Lebowski wrote:
20661 bytes filled using assembly
And how many megabytes if you had coded in C?
Alan B wrote:And how much work to port it to the ARM CPU?
Lebowski wrote:I would actually like to port it to ARM, I would like to learn ARM assembly.
Problem is that I have a soldering station from the 1960's and cannot
deal with SMD's or very small chips.
ctirad wrote:Lebowski wrote:I would actually like to port it to ARM, I would like to learn ARM assembly.
You should consider to write in C. It will make the code much more transparent and portable. The speed loss is minimal and you allways can inline assebly routines for better speed when needed.
BTW, I'm not sure, the ARM is generally better option than dsPIC or another MCU/DSP dedicated for motor controll tasks. However, If you want to try ARM, look at STM32 line of chips.Problem is that I have a soldering station from the 1960's and cannot
Don't worry, SMD is easy to handle even with a plain micro soldering iron. I commonly use mine even for FPGAs, bigger MCUs and so. The real problem is BGA.
Arlo1 wrote:We have been bugging lebowski to write in C for months and he is to stubborn lol. Im learning it its not easy but it does seem better in the long run!
pelle242 wrote:The portabilty of Lebowskis code i mostly academic for now. What are your intentions for it? Keep it your personal baby or open source it and let others contribute? Just curious...
Lebowski wrote:And yes, it's too late to change nowI just programmed the devices to send around, going in the mail tomorrow.
Users browsing this forum: No registered users and 5 guests
