Good! Someone finally oil cooled a hubbie!! HS3540
Re: Good! Someone finally oil cooled a hubbie!! HS3540
Postby hjns » Sat May 05, 2012 11:41 am
dfar wrote:On my other motor I run regen braking so I don't use a back brake caliper so no worries about clearance there.
Hmm. I use regen AND a disc brake. I find that my regen braking just does not cut it in case of an emergency brake. In such a case, I want both my front and rear hydraulic calipers to be fully engaged in providing the maximum braking without blocking.
Henk
High speed commuter w/ modified Lyen 18 FET 4110, 12AWG traces, extra Caps, beefed up shunt, modified Cromotor w/ thermistor, 10AWG phase wires. CAv3B22 with power-throttle limited to 8kW and 130oC motor winding temp, w/ GPS-enabled CA analogger. 20S 13.5Ah Lipo Zippy pack. Fusion FS frame, Fox RL rear shock, Fox F100 front fork, Schwalbe Fat Bob tires, HALO SAS 26inch rims with custom 12G(r) and 14G(f) black Sepim spokes from JRH and laced myself.
Commuter Cromotor build
hjns
Postby amberwolf » Sat May 05, 2012 1:58 pm
John in CR wrote:AW,
I hope I can count on you for the needed test info pervasively lacking, which is with and without oil no-load current and no-load speed. It will be important for determining optimum fill levels. I think the warmish covers is good in your test so far, but that's as long as much of the heat isn't new.
That's part of what I was going to start doing last night, but all the little issues ate up my time and I didn't get teh chance. So these will be done next chance I get to work on this project, when I have the sealant for the axle and the temperature sensor to install.
I can say that no load current appeared normal, from what I can remember of previous testing, but I need actual numbers at specific speeds to be sure, and to see any small differences that come up, which will affect efficiency (and thus heat).
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby amberwolf » Sun May 06, 2012 2:02 am
FWIW, I did a little test overnight: I took some of the dried-up rubber cement off the outside of the lid and bottle, and left it soaking in a capful of ATF. Today before I left for work, about 13 hours after doing that, there was only liquid in the cap. ATF most definitely completely dissolves rubber cement, even if it's been dry for months!
So don't use it to seal an ATF-filled motor. :lol:
amberwolf
Postby Xanda2260 » Sun May 06, 2012 2:55 am
Now that's cool. Eagerly awaiting further results AW,
Cheers
The White Warrior - viewtopic.php?f=6&t=33918
Homebuilt 40mph+ tadpole!
Xanda2260
Postby dfar » Sat May 19, 2012 10:43 pm
kids this is good advice, :wink:
dfar
1 W
1 W
Postby John in CR » Sun May 20, 2012 8:16 am
It depends on the rig. I run regen as the only rear brake on my SuperV, and at 5.5kw peak braking it test the limits of traction. The only time I miss a rear mechanical brake on that bike is at very low speeds where there is no regen braking. On my cargo bike I run throttle activated regen with a very gentle stopping force, so yes that bike requires a rear brake.
John
John in CR
Postby Andje » Sun May 20, 2012 8:23 am
I feel like skidding my rear tire in an emergency does not compare to instant full regen of about 5000w. I doubt my calipers can absorb 5000w as efficiently as my motor.
Norco 125 Dirt Jumper
100v 15ah Lipo Backpack
lyens 18 fet, 100v 100 amps, R12 Regen
x5304- 95km/h
http://endless-sphere.com/forums/viewtopic.php?f=3&t=24594
Norco A-Line Park 2009
144v Kelly 300amp
5403/ future HS60
http://endless-sphere.com/forums/viewtopic.php?f=6&t=35652
Andje
Postby hjns » Sun May 20, 2012 11:51 am
Andje wrote:I feel like skidding my rear tire in an emergency does not compare to instant full regen of about 5000w. I doubt my calipers can absorb 5000w as efficiently as my motor.
Agreed. However, in an emergency stop, I use both regen AND calipers. The regen will bring me back to 20kmh only. Also, adding the brake force of my hydraulics to the regen allows for an even better controlled stop. And yes, of the 6kW power, 5kW may be produced by the regen, and another 1kW by my calipers, which is very nice.
Henk
hjns
Postby The Stig » Tue Apr 09, 2013 12:33 am
Well it sounds like the NZ geeks are having some luck with this oil cooling thing
http://www.ev.geek.nz/viewtopic.php?f=32&t=162&sid=7c6fe6e8b7a1a2f8e8879728ce4247fd&start=150
Anyone tried this with a 9C or MAC?
Last edited by The Stig on Tue Apr 09, 2013 12:34 am, edited 1 time in total. View post history.
The Stig
PreviousNext
Return to Motor Technology
Who is online
Users browsing this forum: No registered users and 5 guests
