How to winding brushless motor
pawulon
Post by pawulon » Nov 11, 2017 4:54 pm
Hello all
First, sorry for my english
I have a motor as on the pics it is a stator TRW power stering pump motor has 12 rotor slots 7 magnets.
https://www.youtube.com/watch?v=tFH1XMlEj4Y
The stator is wound in such a way that it has 8 pins.
I want to wind it like a standard brushless motor and use it for my bike
Power from this controller
https://www.aliexpress.com/item/Free-sh ... 0aec7e78a6
Can you connect in the current winding?
If not how to scroll it?
what wire
how many turns
Thank you all for your help
(225.41 KiB) Downloaded 6 times
(194.1 KiB) Downloaded 6 times
Buk___
Re: How to winding brushless motor
Post by Buk___ » Nov 12, 2017 3:36 am
pawulon wrote:I have a motor as on the pics it is a stator TRW power stering pump motor has 12 rotor slots 7 magnets.
A BLDC motor has to have an even number of magnetic poles, so "7 magnets" is a bit weird.
My guess is that each of those 7 segments is magnetised with 2 poles on the same face similar to those used in the actuator motors in hard disk drives.
That would make your motor a 12N 14P motor which are very common, and there are many online guides to winding them.
eg. This one.
pawulon
Post by pawulon » Nov 12, 2017 4:41 am
Well, maybe I did not think about it.
How to wire up to get out of it as much power but to not overheat it and not burn it
How would I make 18 threads with 1mm wire would it be good?
I need to wind up to get 350-400 kV
maybe that's? https://www.youtube.com/watch?v=-sIVpOLYoqg
I have a choice of a lot of wire and Litz Wire
