I have an option to enter a motor race class, and they have different current limits at different voltage.
I can only use this one motor that is rated to peak power 24v 600w and 36v 1400w.
In this power limiting classi have to limit to either 24v 10a i.e 240w battery watts. or either 36v 7a i.e 252w. i.e 12w more at 36v.
the issue is the motor is way over powered so limiting down from 36v 1400w down to 252 battery current limit the duty cycle may be only like 50% ??
whereas at 24v I would get a lot closer maybe not 100 but maybe 90% duty cycle to get the power down from 600w to 250w.
now the question is what is the difference in losses ? and is going to 36v worth the free extra 12w ? or will I loose more than 24v going from say 90% duty cycle at 24v vs 50% dity cycle at 36v ?
note efficiency is very important for this so I need the most efficient setup, will be using an FOC controller or trapezoidal controller
