Two big MACs. One to blow up finding it's limits, one to ride with on a permanent basis
First note is the huge black plastic case and 12 gauge phase coming out of it.
The axle is flipping huge.
22.3mm.. that's a 7/8" shaft size in inches, which seems to be fairly standard.
70mm width, so ~2.7 inches. This would fit inside a bike triangle pretty well.
I'm missing my tape measure and my caliper is maxed out. I'm gonna guess this is 165mm in width ( 6.5 inches ). The plate adds quite a bit of extra width too, maybe the total diameter is 180mm or so ( 7 inches ). I'll get more exact dimensions later.
Ghetto rigged boat chair seat swivel from wal-mart fits over it..
And fits under it.. i could sandwich the motor between these if i wished. Cool!
mock bike mount..
mock bike mount showing chain line..
Okay, opened up now and oh no, shrinkage! apparently the case is very oversized. Oh well, i was warned.
Cooling holes pre-drilled, sorta like the BMC motors..
Magnet diameter, about 23.5mm or so ( hard to measure here )
Total stator circumference is 135mm.
22mm stator width.
Or 28mm with copper..
Hall sensors and what looks like maybe.. a thermistor?
Okay, back to the case... looks like there is a groove that you could use to seal the motor up by inserting an o-ring, or throwing in some RTV gasket maker, to waterproof the motor.
And last but not least.. showing how oversized the motor cover is.
Overall first impression... this is most definitely a lawn mower motor. It's very overbuilt. If redesigned, it could easily shed pound or two for eBike usage. The case size could be drastically reduced as well. I think the 7/8" shaft is going to have to be cut down for eBike usage, and maybe a custom case could be made as well.
Should have some actual motor tests in a few weeks. Life's a bit hectic but you will definitely hear more about these later
