#$%@$#@ <--- (insert favorite swearword here), IT WORKS !!!!
Re: #$%@$#@ <--- (insert favorite swearword here), IT WORKS
Postby c_a » Fri Jan 20, 2012 4:01 pm
We need a quick solution because my 135-50 inrunner is on the way:
http://www.powerditto.de/monster.html
We will run it at 24s lipo @450amps = 40kW :lol:
c_a
Postby c_a » Fri Jan 20, 2012 4:18 pm
c_a
Postby Arlo1 » Fri Jan 20, 2012 4:23 pm
c_a wrote:We need a quick solution because my 135-50 inrunner is on the way:
Good luck man i have needed something fast for 2 years!!! :)
Thanks Justin of http://www.ebikes.ca/
Also a thanks to Methy at http://www.methtek.com/ :)
And Dave who has some good deals on STUF
RC lipo and most other types of Lithium batteries you MUST know your individual cell voltages while charging and discharging.
Batteries of all kinds need respect they can burn your house down, so don't sleep with them under your bed or any other were you cant afford smoke or fire!
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Postby Arlo1 » Fri Jan 20, 2012 4:24 pm
c_a wrote:Is one enough or should I buy two?
http://www.mitsubishielectric.com/semic ... u-3a_e.pdf
You will be lucky to get 1/4 there rating so... Get 6. How much are they?
Arlo1
Postby c_a » Fri Jan 20, 2012 4:34 pm
I trust in mitsubishi spec sheets, found them for 347€ each in germany. I really like the big blocks :D
c_a
Postby bearing » Fri Jan 20, 2012 4:40 pm
Do you know if anyone have used those for high frequency switching? They have a pretty big gate capacitance, so you'll need a stiff gate drive.
Spec says it can handle 1kW of losses, but since thermal resistance is 0.1°C/W, that means the junctions will be 100°C above case temperature. So, I don't think you can use them close to their power rating.
I wonder if every "transistor" is made of several chips in the "normal" power mosfet size, or if it's one giant chip per transistor.
bearing
Postby Arlo1 » Fri Jan 20, 2012 5:16 pm
c_a wrote:I trust in mitsubishi spec sheets, found them for 347€ each in germany. I really like the big blocks :D
IR and ixys have the best fets most have us have tested so far and their spec sheets are very optimistic. Remember when the fet is on it can only touch the max ratings then you have to turn them off and wait till the current falls enough so you can turn them on again so you wont see 300 amps 150 v from each unit more likely ~80amps at ~130v each unit and thats 80 phase amps!
Arlo1
Postby Arlo1 » Fri Jan 20, 2012 8:43 pm
bearing wrote:I wonder if every "transistor" is made of several chips in the "normal" power mosfet size, or if it's one giant chip per transistor.
I took some big ixys fets apart and they were 8 smaller fets inside.
Arlo1
Postby Lebowski » Sat Jan 21, 2012 3:37 am
bearing wrote:
Lebowski wrote:the third sensor makes it possible to compensate for the common-mode voltage offset (which may be temperature
dependent)
These Allegro sensors (at least the bigger ones that I have been playing with) have a built in ferrite core. Remanence in the core makes the voltage at 0 amps differ from 0.5Vdd. If the last direction of magnetization was positive, sensor will output some mV in the positive direction at rest. This makes it hard, or maybe even impossible, to measure small currents. If you are integrating current over time (like I did) it will accumulate to a big error.
The small Allegro current sensor work in the same way as the big ones. I'm not integrating currents over a long time so it's not a big issue, it's more that I want to build the best controller IC possible, and for this reason I am considering adding the option to use 3 current sensors. It adds the cost of a 3rd sensor but makes it more robust against (drifting, maybe temperature dependent) offsets. The effect of offset is that, because the throttle is current based, at throttle closed you get a tiny bit of either regen or power. Not a big issue but something I want to fix.
Lebowski
Postby Alan B » Sat Jan 21, 2012 9:14 am
Phase currents are AC so compensating for DC offset should be possible.
Alan B
1.21 GW
1.21 GW
Postby Arlo1 » Sat Jan 21, 2012 10:23 am
Lebowski I was thinking I was going to put a current sensor in each phase wire anyway I just wanted them to be ballanced.
Arlo1
Postby Lebowski » Sat Jan 21, 2012 2:32 pm
Alan B wrote:Phase currents are AC so compensating for DC offset should be possible.
I thought about that one. It is possible to run a low pass filter and get the DC offset. Another possibility
would be to run a calibration routine where you make sure all FET's are off (so no phase current)
and measure the DC offset.But I realised going the 3 current sensor route actually has the additional
advantage of also eliminating high frequency noise common in all 3 sensors.
Imagine, the current sensors are in the motor phase lines. all the PWM signals are generated
by the same source meaning that there will be instances where all high side FETs and at other times
when all low side FETs are on. The voltage on the current carrying path of the sensors goes up and
down by about 100 V (I'm planning to run 100V battery). The isolation from current input to voltage
output is not specified but is not going to be an infinite amount of dB. Another sources of noise
which 3 sensors can compensate for is ripple on the 5V supply.
Something else which speaks against using just 2 sensors it that in this case the 3rd motor phase current
is compute as the negative of both other currents combined. So this computed value is going to carry
the combined error of both sensors. While with 3 sensors part of the error is common to all 3 and will
be cancelled out in the 30F.
If you're not versed in analog design it might all sound complicated and stuff but differential signal
processing is very common in integrated analog circuits...
I just ran the motor with 3 current sensors, results are excellent. The 30F will have a menu option
where you can chose 2 or 3 current sensors. For the case of 2, there'll be a small potentiometer
in the schematic that will need to be calibrated. The main difference between 2 and 3 sensors ?
2 sensors will result in a bit less accurate control when motor rpm and currents are low (so low
motor speed and low throttle). Any other case there won't be much of a noticable difference (maybe
some small amount of torque ripple in the 2 sensor setup, but there are coefficients that you can adjust
to reduce this)
Engineering pride though requires me to strongly recommend 3 current sensors :D
Lebowski
Postby Lebowski » Sat Jan 21, 2012 2:40 pm
Arlo1 wrote:Lebowski I was thinking I was going to put a current sensor in each phase wire anyway I just wanted them to be ballanced.
Good thinking... But looking at my own motor, there's so much variation in magnet strength between the magnets
that in practise you probably won't notice the missing current sensor in 1 motor phase... In my case beer was consumed
during the motor's construction, not all motor phases have the same amount of windings :oops:
Lebowski
Postby Lebowski » Sun Jan 22, 2012 5:40 am
independent auto calibration added to the 2 current sensor setup :D
This removes the need for voltage calibration with a small potentiometer,
this simplifies the schematic and removes the need for accurate voltage
measurements / adjustments.
Lebowski
Postby Lebowski » Mon Jan 23, 2012 2:06 pm
Been very busy adding more and more menu options. So much in fact I'm starting to get lost :oops:
this is the main menu:
Code: Select all
a] calibrate hall sensors
b] determine coil positions
c) PWM parameters
d) current settings
e) control loop parameters
f) throttle setup
g) running modes
h) CAN bus setup
z) store parameters in EEPROM for motor use
this is the 'running modes' submenu
Code: Select all
a) sensored or sensorless: SENSORED
b} sensorless startup: PUSH START
c} e-rpm limit sensorless self start: 999
d} e-rpm reached before transition: 89 %
e} minimum current push start: 0.9 A
f} push start current, error allowed: 20 %
g] erpm sensored to sensorless transition: 500
h] transition time sensored to sensorless: 249 milli-sec
i) return to motor start below 200 erpm
j) motor maximum: 6.99 k-erpm
k) motor standstill voltage threshold: 1.49 V
z) return to main menu
Some menu's have gotten so long that I've decided to switch all to letter instead of numbers. Also every option
is indicated by a ']', '}' or ')', the meaning is:
]: option only used for sensored
}: option only used for sensorless
): option used for both sensored and sensorless
This week I hope to be able to start drawing the schematic....
Lebowski
Postby Arlo1 » Mon Jan 23, 2012 2:10 pm
6.99k erpm max??? Thats only 699rpm for colossus....
Arlo1
Postby Lebowski » Mon Jan 23, 2012 2:29 pm
Arlo1 wrote:6.99k erpm max??? Thats only 699rpm for colossus....
These numbers are for my own motor, you can type whatever you want here. This
particular entry I think goes up to 255.99k and is not limited by the controller algorithm
but by the computation which takes the number you enter and transforms it into the
16 bits integer the algorithm uses. Is there a need to go higher than 256 k-erpm ?
Lebowski
Postby Farfle » Mon Jan 23, 2012 2:37 pm
The joby motors are some insane E-rpm iirc, but I cant find it.
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 318A at 91v
Peak power out: 24 Hp and 151ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Farfle
Postby Arlo1 » Mon Jan 23, 2012 2:43 pm
I doubt it but colossus will need <100KERPM so we are good!
Arlo1
Postby mauimart » Mon Jan 23, 2012 3:03 pm
Farfle wrote:The joby motors are some insane E-rpm iirc, but I cant find it.
From the Joby thread it appears we are looking at 26 pole pairs. That's 9800 mechanical rpm with the 255k-erpm. Seems like that will do...
mauimart
Postby c_a » Mon Jan 23, 2012 5:17 pm
I need only 5,000mrpm @ 15 polepairs = 75,000erpm or 1,250Hz field frequency :D
c_a
Postby Lebowski » Thu Jan 26, 2012 4:36 am
I'm busy now adding reverse for if someone wants to build a multi-motor car type vehicle. :D
Is kind of nasty as this also has to work over CAN bus and has to check motor speed
as we don't want to change direction on a fast spinning motor. I think I'll make it such
that when a controller receives a 'change direction' request it cuts the power and
only accepts regen until motor speed is low enough to change direction.
When you got all kinds of features adding an extra one isn't simple anymore :D
Lebowski
Postby Miles » Thu Jan 26, 2012 5:11 am
:D For my needs, the quicker the changeover, the better.....
Miles
Postby whatever » Thu Jan 26, 2012 7:25 am
seems controllers with reverse also limit the max speed in reverse...more complexity
whatever
Postby Lebowski » Thu Jan 26, 2012 7:30 am
whatever wrote:seems controllers with reverse also limit the max speed in reverse...more complexity
Now that I think about it, good point, could be a safety hazard if it's not limited to a lower e-rpm than
forward. It's only 2 additional instructions anyway...
Lebowski
PreviousNext
Return to Motor Technology
Who is online
Users browsing this forum: bearing and 5 guests
