Greentime controllers
whatever
Re: Greentime controllers
Post by whatever » Nov 08, 2015 2:27 am
do you still have original connectors on your controller? The thick red and thick black ( battery power wires) will have another colour with them and a 3 pin connector ( purple on a greentime controller Ihave here). That third wire is your on/off, you connect it to thick red ( positive battery) to make power on.
John Bozi
none
Post by John Bozi » Nov 08, 2015 12:34 pm
Thanks for your reply
Yes of course the thick red and black are the power wires and the thick y g b are the phase wires....
the only colours I have left were mentioned below, I am not sure of some of them....
halls
cycle anaylyst
orange black blue = 3 way switch pretty sure
red green black = probably throttle
purple black = backwards
white black = low level brake
yellow alone = high level brake
white white = can be connected self study
orange orange = can be connected regen
purple with circle ending to nowhere = battery indicator
pink black = cruising control
altermontrealiste
Post by altermontrealiste » Feb 15, 2016 7:08 pm
https://endless-sphere.com/forums/viewt ... =2&t=75887
the one I've got has a brown-blue-purple for anti-theft (anti-theft devices also need voltage from batteries)
brown goes to w pad, so I assume it's for motor sensing
blue goes to a3 (lock motor)
purple goes to vcc
whatever
Post by whatever » Feb 16, 2016 9:38 am
thanks alter....
I read your other thread, you did well to find that old pic of xie cheng controller antitheft wires, must have taken some time.
altermontrealiste
Post by altermontrealiste » Feb 22, 2016 8:26 pm
whatever wrote:thanks alter....
thanks whatever ; antitheft is nice to have...
the picture was in this thread... some good info too... the rest was just logic and opening it up
Larry1984
100 µW
100 µW
Post by Larry1984 » Mar 02, 2016 3:00 pm
Hey guys, I just got a new 12 fet greentime controller that was supposed to have self study, but there is no white wires for it. Can I add them myself or do I have to do it manually.
Thanks
altermontrealiste
Post by altermontrealiste » Mar 03, 2016 8:26 am
Larry1984 wrote:Hey guys, I just got a new 12 fet greentime controller that was supposed to have self study, but there is no white wires for it. Can I add them myself or do I have to do it manually.
Thanks
You can always add wires that go to the corresponding pad on the pcb to customize your controller ; I recommend checking where each wire goes to before relying on the wire's color (not that greentime isn't constant on their wire colors).
https://endless-sphere.com/forums/downl ... p?id=90062 has a list of pads, but did not see what the pads are for self-study...
sketchism
Post by sketchism » Mar 07, 2016 6:11 pm
Hey guys I have the 2015 model 24 fet greentime with 4110s
And I've got my 3 speed switch working by adding the wires to the ZF pad, it was default to mid not high
But my pcb layout isn't like the others listed here and doesn't have the K1 K2 phase timing pads which is what I opened it to do? Would they be labled different in mine maybe a different pcb?
Also my chip/pinout is different too, anyone think there's a chance of programming this one? I would be happy to contribute cash towards the cause, this controller has been brilliant in every other way.
Anyone seen this layout on the greentime 24's? Where would the phase timing advance pads be?
Stay cool - www.hubsink.com (beta testing now open)
Nothing is fool proof to a sufficiently talented fool.
shinyballs
Post by shinyballs » Apr 22, 2016 9:37 pm
I have the 15 Mosfets 84V Sensor/Sensorless Controller and by connective the orange wires, regen does not work. How is the resistor mod working out so far? Any bad side effects on a Greentime controller if I use "electric braking" instead of regen?
Sale section etiquette, pls be courteous to other members, if you know of a better deal or do not agree with the sale price, do not shove links to similar products being sold by someone else in another member's post.. it's just not nice. If you suspect a scam pls FLAG the thread for moderation and it will be checked out... i know this is a tough one to call but put yourself in the seller's shoes and imagine how you would like it.
https://endless-sphere.com/forums/viewto ... 31&t=25446
Rumberopie
Post by Rumberopie » Jun 04, 2016 11:04 am
Someone has managed to change LVC in 36FET controller? To enable the regen with 24s battery?
crossbreak
Post by crossbreak » Jun 30, 2016 12:41 pm
i tried to buy a 15 Fet again from Leo. But he does not answer me on aliexpress. How did you order? I want 4110Fets, no stock controller, otherwise i'd just buy from aliexpress directly. How do i contact him so he will answer? skype?
Samd
1.21 GW
1.21 GW
Post by Samd » Jun 30, 2016 5:31 pm
He only answers when he has your money. Do you need sensorless crossbreak? If not there are a few better option now I think. Pm if info needed. Too many lurkers here now.
http://ballaratebikes.com/
crossbreak
Post by crossbreak » Jun 30, 2016 8:01 pm
yes, sensorless. Otherwise, i wouldnt ask :P (I have many kellys with FOC...) oh that's so exhausting. he didnt answer me so i paid him a 15Fet and said i want 4110's. then he answered he wants more. i told him that id pay what ever he wants. then he didnt answer anymore. i told him that i'd start a dispute if he didnt answer within a week. so he diddnt answer for two weeks, even though i wrote him almost every day :x
is this so hard? i just want a 15 fet with 4110's id even pay him a hundred bucks!! i need it sensorless. ther is NO OTHER OPTION for a sensorless 15fet. even adappto does not work so well from a dead stop from what i heard :( i use these x8m06c from the very beginning ( for 5 years or so) and never found something that can do a start from a dead stop so well in sensorless...so i want it :evil: sure they die if you short the phases and yes, they are load. still i have nothing in spare that is anywhere alike. Said that there is no innovation in this direction from NOWHERE within the past 5 years :shock: or it just didnt make it to us :?
No email? No skype? i'd really like to get hands on a few more of these controllers :(
Skalabala
Post by Skalabala » Jul 13, 2016 4:35 am
I got this one. Just buy 4110s and solder them in?
http://www.aliexpress.com/store/product ... 94528.html
Boosted cars are like hot women. A little edgy, every guy wants one, some guys can't handle them, and if you throw a little alcohol in them they'll rock your world! Born a Jap raised as a boer!
whatever
Post by whatever » Jul 13, 2016 5:32 am
Leo used to also sell irfb4110, he sells genuine ones, there was a thread long time back that looked if Leo was selling the genuine mexico factory made ones or cheap knockoffs, he came up all good, not sure what price he asks these days but they were good price from memory
nicomunet123
Post by nicomunet123 » Jul 14, 2016 4:24 pm
Hello everyone!
Does anyone have a saved copy of flasher software?
On their (xcmmcu) site there is no version 3.0.
Other versiones doesn't work...
Rx, Tx connects to TOOL0
FLMD0 to FLMD0.
Reset to Reset.
Programmer shoud be compatible with NEC MCUs.
Some ppl on russian forum said that FLMD0 can be connected to VCC, Reset can be triggered manually..
crossbreak
Post by crossbreak » Jul 24, 2016 7:36 pm
oh that would be too awesome if someone managed to flash these...do you have a link to the russian forum...some one who actually did it? i'd try again, dont know if i have the right software though, got mine through this forum somehow, not knowing if it actually works
finally i have some 15fet with 4110's being shipped these day, hope they're fine as is. he only programs 50A for them, think this is due layout. they should do more.
Anyway, there should be a form for Leo orders:
1) Type (6 or 36 Fets)
2) Mosfet Type ( he only does those cheap ones, 4410's 4110's, he does not sell 3077 anymore sadly)
3) LVC and HVC, CA-DP Plug (Yes or No), Regen enabled?
4) Name and Adresss
5) Pamyent method
i needed 2 weeks+ to figure out this stuff with him. this could be much faster if you just tell him the above over skype (dont mail him, he wont answer)
nicomunet123
Post by nicomunet123 » Aug 03, 2016 9:28 am
crossbreak wrote:do you have a link to the russian forum...some one who actually did it
Yes, I have. http://electrotransport.ru/ussr/index.p ... 7.0#topmsg .
And still, I didn't tried yet to flash (and nobody on russian forum). But I found some apps, that generate firmware for X8M06 boards from XCM.
All software, documents (most of them in English) could be found here (https://drive.google.com/open?id=0BwLYz ... W5PWE9iaGM).
But I do not have a greentime controller at this moment of time... I have an e-twow kickscooter with some variant of KU63 with adjustable regen. All that is based on X8M06-C, as in Greentime I guess.
crossbreak
Post by crossbreak » Aug 03, 2016 3:25 pm
thanks! Here is the V3 flash program http://www.fileconvoy.com/dfl.php?id=gf ... cc9ca89bbe, should work with those 3-wire FTDI connection. The one i found on google drive is a non compiled Java program i cant compile without installing eclipse. I tried that compiled V3 once, but it didnt connect.
X8M06-C programming.jpg (47.32 KiB) Viewed 1022 times
whatever
Post by whatever » Aug 04, 2016 8:08 am
good info, thanks for sharing, looks promising
nicomunet123
Post by nicomunet123 » Aug 04, 2016 2:03 pm
whatever wrote:good info, thanks for sharing, looks promising
If someone will not understand something (due to Russian language),then feel free to write me, I will try to translate it.
Also I managed to launch the firmware creator, (last post in thread in russian forum), but nobody translated it from chineese...
nicomunet123
Post by nicomunet123 » Aug 04, 2016 3:42 pm
Thank you! It will definatelly speed up the process...
But I have different program, my program generates only 1Kb BIN file, that is quite empty
It looks like this
crossbreak
Post by crossbreak » Aug 04, 2016 4:03 pm
u can use the tool "PantsOff" in WinXP to copy the chinese strings and paste 'em in google translate
nicomunet123
Post by nicomunet123 » Aug 05, 2016 2:44 am
crossbreak wrote:u can use the tool "PantsOff" in WinXP to copy the chinese strings and paste 'em in google translate
I making it slightly different: I decompiled the Jar file, and I am searching all strings and translating them with google.
UPD: Ordered controller from greentime... It is XCM board, C-LA2.2
So, my soft should work with it...
Leo actually is a good seller, he send me photos of PCB...
