Zappy's high power forced induction Magic Pie !
Re: Zappy's high power forced induction Magic Pie !
Postby neptronix » Thu May 10, 2012 8:10 pm
I am actually looking to average about 40kph, since this will be a continuous 7% hill climb for about 11 miles.
So the pie has to handle 2500-3000 watts non-stop :shock:
On a 20" wheel, i will be running a lower RPM as well.
I was going to locate the fans right in between the edge of the cover and the disc brake mounting holes like zappy did.
If so, do you think the fans are going to benefit me, and... i do think that seeing the dyno information would be interesting if you can post it up here.
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby John in CR » Fri May 11, 2012 1:42 pm
Assuming a total load of 300lbs, 2kw at the wheel will get you 28mph and 3kw will get you 35mph. 35mph is plenty fast for good flow without fans, though I'd encourage a number of blades in each cover as close to the stator as you can get. I think it's an important factor in how well our ventilated motors are cooling....similar speed in a 20", bigger load so higher power, smaller diameter motor, and no heat problems.
Here's what I mean by blades (bolted and epoxied so they can't come off or loose and ruin the motor)
An example with a 9C
9C vented covers with blades.JPG (47.82 KiB) Viewed 186 times
More recently with Hubmonster (same diameter as a magpie)
SuperV with Hubmonster inside covers.JPG (46.58 KiB) Viewed 186 times
Unless I missed a change, Zappy has his 4 fans at the spokes of the stator with that aluminum sheet to seal the rest of the space off, so they help suck air into the swiss cheesed side cover. It's similar to what Arlo1 did, and I appreciate the benefit at lower speeds. Zappy is offroading, and Arlo does repetitive launches. I do think blowers, common for servers, would be far better. Mount the same way and point the output directly at the stator. You could also mount some with input and output on the same side of the motor to for a more turbulent flow on that side of the stator too.
This is what I mean by a blower, which would much more likely reach rated cfm in our use for motors.
Blower fan pic.JPG (8.16 KiB) Viewed 186 times
Unless I lose a bunch of weight and start off-roading, then I don't foresee ever needing to go active to ventilate my motors. If I did run into motor heating, the change I would make is larger intake holes near the center and a V shaped ducting outside the motor to funnel more air toward the intake. That would create a high pressure region there, which would definitely help intake flow.
John
John in CR
Postby nechaus » Tue May 15, 2012 6:35 am
awesome!
Magic pie Dual Suspension
Peak 6kw Air cooled
Kelly controller (mini kbs series, smaller than a coke can, can do 80+ battery amps peak, Favorite small controller. Really punchy)
20s 16ah
60 kmh,
Safe, Beautiful handling.
nechaus
Previous
Return to Motor Technology
Who is online
Users browsing this forum: No registered users and 2 guests
