powercroco 135-50 inrunner - 40kW bldc
Postby c_a » Sat Mar 10, 2012 2:57 pm
since september the powercroco community is working on the new motor for my 2012 epo-bike,
it looks like we will be ready soon:
rotor tray:
the stator can be seen here (the second from the top):
http://powerditto.de/monster.html
we are looking for 40kW @ 5.000rpm
Best regards
Christian
c_a
Re: powercroco 135-50 inrunner
Postby Miles » Sat Mar 10, 2012 3:37 pm
Nice!
Looking forward to seeing more of this, Christian. :D
Ref: http://translate.google.com/translate?u ... =&ie=UTF-8
Miles
Postby zEEz » Tue Mar 13, 2012 8:18 am
WOW ... that stuff is great!
I see it is wound up for 6 split controllers, kind of 7kW each. :o
Are you planning to use a custom controller or just 6 pieces of some standard
Infineon-like sensored controller? Like a block of 6x 36fet?
Will you glue the magnets on the rotor?
have fun!
from 1A-1S to 200A-18S ESC ^_^ 3g to 10Kg brushless motors ...
zEEz
Postby c_a » Tue Mar 13, 2012 3:57 pm
today I got the rotor parts,
I really like it and my motivation is back :-)
c_a
Re: powercroco 135-50 inrunner - 40kW bldc
Postby c_a » Thu Mar 15, 2012 4:37 pm
next step is already done, this weekend I will have a lot of fun with the magnets :shock:
c_a
Postby neptronix » Thu Mar 15, 2012 5:03 pm
Jesus Christ on a Cracker.
The high power eBike arms race just got even nuttier.
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby lutach » Thu Mar 15, 2012 7:59 pm
Christian I'm confused :roll: :lol: . I thought you loved outrunners :wink: .
Your motor will be awesome.
lutach
Postby acuteaero » Thu Mar 15, 2012 10:33 pm
neptronix wrote:The high power eBike arms race just got even nuttier.
Pretty sure we're talking electric race motorcycles here, http://epo-bike.de/
Looks like you're running a one-way sprag bearing between the rotor and the output shaft? So I presume the shaft will be suspended in an additional set of bearings, maybe in the motor end plates? Neat setup! I suppose it's the most compact way to allow the motor to freewheel- since regen braking will be of very limited value while racing...
Beautiful parts, I look forward to seeing more photos as you build the motor!
acuteaero
Postby Biff » Thu Mar 15, 2012 11:31 pm
That looks really neat. What controller are you thinking of using? 5000RPM with a 30pole motor is 1250Hz electrical frequency, I don't know of any 40kW controllers that can handle that kind of speed. With your pole/slot combination you could run it with 6 parallel RC ESC's but I think off the line torque might still blow those little controllers up. I am very interested to see what you have come up with.
-ryan
Biff
Postby c_a » Fri Mar 16, 2012 1:12 am
Hi,
the freewheel is for security reasons if I loose one of the 60 6x6x50mm magnets.
First I will use two kelly KBL09401B controllers, each will fire three single motors conntected in YYY.
c_a
Postby grindz145 » Fri Mar 16, 2012 8:11 am
I'll be super psyched if we can actually control this beast. Hugely Subscribed.
Any theoretical calcs on winding resistance/inductance?
:mrgreen:
http://www.endless-sphere.com/forums/viewtopic.php?f=18&t=19548 - Ebike Nerd Podcast
Thanks to Justin @ ebikes.ca! Go there, buy stuff. Support the Revolution :D
grindz145
Postby zEEz » Fri Mar 16, 2012 11:24 am
c_a wrote:Hi,
I hope you not only glue them, but also strap them over with enough turns of carbon wire and coating,
to avoid exploding magnet fireworks :mrgreen:
have fun!
zEEz
Postby liveforphysics » Fri Mar 16, 2012 2:24 pm
zEEz wrote:
c_a wrote:Hi,
have fun!
Carbon is very conductive and starts glowing red very quickly while spinning in a strong magnetic field.
Kevlar or glass fibers are a much better choice.
Like Biff mentioned above, a Sevcon could only bring that motor to half RPM before reaching commutation freq limits. The ultra-high-speed Kelly should get it closer, but not see full speed (and have a habit of randomly exploding).
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby zEEz » Fri Mar 16, 2012 4:12 pm
liveforphysics wrote:Carbon is very conductive and starts glowing red very quickly while spinning in a strong magnetic field.
I had a second thought and considered this point, but then I assumed a spiral rotating in the field
in that fashion you would naturally wrap the magnets should not make a big disaster, since it naturally
sees an almost constant magnetic flux. :mrgreen:
On the other hand, considering the possibility of strong nonlinerities and other nasty effects, I agree with
you, lfp, that to use kevlar would be the safest choice .... 8)
have fun!
zEEz
Postby CNCAddict » Fri Mar 16, 2012 5:20 pm
Carbon is fine. All the neumotors use it and I've used it as well.
CNCAddict
Postby c_a » Sat Mar 17, 2012 3:07 pm
I hope I can glue the magnets early next week.
The copper wire has a diameter of 2,12mm + isolation, the copper weight is >1kg...
today I checked the outer diameter of the rotor, it is 134mm as calculated. So we have 0,5mm air gap as planned :-)
c_a
Postby c_a » Fri Mar 30, 2012 4:38 pm
all parts are here now, check this out:
c_a
Postby zEEz » Fri Mar 30, 2012 4:41 pm
terrific stuff...
are you planning cooling?
have fun :mrgreen:
zEEz
Postby c_a » Fri Mar 30, 2012 4:46 pm
the rotor is the cooler
c_a
Postby zEEz » Mon Apr 02, 2012 9:00 am
c_a wrote:the rotor is the cooler
you didn't plan any kind of water or oil cooling? :shock:
have fun!
zEEz
Return to Motor Technology
Who is online
Users browsing this forum: No registered users and 7 guests
