INSANE HUB MOTOR!
Doctorbass
INSANE HUB MOTOR!
Post by Doctorbass » Oct 03, 2016 6:53 pm
Here is my new Hub motor being prepaired for drag racing! :twisted: 0.41MW :twisted: :twisted:
Problem is that i have to find the bike to install ity to ! :lol:
Doc
INSANE hub motor rebuilt (Personnalisé).jpg (107.42 KiB) Viewed 1921 times
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
https://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
liveforphysics
Re: INSANE HUB MOTOR!
Post by liveforphysics » Oct 04, 2016 2:04 am
Something around that scale but designed for minimum mass will be what obsoletes top fuel dragsters, and they will be reliable and cost $1-2 in electricity rather than costing $50,000usd per pass for a full engine rebuild.
liveforphysics
Post by liveforphysics » Oct 04, 2016 2:25 am
eTrike wrote:
liveforphysics wrote:Something around that scale but designed for minimum mass will be what obsoletes top fuel dragsters, and they will be reliable and cost $1-2 in electricity rather than costing $50,000usd per pass for a full engine rebuild.
Skunkworks project? :twisted:
Not on my personal budget (saving for P100D), but if someone with the right funding wanted to make it happen, I'm sure we could work something out. 8)
Rube
Post by Rube » Oct 04, 2016 4:44 am
No alloy stator no care lol So now you are racing ships? :twisted:
Arlo1
Post by Arlo1 » Oct 04, 2016 9:50 am
I'm in
My Leaf motor controller build. viewtopic.php?f=30&t=63982&p=963227#p963227
My YSR build http://www.youtube.com/watch?v=BRo8r5g4NBg
RC and most types of Lithium batteries you MUST know your individual cell voltages charging and discharging.
Don't keep them were you cant afford smoke or fire!
HI power controller design. Game Changer
http://www.undergroundelectrics.ca/
Wheazel
Post by Wheazel » Oct 05, 2016 10:15 am
What power would be needed to achieve top fuel performance? How much margin does todays tech have to a "lift myself in my own hair" equation? Are the batteries needed to deliver the burst light enough? I remember Doctorbass using those special drag racing lipos for the 2wd nyx. Overall I have little clue about what forces we talk about with topfuel. I want to remember I have heard 8000hp somewhere sometime. Accurate? How heavy is a top fuel drive line?
I think its a very interesting concept, and I would be surprised no one has pursued it if the technology infact is easily available.
Arlo1
Post by Arlo1 » Oct 05, 2016 11:07 am
Wheazel wrote:What power would be needed to achieve top fuel performance? How much margin does todays tech have to a "lift myself in my own hair" equation? Are the batteries needed to deliver the burst light enough? I remember Doctorbass using those special drag racing lipos for the 2wd nyx. Overall I have little clue about what forces we talk about with topfuel. I want to remember I have heard 8000hp somewhere sometime. Accurate? How heavy is a top fuel drive line?
Top fuel cars are at ~10000hp
You will need close to that with electric. They have a clutch system that lets them rev the motor up then dump the stored energy to the wheels abruptly.
That gives them a huge launch as well lets them get close to peak HP off the line.
If I had to guess. With a good motor controller and a 200c rated battery 8000hp electric would do what a 10000hp nitro car could do.
Hillhater
Post by Hillhater » Oct 06, 2016 6:53 pm
Asuming you could find a motor, controller, transmission,etc to suit the 8000 hp needed, i suspect it will condown ro battery as the critical factor.
A little number crunching indicates that a pack would need to be capable of 6000A at 1000v for 8000 hp.
That would imply a 30Ahr pack of 200C cells, which at 150Whr/kg would mean 200 kg weight of cells !
Arlo1
Post by Arlo1 » Oct 06, 2016 11:35 pm
Hillhater wrote:Asuming you could find a motor, controller, transmission,etc to suit the 8000 hp needed, i suspect it will condown ro battery as the critical factor.
Not bad But I would rather 12000A at 500v
Or 2 6000 amp 500v controllers.
1000v is not a good idea.
200kg for cells is not bad.
Skalabala
Post by Skalabala » Oct 13, 2016 10:49 am
I've got a sneak snapshot of what the mad scientist Mr Bass is up to
Boosted cars are like hot women. A little edgy, every guy wants one, some guys can't handle them, and if you throw a little alcohol in them they'll rock your world! Born a Jap raised as a boer!
Doctorbass
Post by Doctorbass » Oct 14, 2016 6:46 pm
John Metric is already using 8000 Amp of Zilla controller.. but guess what?!!.. he is now working on Brushless motor project!! :twisted:
Doc
Arlo1
Post by Arlo1 » Oct 15, 2016 1:43 am
Doctorbass wrote:John Metric is already using 8000 Amp of Zilla controller.. but guess what?!!.. he is now working on Brushless motor project!! :twisted:
Doc
Any more info? All I have seen him post is more brushes....
Doctorbass
Post by Doctorbass » Oct 15, 2016 8:40 am
Doc
here it is. i think he is building a controller for it too.
https://m.facebook.com/story.php?story_ ... 712189084
Arlo1
Post by Arlo1 » Oct 15, 2016 11:59 am
Ok thanks. I remember it now. Multiple controllers. Its in the works. These things take time. LOTS of time.
jmetric
Post by jmetric » Feb 20, 2017 1:04 pm
Here is the new BLDC motor..
and the projected dyno sheet
you could mount that in a hub somehow?
I think the hub of a hyperloop pod maybe?
liveforphysics
Post by liveforphysics » Feb 20, 2017 2:04 pm
That looks like the right size motor John!!
jmetric
Post by jmetric » Dec 22, 2017 11:18 pm
Guess what I just weighed my new car Extinction Level Event with the new BLDC and the new 200C Sleeper Cells.
Total weight loss for identical power output=1100lbs.
Car dropped from 2650lbs to 1550lbs.
Very happy but now have to regear for the new weight.
liveforphysics
Post by liveforphysics » Dec 23, 2017 3:06 am
What a splendid problem to have my friend!
litespeed
Post by litespeed » Dec 23, 2017 9:00 am
That is just amazing to loose that much weight. Can't wait to see this new light weight one in action.
Tom
