DeamEyes
100 µW
A while back I began building an imitation of Adrian/Kepler's friction drive and have finally had all the necessary resources to hook up the motor/esc portion (or so I thought). I hooked up the motor to the ESC and plugged in a 5S battery that was fully charged and the ESC makes the turn-on noise, but then proceeds to beep once a second. I tried hooking up a programming card to it, but the LEDs did not light. I tried interfacing with it using an Arduino clone and various ESC sketches, but no response. Finally I questioned if the control wires are bad for some reason; I tested the +5v wire and ground and have no current running through it.
Is there an issue with this ESC, or is there something I seem to be doing wrong?
ESC: Turnigy Sentilon V4 100A 5-12s HV Bulletproof Speed Controller w/RPM Sensor and the motor
Motor: Turnigy Aerodrive SK3 - 6374-192kv Brushless Outrunner Motor
MicroController: OSOYOO Mini USB Nano V3.0 ATMEGA328P Module CH340G 5V 16M Micro-controller board for Arduino
