Like the Vectrix?damcard wrote:I always wanted a half twist throttle that lets you not only twist back for acceleration, but forward for reverse/variable regen. Just thought it would be cool. -Damcard.
bigmoose wrote:edit: I missed a part in my original comment. Removed comment as it is not accurate. Sorry Arlo!
But I think I caught something new. Mind the data sheet, particularly page 3 and figure 12B and 13B. If you feed Vdd with 15 volts you will move the input logic levels up above the 5V range. You want to power Vdd with 5V and Vcc with 15.
liveforphysics wrote:bigmoose wrote:Two nice things about the sin/cos sensor:
- It get the position sensing element out of the stator heat flux
- It allows precise timing advance with the right controller just like a timing map in an IC ECM
Yes sir it does. We did it mainly for the heat reason you mentioned, as hall melting failure was our demise at the last race event, as well as a previous race.
The second reason you mentioned wasn't really something we were needing for this application, but WOW! It just make it silky smooth, no more chug-chug-chug at low RPM's as each hall sensor latches and tells the fets to switch the next coil on, it's just silky now, you can make the motor spin so slowly you can barely see it moving at all, and it's just perfectly smooth with no torque ripple noticed at all now. Really feels like electric power should feel at all RPM's rather than little bumps of torque pulses when you're at low speeds.
It's fun having this much torque too, I just nosed the front wheel up to a staircase outside a strip mall, and in a very slow controlled calm way, just torqued up the 10 stairs or so and rode along the sidewalk path at the top. It felt even easier than walking up stairs, though the seat does kinda smash into your ass as the rear tire goes over each step. I don't know that it would have been possible to do it so effortlessly on hall sensors.
MitchJi wrote:Hi,
How difficult would it be and how beneficial would it be to add the capability of accepting input from sin/cos sensors, in addition to hall sensors? Seems like a good match for this project because the sin/cos sensors work better at low speed:
http://endless-sphere.com/forums/viewtopic.php?f=28&t=34628&p=503866
MitchJi wrote:How difficult would it be and how beneficial would it be to add the capability of accepting input from sin/cos sensors, in addition to hall sensors? Seems like a good match for this project because the sin/cos sensors work better at low speed:
Lebowski wrote:I don't see any benefit in using sin/cos sensors.
- whatever position sensor system you use, it will always be as accurate as the person whole placed it.
- under load timing will always be wrong as timing depends on many things, only (hall-) sensorless can have perfect timing.
- I make the transition to sensorless around 60 to 120 e-rpm anyway.
It would be nice to have completely a perfectly smooth motor starting up, when its "spin[ing] so slowly you can barely see it moving at all" all the way up to perfect timing at WOT. I assume when Luke says "WOW!" about low speed performance it must be pretty nice, since its not an issue he is normally concerned with. So it seems like its potentially an excellent combination, great low speed and great high speed performance.liveforphysics wrote:The second reason you mentioned wasn't really something we were needing for this application, but WOW! It just make it silky smooth, no more chug-chug-chug at low RPM's as each hall sensor latches and tells the fets to switch the next coil on, it's just silky now, you can make the motor spin so slowly you can barely see it moving at all, and it's just perfectly smooth with no torque ripple noticed at all now. Really feels like electric power should feel at all RPM's rather than little bumps of torque pulses when you're at low speeds.
It depends on which one you use. They are available with digital outputs (both of Todd's links have options with digital outputs):Lebowski wrote:And, not unimportant, I already used all the analog inputs (all 9 of 'm)I'm assuming its an analog-out sensor?
Thud wrote:I am pretty certain they grabbed an off the shelf rotary encoder for reading position. a quick google brings up several that could be employed with a little creativity:
http://www.quantumdev.com/products/optical_encoders/sc12.html
http://ab.rockwellautomation.com/Motion-Control/Sine-Cosine-Absolute-Encoderquantumdev wrote:Output Circuits
(A) Sine/Cosine, Index & RS422 UVW (TTL Compatible)
(B) Sine/Cosine, Index & UVW Open Collector
Alan B wrote:So thinking about this I agree with you - sin/cos encoders are probably not worthwhile to worry about at this point - but I also suspect that getting sensorless operation to be perfect seems to be more difficult than expected and I don't think we've seen any controllers yet that have succeeded. I wonder if Justin of ebikes.ca's sensorless operation is without problems... Burtie's timing advance unit seems to have difficulties as well, but he is working through them. Perhaps it only takes a couple of years of tweaking to get it right.
So what do you think - is your sensorless control algorithm having or going to have regions of difficulty?
Lebowski wrote:I looked at the links of the sensors, the difficulties I see are...
I feel for high power and difficult motors (any motor) sensorless is the only way...
recumpence wrote:#1 If you are talking about a sensorless controller, good luck. MANY people have tried and it would be tough to improve on the Castle Creations controllers we are using for sensorless RC stuff. It is not impossible, but would cost a lot to do. Sensored is another thing altogether.
whatever wrote:what are the reasons for changing from halled to sensorless once the motor is running?
Users browsing this forum: Google [Bot], J-aprilia-N and 5 guests
