I don't know what you mean with laminations, is that the laminated iron core of the coils ?
The motor I built myself is also an axial flux, I have no iron in it which makes it possible to spin
this motor using only 30 milli-Watts.
I've thought about adding iron, what I would do is get plastic coated iron wire (like they sell at the garden center
for tying up beanstalks). I would wind this (soaked in epoxy) to the desired shape / diameter. I think this
would be a very good design for having low eddy currents, there is no continues loop except within a
sideways cross section of the wire. But because it's wire the sideways cross section would be very
shallow...
A mayor disadvantage of iron core (and the reason why I don't have it) is that the two magnet
plates in my design would attract each other with a lot of force making it almost inpossible
to take it apart again. Currently (with the 7 mm airgap) the force is about 100 kg, taking it
apart requires a bearing puller type tool but is still possible...
About airflow to cool it, with mine there is a detectable flow of air being sucked in the core
and flying out inbetween the magnet plates and coils (flow due to centrifugal force).
I already got the magnets and a second coil plate prepared for a dual layer design but at the moment
I'm concentrating on getting my controller IC finished....
- DSC00299_scaled.JPG (148.47 KiB) Viewed 299 times
