly enhanced characteristics desirable in both magnetic levitation and drive systems where space is at a premium.
The HA also eliminates the “Flux Ring” associated with non-HA AF orientations. Without the Flux Ring, the magnetic circuit would leak from the system ~ and actually based on the FEMM studies it is better to say “flood”, for without the ring there is nothing but air to constrain the field. The HA, by implied physical arrangement, redirects the lossy field with measurably superior effectiveness over the flux ring.
With linear or even radial systems HA is pretty economical, however in the axial arrangement the magnets need to be wedge-shaped and in physical contact. It is this wedge-shape that is expensive for custom designs. It is definitely a huge tooling cost as Thud had pointed out earlier. The special feat of correct engineering requires that the design of the object fit within reasonable production, timely manner, and cost-effective. The raw materials must also be readily available.
<soapbox: ON>
When I began this study I initially had costs for a 2-rotor/1-stator down to around $600 for magnets ~ and I thought that was livable for a one-off prototype. Now I am looking at $2000 per wheel and it’s no longer a viable option. Small thread on the price shift. I think we can do better. 8)
<soapbox: Off>
Using the same philosophy as we have with the HobbyKing LiPos for building battery packs, we leverage the mass-production units to construct a reasonable AF solution. Let’s grab some common inexpensive stock and make do with it! Note that the significant part of this challenge is that each magnet supplier is slightly differentiated on height, width, length, strength, and heat-tolerance: It takes a willingness to compromise on the ideal, and a spreadsheet to keep track of the assets.
I am going to pick one supplier, roll the numbers, and see where and how we can bake this AF cake into an equally tasty HA-alternative. Then we’ll pick another supplier and do the same. As we canvas and survey the possibilities, our additive comprehension of the indefinite envelope for opportunity will resolve as tangible, and once there we should be able to articulate a wide assortment of solutions.
Make sense? KF
Kingfish
1 GW
1 GW
Re: Doing the Math
Postby Arlo1 » Fri Oct 29, 2010 6:43 pm
Thanks kingfish. The most important part was the magnets doubble (or close to it) the flux on the one side all I knew was it canceled the flux on one side. This makes more sense now.
Arlo1
Re: Doing the Math
Postby BrushlessinSeattle » Sat Oct 30, 2010 5:02 am
KF, you asked:
1.Axial DD motor, built on a customized hub. I’ve built an experimental version of the hub. It comprises of two 1/3 length hubs which are separated on the axle so as to expose the center section of the axle (total of 4 bearings) . A stator could be attached to this exposed section. The rotors would then attach to each side of the split hub and possibly to the spokes at the outer circumference (if the radius is sufficiently big). Whether using a hub that is split in this way is a workable approach remains to be seen. Its clearly going to affect the structural integrity of the wheel but I hope to get away with it. Connecting the outer edge of the rotors to the spokes will help.
2.26”
3.25mph (or more)
4.No idea
LiveFor Physics,
Ive got a crazy work schedule right now which keeps me busy most evenings but I’d love to come by and see what you have going on, talk about motors etc… and you have carbon-fiber! That’s awesome. Afternoons?
BrushlessinSeattle
100 µW
100 µW
Re: Doing the Math
Postby liveforphysics » Sat Oct 30, 2010 6:58 am
Arlo1 wrote:Im not invited :cry:
You've got a permanent invite to anything I'm doing Arlo*
*unless it involves girls in a quanity less than 3. ;)
liveforphysics
Re: Doing the Math
Postby liveforphysics » Sat Oct 30, 2010 7:04 am
Potluck sounds great.
I work nights, and generally 5-6days a week of >12hrs shifts. So I can make afternoons work if I sacrifice sleep (which is fine).
I need to pick my place up a bit though first. lol It looks kinda like a UFO carrying racecar and motor parts just exploded in there at the moment. lol
Maybe roll the dice and try my luck with another Craigslist maid, and try not to have it end badly (as all previous maid experience as gone...lol)
liveforphysics
Re: Doing the Math
Postby liveforphysics » Sat Oct 30, 2010 7:06 am
Also, back onto the topic of this thread, have you folks seen this axial-flux hubmotor?
viewtopic.php?f=2&t=22255
liveforphysics
Re: Doing the Math
Postby Arlo1 » Sat Oct 30, 2010 2:33 pm
Haha thanks man but I dont waste my time with girls anymore wait that came out wrong lol :mrgreen:
Arlo1
Re: Doing the Math
Postby Kingfish » Sat Oct 30, 2010 2:43 pm
Arlo, I think you meant to post that comment here: http://endless-sphere.com/forums/viewtopic.php?f=3&t=19479 :lol:
~KF
Kingfish
1 GW
1 GW
Re: Doing the Math
Postby Arlo1 » Sat Oct 30, 2010 2:48 pm
Haha too funny! I am going to sit and read through this thread as soon as I can! And get started on the mini vierson multi layered axial flux motor for a practice run! Then the big motor will be for the drag bike! The good and bad news is the boss has a guy trying to get us $20 000 to get it off the ground! (Also bad because like luke I have to many projects and am not ready) But like Luke I also love the challange!
Arlo1
Re: Doing the Math
Postby Arlo1 » Tue Nov 02, 2010 3:32 pm
So luke warns me not to run an axial flux with out a halbach or an iron backing behind the magnets is this true and why? Is it just efficiency that suffers or more?
Arlo1
Re: Doing the Math
Postby Kingfish » Tue Nov 02, 2010 4:55 pm
Arlo, you have brought up the $64,000 Question! :)
Allow me to direct your attention to the Figure 27A below:
The Magnets are ¼-inch / 6.35 mm thick using N42 material.
On the Left, we have a 2-Rotor non-Halbach Array (NHA). The backing plate – though illustrated, is set to exactly the same non-magnetic material at the rotor = Aluminum 7075. The Magnetic Flux field passes unhindered or constrained in any observable manner. The Right side is identical except that we have 3-Rotors.
Taking the Integral diagonal through the cross-section yields:
  • Left: Average B.n = -0.561521 Tesla
  • Right: Average B.n = -0.60282 Tesla
Seems kinda weak relative to a Halbach Array (HA) especially for the magnet thickness. Let’s change the backing plate material and observe the change. The backing plates are 3 mm thick total and the material = M-43, which is about 5 laminations. Figure 27B illustrates the profound change.
  • Left: Average B.n = -0.717422 Tesla
  • Right: Average B.n = -0.690459 Tesla
The Left side is clearly improved by 0.15 T whilst the Right Side by 0.09 T.
For reference, let’s compare that to a HA with 6 mm thick N42 magnets as indicated in Figure 27C.
  • Left: Average B.n = 0.809887 Tesla
  • Right: Average B.n = -0.751268 Tesla
Well, I believe we can readily ascertain that the Halbach Array provides substantial improvement overall ~ but we knew that. :wink: Yet there are still unanswered questions about the NHA, such as effects of design manipulation and the cost benefits.
EDIT: Forgot to add L & R to Fig-27C measurements.
More in a bit, KF
Kingfish
1 GW
1 GW
Re: Doing the Math
Postby Biff » Thu Nov 04, 2010 9:48 am
Kingfish wrote:Well, I believe we can readily ascertain that the Halbach Array provides substantial improvement overall ~ but we knew that. :wink: Yet there are still unanswered questions about the NHA, such as effects of design manipulation and the cost benefits.
The benefit of the Hallbach isn't that clear to me. You have a lot more magnetic material in the Hallbach array than you do in the NHA design, if they both had the same amount of magnetic material which one would have the higher flux density in the airgap?
If I see the diagonal line used for integration correctly it looks like it is just in the airgap where the flux travels, rather than a vertical line through the entire length of the airgap. I see that the Hallbach has only 2 magnetic flux paths, but the NHA has 3, What is the total area where the flux travels between the rotor and stator. It is more of the total flux that interacts between the rotor and stator that determines its ability to perform work rather than flux density. If you can get more flux travelling past the rotor with the hallbach array for a given space then you can get a higher power density which would be the advantage.
Biff
Re: Doing the Math
Postby Kingfish » Thu Nov 04, 2010 2:59 pm
Hi Biff
“…if they both had the same amount of magnetic material which one would have the higher flux density in the airgap?”
The amount of magnetic material is double to create a single pole for the HA as oppose to the NHA. Therefore the cost of the custom-shape HA is compounded. There are advantages and disadvantages to this, however – at this point in the thread we are focused on reducing that cost greatly by using off-the-shelf magnets, and to do that we need to make a few compromises:
  • We lose our optimum shape.
  • We gain a lossy air gap between the magnetic poles along the rotor face.
  • We need to add a Flux Ring to capture the stray field, arrest flux leakage, and better concentrate the density between the rotors.
  • The Flux Ring adds cost and complexity.
  • The off-the-shelf magnets generally have lower Strength, thus we need to add more thickness to compensate.
To conclude, the configurations are as different as are apples and oranges. Imagine how inexpensive a linear HA would be to a NHA! And yet – the cost is prohibitive for prototyping an AF machine. Once production starts, this financial aspect would reduce with each completed assembly – so long as your magnet supply is solvent.
“If I see the diagonal line used for integration correctly… <snip>”
  • The pole-count for the examples given above is the same for both HA and NHA: 32 poles/16 pole-pairs.
  • At the mid-point of the magnet the average radius arm is also the same at 0.09 m.
  • The Halbach magnets have a consistent cross-section whereas the NHA will have a very small air gap at the base and a very large one at the top: It deceptive looks like there are more poles with the NHA.
  • We need only to model one N-S pole interaction for HA, though the NHA modeling requires terminating poles, hence there is an extra pole pair to balance the other side and this allows us to take a proper measurement through the air gap of the middle pole pair.
  • Regardless of the configuration, the HA has higher Flux Density over the NHA with or w/o employment of the backing plates. And actually the HA would be higher if we used 6.35 mm thick magnets rather than 6 mm (I reused one of my earlier models for this comparison).
  • Lastly, when comparing designs, there is no need to calculate the entire flux density of the system when a segment will suffice: Figure 27C representing a HA clearly has a higher flux density over Figure 27B NHA.
More...
Kingfish
1 GW
1 GW
Re: Doing the Math
Postby Arlo1 » Thu Nov 04, 2010 3:06 pm
What was the pull force rating of the magnets on the most effiecient motor (world record holder)? Could one not just figure out how to make a higher pullforce rated magnet??
Arlo1
Re: Doing the Math
Postby Kingfish » Thu Nov 04, 2010 3:11 pm
I do believe you have a valid point though about adding more material: What happens if we attempt to use the same amount as in the HA? The first thing we need to understand is that the geometries are not the same: An AF HA uses wedge-shaped magnets whereas we are using Bar-shaped, or cubes assembled into bars; Apples and Oranges.
If I were to create an AF HA motor it is likely I would have chosen the 5 mm thick 3-Rotor/2-Stator design, and the calculations were completed up to that point to permit cost analysis. Using that model, after I added the windings to the model and put current through them, the integral across the diagonal yielded an Average B.n = 0.81119 Tesla which is quite impressive. Now imagine that I would like to meet or exceed this with off-the-shelf materials :idea:
We understand that the HA shapes are volumetrically different. Let’s run a quick calculation to see how much taller these magnets would become for NHA…
HA - Volume of a Donut:
    V0 – V1 = Vf -> π (r0 – r1) * h;
    π [(0.1)^2 - (0.08)^2] * 0.005 = π (0.000018) = 5.65 x 10-5 m^3 for one face.
    Inner Rotor uses ½ the magnets; = 2.827 x 10-5 m^3
    Total Magnet Volume = (5.65 + 5.65 + 2.827) x 10-5 = 1.41 x 10-4 m^3
NHA – Volume of a circle of Bars:
Using British/American Units, let’s calculate the Area.
    One Bar at ½-inch / 0.0127 m wide x 1.0 inch / 0.0254 m tall x 32 = 0.01032256 m^2 per rotor face.
    The Inner Rotor has the same amount of magnets;
    The total area = 0.01032256 * 3 = 0.03096768 m^2.
Divide HA Volume by NHA Area to get NHA height:
    1.41 x 10-4 / 0.03096768 = 0.0047 mm ≈ 5 mm.
Surprised by the volumetric similarity? Now the rub: You can’t buy 1-inch x ½-inch x 5 mm high magnets. So let’s make them ¼-inch/6.35 mm high and run the FEMM calcs as they were N52 with the Flux Ring backing plates. The integral across the diagonal yields an Average B.n = -0.773328 Tesla which is LESS THAN the Halbach Array at 5 mm high.
Conclusion:
We need to make the magnets taller. Though we’re really close, the problem is that there is only one manufacturer that has those exact perimeters. We could also tinker with the Flux Ring material. Just for fun I swapped out the M-43 material for Carpenter Silicon Core Iron "A", 1066C Anneal and re-ran FEMM: The integral across the diagonal yielded an Average B.n = -0.816757 Tesla! But what is the cost of this material? Is it easy to get, to machine, and will it hold up to structural tension?
BTW – the cost of the magnets for a single wheel is reduced to Quantity 32 * 3 = 96 / wheel with a price-break at Qty-100; $245/wheel. But we also need to figure in the cost of the Flux Ring…
What happens if we change the design, use more common magnet strengths such as N42 or 45? How would the design change to accommodate?
Arlo: Do you have a link to the world-record holder so we can examine further?
~KF
Kingfish
1 GW
1 GW
Re: Doing the Math
Postby Arlo1 » Thu Nov 04, 2010 3:35 pm
I will try to find it later unless luke chimes in (he knows were it is) I have seen a bit on it about 2 years ago when I first got into this! 99% and its Axial flux I belive!
Suprised you dont have it on your desktop Kingfish with how in depth your knoladge is!
Arlo1
Re: Doing the Math
Postby Kingfish » Thu Nov 04, 2010 4:10 pm
I’m a practical engineer, and often disregard edge-cases as unattainable. In the present global situation a HA AF motor is unattainable unless I won the lotto. We are better off rolling up our sleeves and making do with what we can grab off-the-shelf (OtS) and manipulate into a NHA motor for at least ¼ the cost of a HA :)
I think it is important to complete the feasibility study, roll it around, kick it a couple of times. Then look at one last option: Rim Motor. However - with all of these conversations, the one thing that should be obvious is the optimistic beacon of hope that we can design a better, more efficient motor than what is currently available. If we can foster enough enthusiasm then let’s make a few as a group-buy/endeavor to clamp costs. My goal is to extend the battery pack if I can get the Tesla high enough. And we should also consider the Radial Flux calculations – just so people understand how lossy these motors really are! :wink:
My $0.02. KF
Kingfish
1 GW
1 GW
Re: Doing the Math
Postby Thud » Thu Nov 04, 2010 5:41 pm
I think this is the world champ motor discused:
http://www.csiro.au/files/files/p37d.asx
Kingfish, Just a thank you for going all through this exorsize. I have learned a ton & had several moments of expansion while attempting to comprehend all the fomulas & diagrams. Its been good for me.
while I was researching I went to the next step to see what it would take to be able to create custom magnets. for the ULTIMATE Halbauch array senario.....(un zapping & re-zapping into the desired angles of attraction) I found little to help me out in that vein. We used to have a magnet zapper at the rc car club to keep our motors cranking at max potential...I thought there may be some work around to get some "secret sauce" magnets for a reasonable investment.
any one know if neodynmionionionm (???) can be re-oreinteted magneticly for those of us who never say die?
just one of todays out of the box thoughts.
carry on. T
get some......
Thud
Re: Doing the Math
Postby Biff » Thu Nov 04, 2010 8:07 pm
Thud wrote:I think this is the world champ motor discused:
I have 2 of those motors, the biggest problem with them is that you can't cool them. If you run them over 20Nm for any length of time, the stator warps and you end up with a $10,000 piece of epoxy and aluminum. I built a raidal flux motor that is around the same weight and size, but can deliver 50Nm continuous with ease, but is around 94% efficient (vs the 97% of the CSIRO).
Thud wrote:Kingfish, Just a thank you for going all through this exorsize. I have learned a ton & had several moments of expansion while attempting to comprehend all the fomulas & diagrams. Its been good for me.
carry on. T
You can actually order magnets in any orietation you want for fairly reasonable price, maybe even cheaper than buying them off the shelf (there is usually a very high markup off the shelf), no need to comprimize. Come up with a design you want and get a quote, you might be surprised. I gave KingFish the contact information for a manget manufacturer I have dealt with before.
Biff
PreviousNext
Return to Motor Technology
Who is online
Users browsing this forum: Google [Bot] and 8 guests
cron
