Lebowski wrote:We had a rainy weekend here with unpredictable weather, so lots of time to work on the PCB.
Only one sunny day allowed per week, well, until the kit arrives.
May it rain rain rain...
nieles wrote:i have 10 ohm gate resistors in place.
i also have a 10k (or 20k) and a 15v (or 17v) zener diode beteween the gate and source of each fet.
i have ordered some 1nf 2.2nf and 4.7nf capacitors along with a few 100 low value 0.25w resistors to make a snubber.
Thanks for posting the calculations again. i have them written down somewhere, but this saves me a few hours of searching![]()
Will post again when i have some progress.
can i damage something by only snubbing one phase first? i would think this is not a problem but i am not 100% sure
nieles wrote:not 100% sure what you mean, but i am only using 12v supply for the gates, going lower will not fully turn the fets on.
Arlo1 wrote:Niles would you not be able to reduce the ringing by reducing the voltage you are applying to the fet gates?
Teh Stork wrote:Too long deadtime and too much stray inductance. The ringing is set off by the body diode being shut down. What fets are you using Nieles?
Lebowski wrote:Teh Stork wrote:Too long deadtime and too much stray inductance. The ringing is set off by the body diode being shut down. What fets are you using Nieles?
I don't agree with this.
Teh Stork wrote:Lebowski wrote:Teh Stork wrote:Too long deadtime and too much stray inductance. The ringing is set off by the body diode being shut down. What fets are you using Nieles?
Look to this topic for a detailed breakdown of the phenomenon: linksy.
Arlo1 wrote:We should get bigmoose to chime in but i think snubbers are the wrong way to bandaid fix this. Is it not better to tune the fet ringing out with the proper voltage/ gate resistor combination?
nieles wrote:added a 2.2nf capacitor beteween S-D,
this is what the signal looks like now:
tonight i will add the resistors in series with the capacitor.
should i add an other 1nf in parallel to the 2.2nf? or leave it like this.
Arlo1 wrote:nieles wrote:Looks like a 9 volt supply would be OK. I think it was bigmoose who pointed out to me you want to be just about the miller plateau.
liveforphysics wrote:Arlo1 wrote:nieles wrote:Looks like a 9 volt supply would be OK. I think it was bigmoose who pointed out to me you want to be just about the miller plateau.
You MUST switch above the miller plateau by a healthy amount.
Users browsing this forum: No registered users and 2 guests
