it was an eb209 feeding some 30a @48v to a mac 10t.
so i opened the ca's setup menu and set the amp limit to eg 10a. this would be enough to help a bit on those extreme climbs, but without harming the motor/controller.
the problem was that there was no smooth reduction of the power but a lot of stuttering. on - off - on - off all the time. i don't think that this is good for the gears and it's not comfortable to ride.
did i do anything wrong? if not: is there a better way to reduce amps? i can't reprogram the controller during the ride
thanks
