speedmd
I came across this lightweight, relatively low RPM high power motor that looks promising for a mid drive build by flytec. Any one have experience adapting one.
Some specs.
HPD 10 – Technical data
Specific idle running speed: 47 1/min/V
Specific nominal load speed: 42 1/min/V
Rotational speed limit value: 2500 1/min
Rated current: 190 A
Max. motor current: up to 230 A (according to fresh air cooling)
Max. stator temperature: 100° C
Rated input power: 10'000 VA
Nominal effectiveness: approx. > 93%
Linternal resistance phase to phase: 7.8 mOhm
Total inductance phase to phase. 14.5 µh
Ri 7.8 mOhm
Coiling number: 36
Magnetic pole number: 42
Coil number: 18/36
Torque constant: 0.22 Nm/A
Hallsensor feedback: without
Vector group: delta
Weight incl. connecting lines: 3.75 kg
Dimensions: diam. 21.8 cm – length: 7.1 cm
http://www.flytec.com/edrive.html
Some specs.
Ri 7.8 mOhm
Coiling number: 36
Coil number: 18/36
Vector group: delta
