HobbyKing SK3s
Re: HobbyKing SK3s
Postby full-throttle » Fri Feb 24, 2012 1:10 am
adrian_sm wrote:Guess I could put one phase in series while I charge a battery.
- measure current
- measure voltage drop
What is the best way to measure it?
4-wire method is the best, you have just described it. As long as the current is steady and the coil doesn't heat up too much. 1~2A is enough to get a good estimate.
Since the motor is delta-terminated phase resistance is 1.5x of what you'd measure. Do you need to account for that Miles?
full-throttle
Re: HobbyKing SK3s
Postby Miles » Fri Feb 24, 2012 1:36 am
It's the phase to phase resistance that you need.
Miles
Re: HobbyKing SK3s
Postby full-throttle » Fri Feb 24, 2012 1:57 am
Of course :oops: hence the sqrt[3] conversion from star to delta..
full-throttle
Re: HobbyKing SK3s
Postby georg2410 » Fri Feb 24, 2012 5:08 am
Hi Miles, Adrian and others
thanks for the awful lots of explanation / information and pictures. I've already calculated / inhaled the physics behind all this, now I'm in the motor selection phase, but there's so many motors which "looks" suitable, so the choice is not easy.
Yes, I also had the 6364 in mind, since you mentioned it already in another thread. And even the Emax/Epower GT6354 sourced by GiantCod/UK looks good, from the specs ;-)
Also, you mentioned EMP's 6374 in this and other thread, but your pictures of that motor (in thread Custom Full Suspension Flatbar Road bike build) look different from EMP's C6374 and N6374 now found on *bay.
Could you tell me which EMP 6374 you got, and when and where you bought it from ?
Thanks
georg2410
Re: HobbyKing SK3s
Postby adrian_sm » Fri Feb 24, 2012 7:24 am
The 6374-200kv used be sold through hobbyking, and was the motor I did most of my testing with. But Hobbyking don't seem to even list it on their site anymore. Others have bought them from LeaderHobby. Looks like the C6374s on ebay like this one
The link is in my post above, but here it is again.
http://www.leaderhobby.com/product.asp?ID=9394001224160
Don't over think the motor selection too much. The main things are get the KV right, and get the heaviest one you can find. This ensure the motor will perform it's task efficiently, and handle any waste heat well.
So:
1) decide on what speed you want to get assistance up to
2) select a motor kv, that still gives you no load speed above your max assistance speed when your batteries are hitting LVC.
3) get the biggest heaviest motor that will fit your build, as this will handle the heat more
4) get a motor with a skirt bearing if you plan on using the motor can as the drive surface, and want >500w power
5) only pick the smaller motors if you have a reason too. ie bigger one doesn't fit.
6) It is not tragic if you get it wrong. It is only $60-100. The rest of your build will cost a shite load more.
Oh and I tend to like to stick to <=6s LiPo. This means you can stick with the cheaper controllers, easier battery pack build & balancing, and you can still get motors of the right kv to give good assist speeds.
- Adrian
Build #1 ~28kg ~ 700w Avanti Hardtail Crystalyte 408, 48V10Ah Headway. ~5500 kms to date. (retired)
Build #2 ~30kg ~2000w Giant AC Dually Crystalyte 408, 48V10Ah Headway + 6s10Ah LiPo = 70V. ~15000 kms to date [SOLD]
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive in Beta testing (www.commuterbooster.com)
adrian_sm
Re: HobbyKing SK3s
Postby adrian_sm » Mon Feb 27, 2012 5:14 am
- measure current
Hope you only wanted ball park figures.
Motor under test:
Turnigy_Aerodrive_SK3_6364_190kv_Brushless_Outrunner_Motor
Method:
I just charged a battery with two of the motors phase connectors used to complete the circuit, and measured the voltage drop across the phase connectors.
Results:
1.0 Amps => 0.030 Volts
2.0 Amps => 0.059 Volts
3.0 Amps => 0.087 Volts
adrian_sm
Re: HobbyKing SK3s
Postby Miles » Mon Feb 27, 2012 5:31 am
That seems close enough to the specification given. Assuming the Kv is actually 190 rpm/V that gives a Km of 0.29 So, a specific Km of 0.42
Miles
Re: HobbyKing SK3s
Postby adrian_sm » Mon Feb 27, 2012 6:01 am
Don't have a tacho on hand, but the previous FFT acoustic analysis was performed on a 5s 20.03V pack @ full throttle, and appears to show a nice peak about where you would expect it at ~3800Hz.
Now I just have to get my head around what Km actually means for me.
adrian_sm
Re: HobbyKing SK3s
Postby georg2410 » Mon Feb 27, 2012 8:55 am
Miles wrote:That seems close enough to the specification given. Assuming the Kv is actually 190 rpm/V that gives a Km of 0.29 So, a specific Km of 0.42
Yeah. That sounds great so far. If the specs seem to be true, I hope this is also valid for the about 21mOhms of the larger SK-6374 149KV.
My target application is:
Friction driven Bike, limited electronically to German speed limitation (about 30kph) only, ignoring the max. power limit of 250W (because this limit seems senseless, especially since the law only refers to a normative continuous motor rating, which is up to the manufacturer anyway - who can seriously believe that a Hub-w/gear from Bafang or Golden which is labeled "250W" is only able to continuously handle 250W at higher speeds ??)
Skirt bearing of course, in order not to kill the motor by the friction drive - method. The larger no-load current is not really important for me, since it should be mainly a hill climbing support for my GF's bike.
System weight about 100 kgs.
Max. slope of hills to be climbed 10-12% with about 6 to 10kph, therefore the wish for KV 149 and not higher.
=> Torque/Current limited electronically to 4Nm / 62A by either ESC or by self-designed separate switched current limiter in front of the simplest cheap 100A ESC.
If needed, (a later stage), lowest speed support by rotary hall-encoder with round magnet on the axis of the motor, with the new single-chip Infineon digital hall encoder with 3-sensor emulation output (if they finally become available ;-) )
georg2410
Re: HobbyKing SK3s
Postby Miles » Mon Feb 27, 2012 9:07 am
That all seems to add up:
Miles
Re: HobbyKing SK3s
Postby full-throttle » Tue Feb 28, 2012 6:52 pm
adrian_sm wrote:Hope you only wanted ball park figures.
Thanks, that's close enough to 29mOhm claimed
Nice motors
full-throttle
Re: HobbyKing SK3s
Postby adrian_sm » Tue Feb 28, 2012 8:04 pm
Oh, and the no load current was 2.04-2.1Amps at 24.4V.
adrian_sm
Previous
Return to Motor Technology
Who is online
Users browsing this forum: No registered users and 3 guests
