markobetti wrote:Dear Miles, the gearbox isnt published at ES ? Its okay if its a secret , but if not please post link since i havent been able to locate it. i remember you and hal discussion about retro direct drive ....but thats not it right ?
Thanks! They didn't do a trial version before - now they do.markobetti wrote:Maybe you can try your calculations in trial version if they have it :
http://www.infolytica.com/en/products/
http://www.infolytica.com/en/applications/ex0072/
Ken,kenkad wrote:miles
This is what I meant by vertical laminations, bent into a 'C', stacked, to produce a trapezoidal end. It seems to me that the flux path out the end is now distributed. I used different colors for the lam layers to better see the result. I have never seen a sim of this, but have always wondered why this is not done.
Wow! That's nice Marko. Look forward to seeing what it's intended for....markobetti wrote:Glad to be a service to you. You helped me alot, for example with freewheel . Finally made indestructible freewheel with two bearings inside al 7005 mat. and more pawls than any freewheel on the market i can think of. http://img217.imageshack.us/img217/326/heavymetalx.jpg . Logo is covered with white color due to my project that is in state not intended to be shown right now under the name. Anyways , thank you MILES
kenkad wrote:This is what I meant by vertical laminations, bent into a 'C', stacked, to produce a trapezoidal end. It seems to me that the flux path out the end is now distributed. I used different colors for the lam layers to better see the result. I have never seen a sim of this, but have always wondered why this is not done. My preference would have been to do this as a powdered core so that the center could also be trapezoidal, providing a better motor fill with a split copper strip winding like Shane did in one of his motor experiments. I hope this explains my question to everyone. As to why the more than one 3-phase group question. That is because starting torque requirements to get a vehicle moving are greater than running torque requirements at a speed, so I would op to turn off a 3-phase group to reduce motor power consumption since I do not believe the cogging would be noticeable at speed, momemtum effects.
Lebowski wrote:I looked at it from a different angle... In my opinion you need to convert
electrical power efficiently into mechanical power, independent of whether
you want to race uphill or just ride around on the flat. Core laminations help
with efficiency but only in a certain rpm range (too low rpm -> cogging,
too high rpm -> eddy current losses). No iron core gives a lower specific
torque but this can be solved by chosing a different gear ratio so I wouldn't
say this is a disadvantage of having no iron core.
For me in the end the efficiency with no core was good enough, the disadvantages
of the iron core outweighed its advantages.
kenkad wrote:I am not a motor designer. If a wedge shape core end is not beneficial, why should wedge shaped magnets be used on the rotor instead of rectangular shaped magnets. It has been quite a while since I spoke with people involved in powdered cores, but, it seems I recall that there is an orientation process in making cores like this. I dropped the whole design issue because in talking with companies and universities about sim software, I was told the software was not sophisticated enough to deal wtih these questions. That was more than two years ago and I have not checked if there are any improvements. This is why I am now asking the question.
Miles wrote:Next decisions:
How many slots? 18, as modelled or I could possibly reduce it to 15?
How many poles?
But they will affect the amount of copper in the links between coils... If I used 15 slots and 14 or 16 poles, most of the coils could be linked to their adjacent partner, I think. As I'm intending to use rectangular copper strip and the connections are outside of the case this would be an advantage...Lebowski wrote:These choises have no effect on efficiency... just make sure the motor is physically big and has lots of copper in it.
Miles wrote:But they will affect the amount of copper in the links between coils... If I used 15 slots and 14 or 16 poles, most of the coils could be linked to their adjacent partner, I think. As I'm intending to use rectangular copper strip and the connections are outside of the case this would be an advantage...Lebowski wrote:These choises have no effect on efficiency... just make sure the motor is physically big and has lots of copper in it.
Need to find out the trade-offs WRT the winding factor?
Thanks bearing. That's a very good point. I guess the "unbalanced" rotor/pole combination would be noisy, too...bearing wrote:I don't think a stator with 15 teeth is going to work well. With 14 or 16 poles, windings will, as you say, be put in groups of 1/3 of the diameter. Every time a phase pair is energized it will "bend" the rotor(s) and shaft. See the summary at the bottom of this page: http://powerditto.de/15N14P.html
It might work better with an axial design with small diameter, but I would personally avoid it.
Lebowski wrote:What is a winding factor ?
18t and 20p (winding factor 0.945) seems the best solution for me, I think. I'll see what a 12t layout looks like, though.bearing wrote: To solve this "imbalance", use twice as many teeth, which will put windings in two groups, on opposite sides of the centre.
Users browsing this forum: j3tch1u and 3 guests
