MOSFETs near their voltage limit
1N4001
Post by 1N4001 » Dec 19, 2017 9:27 am
Hey, a quick question.
When selecting FETs for a motor controller, would it be a good idea to keep some breathing room between VDS and battery voltage?
I am considering a 14s battery pack which, fully charged, comes very close to the 60V absolute maximum rating of most common MOSFETs. I could select 80V ones, but will have to deal with higher RDS(on) and QG.
Thanks for any advice.
Addy
Re: MOSFETs near their voltage limit
Post by Addy » Dec 19, 2017 11:12 am
It's absolutely a good idea to keep some breathing room. 14s x 4.2V = 58.8V, very close to the limit.
When a MOSFET in your controller turns off and stops the current flow, the inductance of the battery wires will try to keep the current flowing by increasing the voltage. This means that your controller will see a voltage spike which is higher than the battery's voltage. If you went with 60V MOSFETs you would have almost no margin to tolerate this.
Punx0r
Post by Punx0r » Dec 19, 2017 4:44 pm
I have heard a rough guide to allow at least 20% for voltage transients. However, I cannot substantiate this and there's a continuous sliding scale between conservativeness in design and reliability offset by increased cost & lower power density. Hobbyists will sometimes run 0% margin while someone design a critical system might want more like 50%...
A lot of ebike controllers rated up to 48V nominal are 60V max and use 75V FETs.
Gregory
Post by Gregory » Dec 19, 2017 5:58 pm
As an amateur I use 20% for MOSFETs and 50% for caps.
1) x5305 Hub Motor in a 24" Sun rim with 10G spokes, Kelly 72601 controller, 74V 10Ah Turnigy LiPo 20C Battery and CycleAnalyst
2) Mac 10T rear hub in a 700C "comfort bike" 15S 5Ah LiPo, stock 28A Xie Cheng controller
3) 38" Longboard, Turnigy 6374, CC Mamba XL2 ESC
1N4001
Post by 1N4001 » Dec 20, 2017 3:59 am
Thanks, that helps. I'll be going with 80V ones then. Cheers!
