For people that are not so electronics savy I still plan to make `official` PCBs but
for now I'm building a high power 6 FET and after that want to continue programming,
so the next version of my PCB will have to wait a bit.
Lebowski wrote:You got Gordons chip to go into drive 3 ? That would be really coolcan you post all your settings ?
# (c)opyright 2012, B.M. Putter #
# Adliswil, Switzerland #
# bmp72@hotmail.com #
# version 1.01 #
# experimental, use at your own risk #
a] calibrate hall sensors
b] determine coil positions
c) PWM parameters
d) current settings
e) control loop parameters
f) throttle setup
g) running modes
h) CAN bus setup
z) store parameters in EEPROM for motor use
------> a
a] number of e-rotations: 20
b] calibrate hall positions
c] table out hall signals
z] return to main menu
------> b
Spin the motor then press any key to start measurement
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
------> c
hall 1, hall 2, hall 3
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 -.5200 -.5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
a) write variables to EEPROM
b] reverse direction and write variables to EEPROM
z) return to main menu
------> a
Data stored in EEPROM for motor use
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> b
a] number of back-emf samples: 500
b] calibrate coil positions
c] reconstruct waveforms based on extracted parameters
d] table out data arrays
------> a
new value -> 700
a] number of back-emf samples: 700
------> b
Waiting for motor to slow down
Sampling...
coil position capture failed
------> b]
Sampling...
------> b
Sampling...
------> b]
Sampling...
------> b
Sampling...
------> b]
Sampling...
coil position capture successfull
data arrays now contain sampled back-emf waveforms
------> d
data A, data B, data C
.4482 .3486 .8287
.4519 .3735 .8514
.4537 .3933 .8653
.4460 .4046 .8697
.4324 .4112 .8664
.4251 .4233 .8701
.4211 .4420 .8759
.4178 .4584 .8829
.4105 .4716 .8843
.3980 .4812 .8789
.3859 .4925 .8712
.3731 .5061 .8613
.3629 .5229 .8540
.3511 .5408 .8466
.3424 .5610 .8426
.3383 .5852 .8426
.3394 .6123 .8448
.3471 .6452 .8518
.3618 .6851 .8649
.3775 .7265 .8818
.3980 .7716 .9023
.4116 .8100 .9180
.4211 .8378 .9250
.4277 .8649 .9243
.4200 .8734 .9012
.4094 .8741 .8785
.3980 .8726 .8554
.3859 .8715 .8309
.3742 .8668 .8027
.3614 .8602 .7712
.3500 .8503 .7357
.3402 .8433 .6990
.3347 .8393 .6643
.3347 .8441 .6375
.3427 .8558 .6214
.3552 .8693 .6079
.3695 .8836 .5980
.3870 .8983 .5888
.4024 .9114 .5771
.4152 .9228 .5650
.4262 .9309 .5518
.4277 .9298 .5346
.4222 .9217 .5148
.4042 .8920 .4661
.3925 .8693 .4343
.3830 .8474 .4039
.3775 .8294 .3757
.3782 .8184 .3555
.3863 .8133 .3416
.3973 .8096 .3306
.4116 .8049 .3215
.4339 .8052 .3200
.4687 .8166 .3288
.5126 .8367 .3471
.5635 .8638 .3709
.6097 .8873 .3914
.6518 .9060 .4079
.6829 .9144 .4160
.7119 .9177 .4222
.7316 .9122 .4196
.7441 .9005 .4097
.7551 .8869 .3973
.6357 .7305 .3215
.3848 .4357 .1878
.7708 .8620 .3739
.7749 .8499 .3640
.7760 .8298 .3511
.7745 .8089 .3380
.7734 .7873 .3262
.7741 .7672 .3178
.7829 .7551 .3153
.8001 .7496 .3229
.8247 .7525 .3402
.8536 .7584 .3643
.8789 .7584 .3859
.8990 .7500 .4035
.9177 .7390 .4185
.9290 .7214 .4248
.9276 .6903 .4185
.9188 .6547 .4057
.9071 .6174 .3940
.8939 .5782 .3823
.8803 .5386 .3698
.8679 .5017 .3574
.8565 .4661 .3457
.8437 .4321 .3336
.8291 .4028 .3233
.8045 .3592 .3127
.7976 .3420 .3171
.8093 .3413 .3402
.8375 .3596 .3823
.8748 .3856 .4313
.9071 .4097 .4797
.9268 .4244 .5192
.9349 .4306 .5529
.9342 .4281 .5804
.9290 .4204 .6035
.9206 .4083 .6218
.9114 .3969 .6375
.8990 .3845 .6507
.8865 .3728 .6632
.8715 .3621 .6756
.8565 .3500 .6877
.8422 .3380 .6990
.8294 .3277 .7100
.6829 .2702 .5969
.8166 .3200 .7327
.8166 .3237 .7423
.8206 .3383 .7686
.8294 .3592 .7976
.8430 .3845 .8331
.8576 .4108 .8686
.8620 .4284 .8950
.8525 .4328 .9067
.8291 .4266 .9056
.7957 .4141 .8950
.7602 .4020 .8833
.7239 .3900 .8726
.6892 .3775 .8635
.6540 .3643 .8551
.6188 .3530 .8452
.5852 .3405 .8349
.5504 .3306 .8228
.5181 .3229 .8137
.4899 .3193 .8082
.4698 .3229 .8093
.4573 .3350 .8195
.1490 .1065 .2647
------> c
data arrays now contain reconstructed back-emf waveforms
------> d
-.3420 -.5042 .4876
-.3507 -.4740 .5225
-.3611 -.4469 .5588
-.3749 -.4231 .5928
-.3934 -.4025 .6212
-.4169 -.3844 .6411
-.4458 -.3677 .6503
-.4793 -.3515 .6481
-.5164 -.3344 .6347
-.5555 -.3151 .6122
-.5946 -.2918 .5836
-.6309 -.2631 .5532
-.6619 -.2272 .5254
-.6848 -.1825 .5046
-.6973 -.1278 .4946
-.6978 -.0626 .4975
-.6858 .0127 .5140
-.6622 .0968 .5427
-.6292 .1866 .5802
-.5903 .2784 .6214
-.5501 .3674 .6605
-.5137 .4485 .6910
-.4858 .5167 .7073
-.4705 .5682 .7047
-.4704 .6005 .6807
-.4862 .6129 .6350
-.5162 .6071 .5698
-.5568 .5870 .4891
-.6030 .5577 .3987
-.6485 .5257 .3052
-.6871 .4975 .2151
-.7131 .4788 .1339
-.7227 .4737 .0657
-.7142 .4841 .0126
-.6883 .5095 -.0257
-.6484 .5468 -.0516
-.5994 .5910 -.0691
-.5480 .6361 -.0829
-.5007 .6753 -.0982
-.4635 .7030 -.1195
-.4407 .7148 -.1503
-.4345 .7089 -.1924
-.4443 .6855 -.2454
-.4672 .6479 -.3078
-.4978 .6006 -.3759
-.5297 .5499 -.4454
-.5558 .5025 -.5116
-.5697 .4639 -.5699
-.5660 .4389 -.6163
-.5417 .4300 -.6481
-.4960 .4374 -.6640
-.4303 .4592 -.6642
-.3486 .4918 -.6501
-.2557 .5304 -.6244
-.1578 .5698 -.5905
-.0606 .6047 -.5522
.0301 .6315 -.5135
.1106 .6473 -.4781
.1782 .6510 -.4492
.2318 .6430 -.4293
.2720 .6249 -.4200
.3005 .5992 -.4220
.3196 .5687 -.4348
.3324 .5363 -.4575
.3419 .5040 -.4877
.3506 .4739 -.5226
.3610 .4468 -.5589
.3748 .4230 -.5929
.3932 .4023 -.6214
.4168 .3842 -.6413
.4456 .3676 -.6505
.4791 .3514 -.6482
.5163 .3343 -.6349
.5555 .3149 -.6124
.5946 .2917 -.5838
.6308 .2630 -.5534
.6618 .2271 -.5255
.6847 .1823 -.5048
.6972 .1277 -.4948
.6977 .0624 -.4977
.6857 -.0128 -.5142
.6621 -.0968 -.5429
.6291 -.1867 -.5803
.5902 -.2785 -.6216
.5501 -.3675 -.6607
.5136 -.4486 -.6912
.4857 -.5169 -.7074
.4704 -.5683 -.7048
.4703 -.6006 -.6809
.4860 -.6129 -.6352
.5159 -.6072 -.5700
.5567 -.5871 -.4893
.6029 -.5578 -.3989
.6483 -.5258 -.3054
.6869 -.4976 -.2153
.7129 -.4789 -.1341
.7225 -.4738 -.0659
.7140 -.4842 -.0127
.6882 -.5096 .0256
.6482 -.5469 .0515
.5993 -.5911 .0690
.5478 -.6361 .0828
.5005 -.6754 .0980
.4633 -.7031 .1194
.4406 -.7149 .1502
.4344 -.7089 .1922
.4443 -.6857 .2453
.4670 -.6479 .3077
.4977 -.6007 .3758
.5296 -.5501 .4453
.5557 -.5026 .5115
.5695 -.4641 .5697
.5659 -.4391 .6161
.5415 -.4302 .6480
.4958 -.4375 .6639
.4302 -.4593 .6641
.3484 -.4920 .6500
.2555 -.5306 .6243
.1576 -.5699 .5903
.0605 -.6049 .5521
-.0302 -.6317 .5134
-.1107 -.6474 .4780
-.1783 -.6511 .4491
-.2319 -.6431 .4292
-.2722 -.6251 .4199
-.3006 -.5994 .4219
-.3197 -.5689 .4348
-.3326 -.5364 .4574
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> c
a) PWM frequency: 20kHz
b) deadtime: 1499ns
c) dutycycle testsignal: 50%
d) toggle high side polarity, now active HIGH
e) toggle low side polarity, now active HIGH
f) test PWM signals
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> e
a) loop sample frequency: 38.01 kHz
b) 1st order phase loop integrator coefficient: 307.1999
c) 2nd order phase loop integrator coefficient: 0.0199
d) amplitude loop integrator coefficient: 12.8999
e) maximum amplitude: 200 %
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> f
a) calibrate throttle 1
b) calibrate throttle 2
c) polynomial coefficients throttle 1 (x, x^2, x^3): -0.0002, -0.0002, -0.0002
d) polynomial coefficients throttle 2 (x, x^2, x^3): -0.0002, -0.0002, -0.0002
e) use analog throttle 1: YES
f) use analog throttle 2: NO
receive throttle over CAN: NO
g) TX throttle over CAN: NO
h) test throttle
------> h
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
21 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 F - X +
2 1 F - X +
2 1 F - X +
2 1 F - X +
2 1 F - X +
2 1 F - X +
2 1 F - X +
2 1 F - X +
2 1 F - X +
2 1 F - X +
2 1 F - X +
2 1 F - X +
2 1 F - X +
2 1 F - X +
2 1 F - X +
2 1 F - X +
2 1 F - X +
2 1 F - X +
2 1 F - X +
2 1| F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
21 | F - X +
21 | F - X +
21 | F - X +
21 | F - X +
21 | F - X +
21 | F - X +
21 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1| F - X +
2 1| F - X +
2 1| F - X +
2 1| F - X +
2 1| F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 1 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
2 | F - X +
h) test throttle
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> g
a) sensored or sensorless: SENSORED
b} sensorless startup: SELF START
c} e-rpm limit sensorless self start: 278
d} e-rpm reached before transition: 75 %
e} minimum current push start: 1.2 A
f} push start current, error allowed: 5 %
g] erpm sensored to sensorless transition: 1500
h] transition time sensored to sensorless: 299 milli-sec
i) return to motor start below 107 erpm
j) controlled slowdown for direction change: YES
k) phase current for controlled slowdown: 74.9 A
l) motor maximum, forward: 99.97 k-erpm
m) motor maximum, reverse: 99.97 k-erpm
n) motor standstill voltage threshold: 0.49 V
o) enable low side pulsing in drive 0: YES
p) low side pulsing rate: 20 Hz
q) low side pulsing width: 20 usec
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> d
a) number of current sensors: 2
b) current sensor transimpedance: 10.00 mV/A
c) maximum motor phase current: 29.9 A
d) maximum battery current, motor use: 9.9 A
e) maximum battery current, regen: 4.9 A
f) maximum shutdown error current, fixed: 6.2 A
g) maximum shutdown error current, proportional: 6.2 A
h) IIR filter coefficient: 5
i) use additional comb filter: YES
j) use offset calibration: YES
k) restore default calibration
------> k
default values restored
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> h
a) CAN 'address': 16383
b) CAN CFG1 as per Microchip 30F manual: 65535
c) CAN CFG2 as per Microchip 30F manual: 65535
RS232 output rate: 3802 Hz
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> h
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> [00][00]
[00][00]
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> b
------> a
new value -> 1500
a] number of back-emf samples: 1500
------> b
Sampling...
------> b]
Sampling...
------> b
Sampling...
------> b]
Sampling...
------> b
Sampling...
------> b]
Sampling...
------> b
Sampling...
------> b]
Sampling...
------> b
Sampling...
------> b]
Sampling...
------> [00][00]
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> b
------> a
new value -> 1500
------> b
Sampling...
------> b]
Sampling...
------> b
Sampling...
------> b]
Sampling...
------> b
Sampling...
------> b]
Sampling...
------> b
Sampling...
------> d
-.7432 -.8763 -.0955
-.7695 -.8695 -.0968
-.7884 -.8565 -.0968
-.8047 -.8410 -.0968
-.8197 -.8232 -.0964
-.8340 -.8043 -.0964
-.8481 -.7853 -.0961
-.8600 -.7642 -.0959
-.8677 -.7379 -.0946
-.8710 -.7045 -.0942
-.8726 -.6652 -.0932
-.8741 -.6223 -.0921
-.8772 -.5802 -.0906
-.8812 -.5377 -.0899
-.8856 -.4987 -.0897
-.8878 -.4592 -.0904
-.8869 -.4191 -.0911
-.8856 -.3788 -.0926
-.8845 -.3383 -.0928
-.8853 -.3006 -.0928
-.8847 -.2642 -.0908
-.8069 -.2145 -.0805
-.8772 -.2065 -.0869
-.8692 -.1783 -.0886
-.8510 -.1343 -.0948
-.8406 -.1093 -.1025
-.8432 -.0952 -.1235
-.8556 -.0930 -.1552
-.8673 -.0924 -.1895
-.8745 -.0919 -.2259
-.8774 -.0924 -.2664
-.8792 -.0922 -.3099
-.8822 -.0913 -.3566
-.8878 -.0897 -.4046
-.8942 -.0888 -.4500
-.8979 -.0878 -.4916
-.8984 -.0871 -.5317
-.8970 -.0871 -.5716
-.8957 -.0878 -.6117
-.8950 -.0882 -.6524
-.8944 -.0884 -.6893
-.8917 -.0889 -.7218
-.8869 -.0899 -.7479
-.8737 -.0917 -.7754
-.8534 -.0933 -.7966
-.8355 -.0950 -.8120
-.8175 -.0957 -.8278
-.7988 -.0953 -.8433
-.7769 -.0935 -.8551
-.7507 -.0910 -.8627
-.7172 -.0888 -.8646
-.6802 -.0884 -.8660
-.6406 -.0886 -.8677
-.6013 -.0886 -.8719
-.5634 -.0893 -.8774
-.5255 -.0891 -.8827
-.4887 -.0902 -.8864
-.4504 -.0922 -.8871
-.4094 -.0933 -.8843
-.3695 -.0948 -.8820
-.3277 -.0933 -.8792
-.2883 -.0915 -.8776
-.1973 -.0682 -.6571
-.1569 -.0598 -.5835
-.2145 -.0908 -.8732
-.1902 -.0919 -.8677
-.1604 -.0942 -.8576
-.1320 -.0977 -.8461
-.1076 -.1054 -.8362
-.0961 -.1267 -.8388
-.0924 -.1563 -.8488
-.0913 -.1884 -.8583
-.0906 -.2222 -.8649
-.0911 -.2592 -.8677
-.0911 -.2995 -.8686
-.0917 -.3451 -.8713
-.0917 -.3916 -.8756
-.0911 -.4379 -.8816
-.0895 -.4806 -.8854
-.0871 -.5198 -.8851
-.0855 -.5590 -.8823
-.0853 -.5972 -.8796
-.0864 -.6379 -.8798
-.0871 -.6762 -.8811
-.0886 -.7111 -.8825
-.0902 -.7399 -.8822
-.0919 -.7628 -.8781
-.0948 -.7959 -.8565
-.0961 -.8124 -.8397
-.0959 -.8283 -.8219
-.0957 -.8435 -.8031
-.0944 -.8574 -.7818
-.0930 -.8662 -.7549
-.0917 -.8710 -.7214
-.0917 -.8741 -.6828
-.0915 -.8778 -.6395
-.0906 -.8820 -.5967
-.0902 -.8882 -.5559
-.0902 -.8930 -.5167
-.0908 -.8959 -.4779
-.0897 -.8939 -.4376
-.0902 -.8911 -.3955
-.0906 -.8889 -.3537
-.0908 -.8889 -.3143
-.0917 -.8887 -.2790
-.0836 -.8122 -.2266
-.0919 -.8800 -.2199
-.0928 -.8734 -.1968
-.0937 -.8594 -.1651
-.0963 -.8413 -.1307
-.1047 -.8318 -.1060
-.1270 -.8353 -.0948
-.1569 -.8452 -.0917
-.1904 -.8552 -.0919
-.2257 -.8611 -.0917
-.2634 -.8629 -.0930
-.3041 -.8649 -.0939
-.3477 -.8668 -.0939
-.3898 -.8719 -.0928
-.4324 -.8774 -.0913
-.4714 -.8801 -.0893
-.5099 -.8805 -.0891
-.5480 -.8801 -.0906
-.5868 -.8785 -.0921
-.6258 -.8767 -.0930
-.6643 -.8767 -.0935
-.6990 -.8765 -.0941
-.5408 -.6531 -.0708
------> c
------> d
-.4314 -.6116 .5738
-.4746 -.6076 .5755
-.5131 -.6004 .5810
-.5466 -.5880 .5895
-.5746 -.5687 .5998
-.5973 -.5413 .6108
-.6151 -.5051 .6211
-.6284 -.4601 .6296
-.6381 -.4070 .6356
-.6452 -.3470 .6387
-.6503 -.2818 .6393
-.6544 -.2131 .6378
-.6578 -.1425 .6354
-.6609 -.0715 .6330
-.6634 -.0011 .6316
-.6651 .0676 .6319
-.6657 .1346 .6343
-.6648 .1993 .6383
-.6623 .2617 .6432
-.6582 .3215 .6477
-.6529 .3782 .6502
-.6468 .4312 .6491
-.6408 .4797 .6426
-.6356 .5229 .6293
-.6320 .5600 .6083
-.6307 .5905 .5793
-.6318 .6143 .5422
-.6353 .6315 .4974
-.6409 .6427 .4457
-.6479 .6492 .3883
-.6556 .6519 .3262
-.6631 .6524 .2607
-.6698 .6519 .1926
-.6752 .6512 .1229
-.6790 .6508 .0524
-.6815 .6510 -.0179
-.6828 .6513 -.0877
-.6831 .6512 -.1561
-.6831 .6502 -.2221
-.6825 .6477 -.2849
-.6812 .6435 -.3436
-.6788 .6376 -.3976
-.6742 .6304 -.4461
-.6662 .6228 -.4886
-.6536 .6158 -.5252
-.6350 .6105 -.5558
-.6094 .6076 -.5810
-.5761 .6079 -.6013
-.5347 .6112 -.6175
-.4858 .6174 -.6301
-.4300 .6253 -.6398
-.3685 .6340 -.6469
-.3029 .6420 -.6516
-.2347 .6483 -.6539
-.1653 .6519 -.6535
-.0962 .6523 -.6504
-.0282 .6497 -.6446
.0379 .6448 -.6362
.1019 .6383 -.6258
.1635 .6313 -.6141
.2226 .6249 -.6021
.2793 .6199 -.5910
.3332 .6164 -.5820
.3840 .6138 -.5761
.4313 .6114 -.5739
.4745 .6075 -.5756
.5130 .6002 -.5811
.5464 .5879 -.5896
.5745 .5685 -.6000
.5972 .5412 -.6109
.6150 .5049 -.6213
.6283 .4599 -.6297
.6380 .4068 -.6357
.6450 .3468 -.6389
.6502 .2817 -.6394
.6543 .2129 -.6380
.6578 .1424 -.6355
.6607 .0714 -.6331
.6632 .0010 -.6317
.6650 -.0677 -.6321
.6656 -.1347 -.6344
.6647 -.1995 -.6384
.6623 -.2619 -.6434
.6582 -.3216 -.6479
.6528 -.3783 -.6504
.6467 -.4313 -.6492
.6407 -.4798 -.6427
.6355 -.5230 -.6294
.6319 -.5601 -.6085
.6305 -.5906 -.5795
.6316 -.6144 -.5423
.6351 -.6316 -.4975
.6408 -.6428 -.4459
.6477 -.6492 -.3885
.6554 -.6520 -.3264
.6629 -.6525 -.2608
.6696 -.6520 -.1927
.6750 -.6512 -.1230
.6789 -.6509 -.0526
.6813 -.6510 .0179
.6826 -.6513 .0876
.6830 -.6513 .1560
.6829 -.6503 .2220
.6823 -.6478 .2848
.6810 -.6436 .3436
.6786 -.6376 .3975
.6740 -.6305 .4460
.6660 -.6229 .4885
.6535 -.6159 .5250
.6348 -.6106 .5557
.6092 -.6078 .5808
.5759 -.6081 .6012
.5346 -.6114 .6174
.4856 -.6176 .6300
.4298 -.6255 .6397
.3684 -.6342 .6468
.3027 -.6422 .6515
.2345 -.6485 .6538
.1652 -.6520 .6535
.0960 -.6525 .6504
.0281 -.6499 .6445
-.0380 -.6449 .6361
-.1020 -.6384 .6257
-.1636 -.6315 .6140
-.2228 -.6251 .6020
-.2794 -.6201 .5910
-.3333 -.6165 .5820
-.3841 -.6140 .5760
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> [00][00]
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> c
a) PWM frequency: 30kHz
b) deadtime: 1499ns
f) test PWM signals
------> b
new value -> 600
b) deadtime: 599ns
f) test PWM signals
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> e
a) loop sample frequency: 58.02 kHz
b) 1st order phase loop integrator coefficient: 20.5289
c) 2nd order phase loop integrator coefficient: 0.0456
d) amplitude loop integrator coefficient: 1.3127
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> f
h) test throttle
------> c
enter the 3 coefficients [-8..8]
new value -> 1,0,0
new value -> 0
new value -> 0
c) polynomial coefficients throttle 1 (x, x^2, x^3): -8.0000, 0.0000, 0.0000
h) test throttle
------> c
new value -> 1
new value -> 0
new value -> 0
c) polynomial coefficients throttle 1 (x, x^2, x^3): 1.0000, 0.0000, 0.0000
h) test throttle
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> g
c} e-rpm limit sensorless self start: 425
d} e-rpm reached before transition: 87 %
e} minimum current push start: 4.9 A
f} push start current, error allowed: 10 %
g] erpm sensored to sensorless transition: 500
h] transition time sensored to sensorless: 399 milli-sec
i) return to motor start below 200 erpm
l) motor maximum, forward: 255.60 k-erpm
m) motor maximum, reverse: 152.57 k-erpm
n) motor standstill voltage threshold: 0.19 V
p) low side pulsing rate: 30 Hz
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> d
------> h
new value -> 7
h) IIR filter coefficient: 7
------> k
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> [00][00][00]
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> [00][00]
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> d
------> h
new value -> 58
h) IIR filter coefficient: 10
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> [00][00]
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> e
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> g
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> a
------> b
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> a
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> d
------> k
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> [00][00]
[00]
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> a
------> b
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
------> c
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 .5200 -.5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
-.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 -.5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 .5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
.5000 .5200 -.5400
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> b
------> b]
Sampling...
------> d
-.7642 -.8931 -.2081
-.7886 -.8867 -.2089
-.8069 -.8770 -.2085
-.8215 -.8642 -.2087
-.8347 -.8492 -.2089
-.8488 -.8336 -.2087
-.8622 -.8177 -.2089
-.8735 -.8009 -.2085
-.8825 -.7803 -.2083
-.8886 -.7553 -.2085
-.8908 -.7236 -.2085
-.8928 -.6888 -.2092
-.8959 -.6531 -.2087
-.9006 -.6176 -.2083
-.9045 -.5820 -.2074
-.9069 -.5474 -.2072
-.9056 -.5115 -.2063
-.9038 -.4762 -.2067
-.9030 -.4416 -.2072
-.9030 -.4083 -.2080
-.9047 -.3771 -.2080
-.8298 -.3220 -.1906
-.9038 -.3261 -.2080
-.8988 -.3039 -.2089
-.8838 -.2667 -.2100
-.8693 -.2385 -.2114
-.8613 -.2171 -.2182
-.8655 -.2067 -.2384
-.8767 -.2058 -.2673
-.8862 -.2058 -.2986
-.8906 -.2052 -.3303
-.8919 -.2043 -.3647
-.8930 -.2034 -.4031
-.8973 -.2036 -.4442
-.9021 -.2030 -.4854
-.9093 -.2039 -.5255
-.9133 -.2041 -.5617
-.9131 -.2043 -.5960
-.9104 -.2043 -.6287
-.9082 -.2041 -.6626
-.9065 -.2045 -.6961
-.9063 -.2052 -.7280
-.9038 -.2059 -.7542
-.8975 -.2067 -.7807
-.8809 -.2078 -.8052
-.8657 -.2080 -.8182
-.8496 -.2085 -.8309
-.8327 -.2083 -.8432
-.8166 -.2078 -.8558
-.7998 -.2080 -.8677
-.7783 -.2078 -.8754
-.7529 -.2081 -.8801
-.7214 -.2083 -.8812
-.6879 -.2083 -.8827
-.6547 -.2078 -.8853
-.6209 -.2065 -.8889
-.5881 -.2056 -.8922
-.5564 -.2058 -.8950
-.5231 -.2058 -.8944
-.4890 -.2063 -.8922
-.4548 -.2069 -.8897
-.4205 -.2069 -.8871
-.3874 -.2065 -.8858
-.3316 -.1889 -.8139
-.3387 -.2065 -.8856
-.3198 -.2065 -.8836
-.2898 -.2070 -.8761
-.2583 -.2091 -.8642
-.2329 -.2107 -.8519
-.2140 -.2202 -.8475
-.2076 -.2415 -.8530
-.2059 -.2686 -.8635
-.2061 -.2971 -.8719
-.2069 -.3268 -.8778
-.2065 -.3587 -.8796
-.2065 -.3945 -.8814
-.2056 -.4330 -.8836
-.2058 -.4735 -.8889
-.2059 -.5132 -.8950
-.2061 -.5504 -.8995
-.2045 -.5850 -.8999
-.2048 -.6190 -.8986
-.2047 -.6522 -.8970
-.2052 -.6864 -.8968
-.2056 -.7199 -.8981
-.1891 -.6846 -.8236
-.2065 -.7710 -.8970
-.2067 -.7904 -.8919
-.2061 -.8153 -.8728
-.2074 -.8294 -.8583
-.2076 -.8432 -.8422
-.2080 -.8578 -.8267
-.2072 -.8699 -.8095
-.2072 -.8807 -.7886
-.2067 -.8858 -.7617
-.2076 -.8897 -.7291
-.2078 -.8922 -.6928
-.2081 -.8970 -.6566
-.2076 -.9019 -.6212
-.2070 -.9060 -.5874
-.2074 -.9087 -.5544
-.2070 -.9083 -.5202
-.2078 -.9058 -.4854
-.2080 -.9041 -.4497
-.2080 -.9021 -.4149
-.2083 -.9014 -.3825
-.2085 -.8988 -.3524
-.2074 -.8941 -.3275
-.2081 -.8809 -.2904
-.2087 -.8677 -.2618
-.2131 -.8497 -.2268
-.2274 -.8481 -.2122
-.2521 -.8567 -.2078
-.2805 -.8659 -.2070
-.3101 -.8721 -.2070
-.3416 -.8754 -.2072
-.3744 -.8759 -.2078
-.4099 -.8767 -.2070
-.4473 -.8809 -.2072
-.4846 -.8860 -.2072
-.5196 -.8911 -.2070
-.5540 -.8944 -.2076
-.5866 -.8942 -.2083
-.6177 -.8917 -.2081
-.6502 -.8886 -.2083
-.6822 -.8869 -.2083
-.7124 -.8860 -.2081
-.6157 -.7401 -.1739
------> c
------> d
-.4158 -.6224 .6330
-.4649 -.6207 .6266
-.5104 -.6174 .6201
-.5512 -.6102 .6145
-.5863 -.5971 .6107
-.6152 -.5765 .6092
-.6377 -.5468 .6103
-.6539 -.5078 .6139
-.6646 -.4594 .6193
-.6706 -.4027 .6259
-.6735 -.3393 .6327
-.6744 -.2712 .6387
-.6743 -.2004 .6433
-.6742 -.1290 .6461
-.6744 -.0584 .6471
-.6751 .0101 .6467
-.6758 .0762 .6453
-.6762 .1396 .6437
-.6757 .2006 .6424
-.6738 .2591 .6415
-.6704 .3156 .6408
-.6656 .3698 .6398
-.6597 .4213 .6370
-.6534 .4695 .6313
-.6477 .5133 .6207
-.6432 .5519 .6040
-.6406 .5844 .5796
-.6404 .6104 .5468
-.6426 .6297 .5053
-.6467 .6429 .4556
-.6524 .6507 .3986
-.6587 .6545 .3356
-.6649 .6556 .2684
-.6701 .6555 .1985
-.6741 .6552 .1275
-.6764 .6553 .0567
-.6772 .6562 -.0129
-.6767 .6576 -.0809
-.6752 .6589 -.1470
-.6732 .6593 -.2109
-.6705 .6581 -.2724
-.6669 .6549 -.3313
-.6618 .6495 -.3872
-.6543 .6422 -.4392
-.6430 .6339 -.4866
-.6264 .6256 -.5286
-.6036 .6184 -.5643
-.5735 .6134 -.5932
-.5354 .6115 -.6153
-.4896 .6128 -.6307
-.4366 .6173 -.6403
-.3775 .6240 -.6449
-.3139 .6321 -.6462
-.2475 .6400 -.6455
-.1799 .6466 -.6439
-.1125 .6508 -.6427
-.0464 .6521 -.6422
.0177 .6506 -.6426
.0797 .6466 -.6437
.1397 .6411 -.6449
.1979 .6353 -.6455
.2545 .6300 -.6449
.3099 .6261 -.6427
.3638 .6236 -.6386
.4156 .6222 -.6331
.4648 .6206 -.6267
.5103 .6173 -.6202
.5510 .6101 -.6147
.5862 .5970 -.6109
.6151 .5763 -.6094
.6376 .5467 -.6105
.6538 .5076 -.6141
.6645 .4592 -.6195
.6705 .4025 -.6261
.6734 .3392 -.6329
.6743 .2710 -.6388
.6742 .2003 -.6435
.6741 .1288 -.6463
.6744 .0583 -.6473
.6750 -.0103 -.6468
.6758 -.0764 -.6455
.6761 -.1398 -.6439
.6756 -.2007 -.6426
.6738 -.2593 -.6416
.6704 -.3157 -.6410
.6654 -.3699 -.6399
.6596 -.4214 -.6372
.6534 -.4696 -.6314
.6476 -.5134 -.6209
.6430 -.5520 -.6041
.6405 -.5845 -.5798
.6402 -.6105 -.5469
.6423 -.6299 -.5055
.6466 -.6430 -.4558
.6522 -.6508 -.3988
.6585 -.6546 -.3358
.6647 -.6557 -.2685
.6699 -.6556 -.1986
.6738 -.6553 -.1276
.6762 -.6554 -.0569
.6770 -.6564 .0128
.6765 -.6577 .0808
.6751 -.6589 .1469
.6730 -.6594 .2108
.6703 -.6582 .2723
.6668 -.6549 .3312
.6617 -.6495 .3871
.6542 -.6423 .4391
.6428 -.6340 .4865
.6263 -.6257 .5285
.6035 -.6185 .5642
.5733 -.6136 .5932
.5353 -.6117 .6152
.4895 -.6130 .6306
.4364 -.6174 .6401
.3774 -.6242 .6448
.3138 -.6322 .6461
.2473 -.6401 .6454
.1798 -.6467 .6438
.1124 -.6510 .6426
.0462 -.6523 .6420
-.0178 -.6507 .6425
-.0798 -.6467 .6436
-.1398 -.6413 .6448
-.1980 -.6354 .6454
-.2546 -.6302 .6448
-.3100 -.6262 .6426
-.3638 -.6238 .6386
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> [00][00]
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> f
h) test throttle
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> e
------> b
new value -> 307.1999
b) 1st order phase loop integrator coefficient: 307.1998
------> c
new value -> .0199
c) 2nd order phase loop integrator coefficient: 0.0198
------> d
new value -> 12.8999
d) amplitude loop integrator coefficient: 12.8998
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> g
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> d
------> k
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> [00][00][00][00]
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> e
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> g
------> g
new value -> 1000
g] erpm sensored to sensorless transition: 1000
------> [00][00]
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> g
------> 1000
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> [00][00]
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> e
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> d
------> k
------> h
new value -> 5
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> [00][00]
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> e
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> f
h) test throttle
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> g
------> g
new value -> 1000
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> [00][00]
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> g
------> h
new value -> 1000
h] transition time sensored to sensorless: 999 milli-sec
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> [00][00]
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> g
------> h
new value -> 5000
h] transition time sensored to sensorless: 4999 milli-sec
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> g
------> h
new value -> 10
h] transition time sensored to sensorless: 9 milli-sec
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> [00][00]
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> g
------> g
new value -> 5000
g] erpm sensored to sensorless transition: 5002
------> h
new value -> 300
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> a
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> z
# version 1.01 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
Users browsing this forum: davidyerger and 4 guests
