Lebowski wrote:At the moment I'm finishing my bike build (maybe this coming 4-day weekend), after that
I want to make a 16x10 cm PCB containing a full 6 FET (hopefully TO247) controller
(including 100V or 150V to 18V/5V supply, controller IC, proper gate drivers and output stage).
For a 1 motor bicycle you then only need to connect analog throttle, the battery, the
3 motor wires and optionally the 5 hall sensor wires.
I think a PCB will make it very easy for everyone to build a controller. Just order the parts
from digikey (I will try to make a parts list), solder everything to the PCB, setup the controller
IC with your laptop and your vector based, sinewave out with automatic timing compensation
controller is done !
If the 6 FET proves itself I'll do a 12 FET or more version if there's a demand for it.
Lebowski wrote:Or, you know, I'm
scared to think what would happen if this 30 kg (65 pounds) piece of metal
is spinning at high rpm and breaks lose of it's two tiny 6mm mounting bolts...
Arlo1 wrote:What transistors would you sugest? I have 2n3904, 2n3906, 2n5061, and n43al lm293 iaz-5 (think its called a lm 293) in stock Would any of those 4 work?
Lebowski wrote:The next step for my controller is to make a PCB containing everything, I think once that's done it's
at a stage where a soldering iron and multimeter should be enough. At that point it's just a matter
of ordering a list of parts from Digikey, solder everything in the right place and set it up with a PC.
No clue though how long designing the PCB will take, never done that before (I've drawn 40nm IC layouts
though but it's not the same). I guess learning the PCB tool will be the hard part.
Lebowski wrote:The plan is to add high torque startup or even high torque at standstill, SENSORLESS.
I did some measurement on the ME 602 scooter motor and found the winding
impedances change by + or - 15 % based on the rotor position, power needs
to be supplied to the lowest inductance (of the 3) to make the motor move.
Lebowski wrote:I all of a sudden got very motivated to get the controller PCB done, cause in my mind I'm already working on the next holy grail of controller design for which I need a 2nd complete controller.
Jeremy Harris wrote:Pretty impressive work, Lebowski! Great job.
(I've been away from here for a fair while and have only just caught up with this.......)
Jeremy
Lebowski wrote:We had a rainy weekend here with unpredictable weather, so lots of time to work on the PCB.
I got familiar with KiCad by following some only tutorials and got most of the schematic of the
controller drawn...
Ratking wrote:Jeremy Harris wrote:Pretty impressive work, Lebowski! Great job.
Jeremy
Greetings Mr Jeremy, long time no see.
I hope we will maybe see you a bit more often, I really miss the contributions you gave to this forum, it helped me a lot.
Are your house coming together?
Jeremy Harris wrote:Thanks for the kind words, I'll post something on the hassle of trying to build a house here later.
Jeremy
controller drawn...
Users browsing this forum: SiriusFun and 2 guests
