Geez.....
The magic pie has drastically more torque than their other DD, which is identical in performance to the 9C, MXUS etc. motors.
It also sheds heat better.
It also handles more power.
But it is a slow winding. You'll need to feed it high volts for it to go fast. You need an aftermarket controller to really give it the amps it wants too.
See my magic pie build in my thread. snellemin and oooscorpionooo have also built really high power bikes on the 26" pies as well.
The mid-size hub is not worth buying IMHO. If you must have it for whatever reason, just get yourself a MXUS kit from cell_man, it'll cost a lot less and perform all the same.
