air cooling a magic pie
Postby zappy » Mon May 21, 2012 4:34 am
See attached pics
backward facing vanes
(136.55 KiB) Downloaded 4 times
freewheel side plate view
(158.13 KiB) Downloaded 4 times
maximum permissable diameter and height
(151.16 KiB) Downloaded 4 times
bending vanes on preloved pie magnets
(108.23 KiB) Downloaded 4 times
final shape
(129.59 KiB) Downloaded 4 times
approx clearance when assembled
(97.1 KiB) Downloaded 4 times
fans for slow speed cooling
(140.3 KiB) Downloaded 4 times
assembled pie
(119.77 KiB) Downloaded 4 times
zappy
Re: air cooling a magic pie
Postby nechaus » Mon May 21, 2012 7:58 am
you did a good job well done.
Pretty damm dirty pie. that has to be the smallest spokes iv ever seen
Magic pie Dual Suspension
Peak 6kw Air cooled
Kelly controller (mini kbs series, smaller than a coke can, can do 80+ battery amps peak, Favorite small controller. Really punchy)
20s 16ah
60 kmh,
Safe, Beautiful handling.
nechaus
Postby zappy » Mon May 21, 2012 6:55 pm
One crusty pie is the correct term. For max thrust the magnets need to be just under the surface of the tyre tread, this is closer than most. This winding was corroded when it was run for 6 months as a sealed standard motor. The whole winding has been dipped in a product called Nyalic which is good to 350F but some of that has darkened. Riding with dirt bikes is very dusty.
Zappy
zappy
Postby Farfle » Wed May 23, 2012 7:15 pm
Damn, I thought I was winning the shortest spoke contest... 54mm here
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 318A at 91v
Peak power out: 24 Hp and 151ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Farfle
Postby nechaus » Fri May 25, 2012 10:52 am
thats a great looking setup.
damm
Peak 6kw Air cooled
20s 16ah
60 kmh,
nechaus
Return to Motor Technology
Who is online
Users browsing this forum: Teh Stork and 3 guests
