John in CR wrote:I think the best comparison between the motors would be no load current, or if they're wound to different Kv's, then no load watts at the same rpm. A difference indicates a difference in efficiency.
42.6V ?magudaman wrote:BMC Motor @ 52.8v
4470 RPM 4.4 Amps
Reduced speed to 3650RPM 3.65 amps @ 52.6v
magudaman wrote:No 16s lifepo4, measured 52.6v. What made you think otherwise?
TylerDurden wrote:Ja, that makes sense.
No difference in draw with two different hall combos is still a puzzle to me.
John in CR wrote:TylerDurden wrote:Ja, that makes sense.
Yeah, I've only seen that on my 63 slot hubbie. Maybe he change the phases too, in which case we'd expect 3 correct ones for each direction, though Fechter swears there's a BMC with only a 1 in 36 valid combo, which I don't understand how it's possible.
torqueon wrote:Is this still a work in progress, is there a verdict.
Pete
wasp wrote:to get the kv down couldn't one rewind 1 of these motors?
Users browsing this forum: No registered users and 4 guests
