MitchJi
Hi,
More models than a few years ago with much lower prices. A couple of years ago they were working on sensored start-up, transitioning to unsensored, not sure if the current models handle start-up and sensored motors.
EDIT: added blog posts from 2009 below.
These might be a good choice for people without the expertise to build a Lebowski Controller?:
http://endless-sphere.com/forums/viewtopic.php?f=30&t=36602
Some blog posts from 2009:
translate.google.com/translate?u=http://www.sinusleistungssteller.de/&sl=de&tl=en&hl=en&ie=UTF-8
http://translate.google.com/transla...istungssteller.de/&sl=de&tl=en&hl=en&ie=UTF-8
Lebowski's motor controller IC, schematic and setup manual
Compact models:23.11.2009:
The target set for this year with respect to the sensor SLS is reached: the software could with the new hardware a motor first turns to limit speed (iM still without load, but in sensorless mode) elicit! Finished, however, the new SW / HW is far, we have you still some (!) Teach subtleties ...
As a sensor, we will first take a AS5040 support. This intelligent Hall sensor generates an "A-quad-B + index" signal represents the absolute angular position even at a SPI interface zV This is important for the correct determination of the initial position, the engine has not yet brought about the index position as long as is! With a resolution of 1024 positions per mechanical revolution he would be good also suitable for high-pole motors. The "drawback" of the matter: the sensor would actually already be integrated mechanically and adjusted by the engine manufacturer in the engine ...
17/10/2009:
The development of sensor-SLS Making Progress: the revised hardware with even more powerful DSP core has arrived. The next step is to transfer and firmware upgrade. We have since set out to do something, because the new hardware is designed to support the sensorless mode as before and allow additional also to operate with position sensors. Then full torque could already be produced with the engine. If we our "normal work" leaves enough time, the first prototype could be ready by early 2010.
Other activities towards higher currents (SLS-60-300) we first postponed. We'll see but well prepared: The prototype of the SLS-60-300 is in progress already and a correspondingly dimensioned engine (Cuba-II) has been tested already at moderate power. Further testing at higher power could always be carried out as soon as time and good weather permit. The top priority at the moment, however, the development of sensor-SLS ..
Larger models:"CSL's ... probably the smallest sine-regulator in the world!"
If it is small, light and yet must be "sine", you are well supplied with the CSL:
eg CSL-60-70
- Battery voltage of 16Vdc to 60Vdc (14S LiPo)
- Motor current to 70Aac
- Fully sealed with screw down cooling plate
- Input ELKOs 900μF/100V/105 ° C (up 1.700μF possible)
- Only about 77mm x 42mm x 36mm
- Only 170g (incl. 20cm silicone cable)
from EUR 549, - (EUR 461.35 plus VAT) delivery time on request
eg CSL-42-75
- Battery voltage of 16Vdc to 42Vdc (10S LiPo)
- Motor current to 75Aac
- Input ELKOs 2.000μF/50V/105 ° C (up 3.700μF possible)
- Only about 77mm x 42mm x 30mm
Price + Shipping time on request (special edition)
eg SLS-60-200
- Motor current to 200Aac
- Sealed with screw-cooling plate
- Screw ELKOs 4.400μF/100V/85 ° C
- About 480g (including 30mm ² Cu bars and electrolytic capacitors)
from EUR 821,10 (EUR 690, - plus VAT) delivery time on request
eg SLS-60-100 1PM ... picture: Version 2
- Motor current to 100Aac
- Input ELKO 1.000μF/100V/85 ° C
- About 360g (incl. 20cm silicone cable, Cu Rail & ELKO)
from EUR 761.60 (EUR 640, - plus VAT) delivery time on request
