#$%@$#@ <--- (insert favorite swearword here), IT WORKS !!!!
Re: #$%@$#@ <--- (insert favorite swearword here), IT WORKS
Postby fechter » Wed Jan 11, 2012 9:20 am
[quote="Lebowski
I don't want to waste my time writing a fance windows GUI interface, plus I like the 80-ies BBS feel of it :mrgreen:[/quote]
I agree. Once you get it dialed in, there should not be much need for tweaking. As long as you can figure out how to enter the parameters properly I don't see a lot of value in a fancy GUI.
Are you planning to have any kind of display?
fechter
Postby Lebowski » Wed Jan 11, 2012 9:31 am
fechter wrote:I agree. Once you get it dialed in, there should not be much need for tweaking. As long as you can figure out how to enter the parameters properly I don't see a lot of value in a fancy GUI.
At the moment there's no setup for a display. There's no reason it shouldn't be possible in a next version though,
there's CAN bus communication so a second controller could ask the motor controller al kinds of questions. First
I'm concentrating on making my bike go :D
What it does have at the moment is RS232 out during motor use. There is 10 to 20 parameters inside the controller
which can be outputted over RS232 at a rate of around 4 kHz. Dependent on which parameter you want to view you
send a letter to the controller. This then starts sending back the 16 bit variable over RS232 to the PC where you can
real-time plot it in a graph (see also the 2nd video of the RC motor, on the laptop screen). It can transmit variables
like e-phase, motor current, control loop variables, effective throttle input, effective PWM amplitude etc etc. Send
another letter and it will output another variable, a letter out-of-range will shut down the RS232. Nifty, eh ?
Lebowski
Postby etard » Wed Jan 11, 2012 10:18 am
Great work Lebowski! I can't believe the redneck in your avatar is the same guy who built this controller, this has got to be the most advanced piece of redneck engineering yet! :lol:
Redneck= good ol country boys, like the one in Lebowski's avatar.
etard
Postby fechter » Wed Jan 11, 2012 10:34 am
With RS232 output it wouldn't be too hard to make something that works on a Palm Pilot or similar to display useful parameters like current.
fechter
Postby Arlo1 » Wed Jan 11, 2012 10:40 am
fechter wrote:With RS232 output it wouldn't be too hard to make something that works on a Palm Pilot or similar to display useful parameters like current.
I have a couple rs232 db9 bluetooth adapters you can stream a wireless serial link to a bluetooth device and do what you need.
I set it all up a couple years ago for my roadrunner I can start it outside and sit on the couch and play with the tuning. I was looking at trying to make it work at the track so I can watch the cars I tune from the pits but bluetooth is not great for that.
Thanks Justin of http://www.ebikes.ca/
Also a thanks to Methy at http://www.methtek.com/ :)
And Dave who has some good deals on STUF
RC lipo and most other types of Lithium batteries you MUST know your individual cell voltages while charging and discharging.
Batteries of all kinds need respect they can burn your house down, so don't sleep with them under your bed or any other were you cant afford smoke or fire!
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Postby Hugues » Wed Jan 11, 2012 10:48 am
etard wrote:Great work Lebowski! I can't believe the redneck in your avatar is the same guy who built this controller, this has got to be the most advanced piece of redneck engineering yet! :lol:
Actually there are 2 persons on the avatar picture, Lebowski could also be the woman :shock:
Hugues
Switzerland
Mountain bike
XC-204 -> Crystalyte HT3525/Infineon ctrlr 40 A EB712XC board/LiPo 88 V 10ah
All Terrain Vehicle
Hanebrink -> Crystalyte HS/Infineon ctrlr 20 A/Allcell Li-ion 36 V 10ah
Motor bike Cruiser
My build thread here
Hugues
Postby parabellum » Wed Jan 11, 2012 12:53 pm
There is video on page 5 where you can see Lebowkis reflection in the screen, definitely not the guy on the avatar! :D Thanks God!
parabellum
Postby Lebowski » Thu Jan 12, 2012 4:19 am
ctirad wrote:Do you plan to make it comercially available some day?
That would be nice :D I don't know about selling complete controllers though it is an attractive
possiblity... At the moment I'm still finishing up the program, after that I'll send chips to people
that want to do beta testing :)
Because I'm also working on this for my own personal bike I'll make a sort of 'reference' design,
I'll post a schematic for how to build a controller with the 30F. This can be used to see how the
30F should be connected (if you want to plug it into an existing XieChang controller) or can be
used to build a controller from scratch. Just ordered $150 worth of 30F's, 4115's, NCP5181's,
20A versions of the ACP714's etc etc on digikey :D
Because of all the configurable variables and options in the controller I'll also write a sort of
manual explaining all the parameters, suggesting values and equations for calculating them.
The suggested equations for the parameters are basic (so if you just want to ride you'll have
no problem setting it up correctly) but allow room for your own experimentations as well.
Just a tip, I went to the town recycling centre last week to get rid of some paper and cardboard. I had
a dig through the electronics bin and found a 100-240V to 16.6 V / 2 Amps laptop charger. I tried
it on 65 V DC and it worked fine. I'll use this on my bike to go from 96V (ping) down to 16.6V
to power the PIC (via 1 Amp version of 7805) and FET drivers.
Lebowski
Postby Lebowski » Thu Jan 12, 2012 4:30 am
parabellum wrote:There is video on page 5 where you can see Lebowkis reflection in the screen, definitely not the guy on the avatar! :D Thanks God!
I do play some banjo though ! :shock:
or at least I did 7 years ago...
Lebowski
Postby markobetti » Thu Jan 12, 2012 5:08 am
Lebowski , i sent pm to ya.. Please check
markobetti
Postby whatever » Thu Jan 12, 2012 8:04 am
so running sensorless after startup would mean the timing adjustment tool on another thread would not be required, you would be running at ideal timing
no matter the rpm?
whatever
Postby Lebowski » Thu Jan 12, 2012 8:12 am
whatever wrote:so running sensorless after startup would mean the timing adjustment tool on another thread would not be required, you would be running at ideal timing
no matter the rpm?
Yep, that's the idea
Lebowski
Postby c_a » Thu Jan 12, 2012 10:07 am
At 6.000rpm you have 100 revs per second or 10ms per rev.
If the controller needs 100us (how much is this in reality?) for input, processing and output you have an angle failure of 3,6° with a 30P rotor (one pole each 12°) the failure is... ?
c_a
Postby Lebowski » Thu Jan 12, 2012 10:42 am
c_a wrote:At 6.000rpm you have 100 revs per second or 10ms per rev.
10msec per (mechanical) m-rev, 30P -> 10msec/15 = 666 :twisted: usec per e-rev.
input, processing, output takes around 10 to 12 usec -> once every 6.5 degrees of an e-rev....
Your output stage though needs to be able to handle at least 40 to 50 kHz PWM (the 30F
can update it's dutycycle 2 times per PWM period, dutycycle is allowed to change
between rising and falling edge)
With my background and work experience, I could do an FPGA version to go much, much faster :mrgreen:
Lebowski
Postby whatever » Fri Jan 13, 2012 6:01 am
came across this site
http://urun.gittigidiyor.com/elektronik ... p-39337642
seems an lcd screen setup to go with 30f chip ( no idea what language or country its in)
excuse my lack of knowledge on this, but would it be possible to reprogram an xie-cheng chip to do the same as you are doing? is enough known on the xie-cheng chip
another link here referring to lcd with 30f ( i'll delete if not relevant)
http://320volt.com/dspic30f4011-ile-glc ... -analizor/
whatever
Postby whatever » Fri Jan 13, 2012 6:14 am
not sure if these diagrams are useful, but seems to be a 30f chip,
from this site
http://www.go-gddq.com/html/PICDanPianJ ... 551855.htm
( i'll delete this post if not relevant: let me know)
whatever
Postby whatever » Fri Jan 13, 2012 6:28 am
one more
http://140.116.40.178/mfhsieh/ch/en/study_02.htm
last one.jpg (74.88 KiB) Viewed 494 times
whatever
Postby Lebowski » Fri Jan 13, 2012 7:05 am
the diagrams show a standard motor controller setup.. I don't think it's the xiechang circuit, the
diagrams from Markobettishow a gpm8f3108 chip....
Lebowski
Postby markobetti » Fri Jan 13, 2012 7:14 am
Yes, the new xie chang boards use new chip. Old boards older chip. We for example have those boards with bigger chip and thats their new standard
markobetti
Postby Lebowski » Fri Jan 13, 2012 7:37 am
markobetti wrote:Yes, the new xie chang boards use new chip. Old boards older chip. We for example have those boards with bigger chip and thats their new standard
there's a lot of 8's in the name of the chip, is it an 8 bit ? I can't find any datasheet for it.
Lebowski
Postby whatever » Fri Jan 13, 2012 9:38 am
theres a paper
Design and control of a multilevel inverter for electric vehicles
Arthur W. Matteson, Michigan State University
uses the 30f might be worth a read if anyone can find a copy on the net
whatever
Postby whatever » Fri Jan 13, 2012 9:40 am
new xie cheng chip was 'in-house' apparently
whatever
Postby Arlo1 » Fri Jan 13, 2012 10:20 am
whatever wrote:theres a paper
We already have this going on my thread. See not simple BLDC controller.
I just switched from a dspic30f3010 to a dspic30f4011 mostly for the extra pins for more fetures but also because its more powerfull.
The reason I made it "multylevel" is because I want to be able to swap fets and not have to worry about a fet blowing and making a mess out ot the Brain stage.
I also figure this was I can build a little 6 fet for a bicycle or a multi fet monster for a motorcycle or can and use the same brain design, or even the same brain with a quick reflash!!
Arlo1
Postby Lebowski » Sat Jan 14, 2012 2:48 am
whatever wrote:new xie cheng chip was 'in-house' apparently
Hmmm, that would be something, to turn my algorithm into a custom IC....
This is actually my profession :mrgreen:
Lebowski
Postby Lebowski » Sat Jan 14, 2012 4:41 am
busy adding the menu's for all the variables.
this is for PWM :
Code: Select all
1) PWM frequency: 21kHz
2) deadtime: 499ns
3) dutycycle testsignal: 50%
4) toggle high side polarity, now active HIGH
5) toggle low side polarity, now active HIGH
8) test PWM signals
9) return to main menu
options 4 and 5 are to adjust whether the controller gives out a logic 1 or 0 to turn
the output stage FETs on. A XieChang has active LOW for the high side FET and
active HIGH for the low side FET. Someone (like me) using NCP5181 drivers
needs both active HIGH.
Code: Select all
1) current sensor transimpedance: 3.32 milli-Ohm
2) maximum motor phase current: 600.0 A
3) maximum battery current, motor use: 350.0 A
4) maximum battery current, regen: 50.0 A
5) maximum shutdown error current, fixed: 10.0 A
6) maximum shutdown error current, proportional: 5.0 A
7) error current filter coefficient: 5
Above is the currents setup menu for a high power setup (600 amp sensors as C_A wants
to use), for my testing I use something much more moderate
Code: Select all
1) current sensor transimpedance: 100.00 milli-Ohm
2) maximum motor phase current: 4.0 A
3) maximum battery current, motor use: 1.5 A
4) maximum battery current, regen: 0.0 A
5) maximum shutdown error current, fixed: 0.1 A
6) maximum shutdown error current, proportional: 0.0 A
The resolution of the currents is 1/32 of an Amp and can go up to 2047 Amps.
Should be enough I think :D
Lebowski
PreviousNext
Return to Motor Technology
Who is online
Users browsing this forum: No registered users and 4 guests
