Doctorbass
Guys.. I had a really good idea last night
We always had problem with the the room on the axel and bearing for adding liquid cooling tubes on our hub motor.
Now i realized that the gauge 10 silicone wire from Hobbykin that we can already succeed to put on the axle have exactly the same diameter as the 3/16 O.D. diameter copper tube!!!
So if someone would try to watercool it while the same occasion of a rewind job on the motor that would be nice!
Think about that...:
2 copper tubes with kapton tape skin around that goes inside the hub as for two of the 3 phase wires... and one gauge 10 silicone wire as last phase wire... that make 3 electrical conductor that also are used as liquid circulation!
The 3/16" O.D. copper tube have usually 1/8" I.D. and i found that the waterflow we can achieve with that diameter of tube is still really interesting.
This 3/16" tube could be just used to cary the liquid in and out of the motor.. and inside the motor, we could use larger tube like 1/4" to maximize the overall flow rate...
