rhitee05 wrote:Okay, that explains the design choice. I'm a little confused by the details however. You say that the magnet OD is 180 mm and the magnets are 30 mm long, which would imply that the ID is 150 mm and the average diameter is 165 mm. But you say that the average (midpoint) diameter is 150 mm?
For the geometry you posted (fig 4), I actually think we can make a big hand-waving simplification and say that the effective length of each coil is 2x the magnet length. Why you ask? Especially for the coreless case, we can assume with a reasonable degree of accuracy that the magnetic field is uniform across the face of each magnet and zero outside the face. There will be some fringing fields, edge effects, etc, but this assumption makes things very easy and is fairly accurate. Since the only portion of the coil of interest is the portion within the magnetic field, and due to the coil shape these sections are entirely in the radial direction, we can simply say that the effective length is 2x the magnetic length (one for each side of the coil). Simple, eh?
Another suggestion I'll toss out is to consider using overlapping windings. That will generally achieve higher copper fill (more power density), but at the cost of having more stator poles and thus higher electrical frequency. But, that doesn't seem like it should be a problem here.
rhitee05 wrote:Another comment about the number of windings. You may already know this, but I'll add it for the benefit of others who might be reading along.
The total number of wires per slot determines the torque/power potential of the motor. Using the terms "slot" or "tooth" is a little imprecise when talking about a coreless motor here, but I think everyone will understand the intended meaning.
How those wires are connected then determines the Kv/Kt of the motor. For example, if you made each winding a single coil of 28 turns in series, you would have a motor with very low Kv and high Kt. If you did the other extreme and placed 28 single coils in parallel, you would have a motor with high Kv and low Kt, with a whole spectrum of choices in between.
Kingfish wrote:# Magnets in Plan-A are 30 mm in length.
# Let's start with the 180 mm OD and convert that to r = d/2 = 90 mm.
# Subtract 30 from 90 = 60; 60 mm r = 120 mm ID.
# 1/2 of 30 mm is 15 mm; 60 + 15 = 75; midpoint = 75 mm r or 150 mm diameter.
rhitee05 wrote:Kingfish wrote:# Magnets in Plan-A are 30 mm in length.
Sigh. I seem to be having problems with math recently. You are, of course, correct.Your use of terminology seems reasonable and fairly standard, so there should be little confusion.
Kingfish wrote:Eric, can you live with a layout as shown in Figure 14 where the cross-section is close to ideal, the separation between the windings is enough for airflow, and the distance between the up and down legs are at the maximum? The overall turns advances from the original 22 or 23, to 33 turns by using smaller gauge flat wire. If we’re good on this I think it would be prudent to calculate resistance, inductance, and changes to Current and voltage.
Kingfish wrote:Certainly we could get more area to work with if the bounding Radius were allowed to expand, however I think that the 2806 hubs are already ungainly in diameter. The only alternative is to move the magnets to the rim – and maybe that should be explored a bit later – though I suspect that is another can o’worms.
You can imagine the opposite of a hub motor - sort of a "rim" motor. If you could get past the construction details, that would be an excellent way to build a high-torque low-RPM motor with a very high pole count.
The magnet sectors drawn in red in your Fig 14 - what do they represent?
The triple layer of 24 AWG wire looks like it would work out well. Depending on what Kv you want to achieve, you could connect the layers in parallel and get approximately the same current capacity of the single 20 AWG, but with 50% more turns.
rhitee05 wrote:<snip>
Not sure what you mean regarding the parallel inductors and eddy currents. Can you elaborate?
<snip>
rhitee05 wrote:FEMM is a fun tool, isn't it?
If you set up the model properties right, FEMM will calculate the force for you. For each of your coils you can add material properties for copper with such-and-such number of turns, such-and-such current.
The next step up is you can set up the model to allow you to move the rotors relative to the stator and plot the resulting data. I believe it's possible to generate a BEMF curve, for example. I'm a little fuzzy on the details but I think there is an example (either included with FEMM or available on their website) which goes through this for a radial-flux motor.
Users browsing this forum: Google [Bot] and 2 guests
