by Farfle » Thu Jul 12, 2012 12:37 am
Nothing that extreme, since I put the big tires on, it's overheatind issue got made worse, then I tried to race a turboed WRX from a stoplight, I beat him the first time,I beat him the second time too, but the motor was already really hot. And then sitting at a stoplight for a while let the heat soak, and it demagnetized the magnets, plus that stator iron has been stuffed since the moment I made it, 1kw of no load heat. Im pretty much done with it, A trophy would be a fitting resting place for it.
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 318A at 91v
Peak power out: 24 Hp and 151ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"Team Farfle blog!!
http://www.farfleselectrics.blogspot.com
