I'm planning to replace my ezee controller in an Infineon controller, so I'm going to redo the wiring also. I was hoping to run a single 8 core cable to the handlebars, and was wondering if I could combine the grounds and +5v for the halls and throttle for example. If this is possible then this is how I plan to wire it up using 8 cores:
1 ground
2 5v for hall and throttle
3 throttle
4 hall 1
5 hall 2
6 hall 3
7 brake cutoff
8 battery + for voltmeter
I'll run the phase cables separately as they are really thick, now my question is has anyone else done this? Will it work or will I need to run more than 8 cores?
