The insulation thickness values seemed quite high, too. But with only 3 turns x 2 .......rhitee05 wrote:8mm x 1mm is pretty hefty stuff - comparable to 8-ga round wire. Bending radius could be an issue - you'd probably need to round the edges of the lam stack to accommodate it. Definitely suitable for a high-current motor, though...
Thanks Eric. That would be very useful. I'll model up the stator modules properly for 12t and 18t layouts.rhitee05 wrote:If you want to provide me with some of the dimensions you're looking at, I can toss together a quick FEMM model as a place to start considering some of the tradeoffs.
Miles wrote:Reworked 18t stator:
Still wondering if there would be a significant advantage in using grain-oriented steel (up to 30% higher flux density but usually has a lower silicon content than non-oriented)?
I don't either Marko.markobetti wrote:i dont see a point why not to make laminations : use 0.35mm or 0.2 mm soft silicone steel No. 250#.
winding wire perhaps : type(at least): Enameled wire, No. 2UEW, grade: F, internal resistance: 0.0087Ω
Users browsing this forum: Doctorbass, h0tr0d, steeeve and 1 guest
