edit:
in the usermanual is written: Trouble: the sensored motor doesnt work....solution: check the wire connection.
you have to read between the lines
Ludo91 wrote:Hi,
it`s time for me to buy the sensor. DigiKey run out of honeywell SS411, do you think this http://search.digikey.com/scripts/DkSea ... 8920692357 will fit? I looked at all the specs and they seems to be the same, correct meif i`m wrong
AussieJester wrote:Ludo91 wrote:Hi,
"Item not found" comes up when i click the link
KiM
benediktsamuel wrote:hey...
Its me again.....could you tell me something aubout the non Load Current? I´ve got a Brushless outrunner with a non Load current of about 5 A and with the Sensoring it has a Non Load Current on 9 A.....
So My question......Is The timing soooo Bad or is that normal??
Users browsing this forum: No registered users and 4 guests
