Hello, I'm new around here. I'm working on a project where I'm looking for a ~10kW motor that is affordable and capable of regen. I've found the Turnigy Rotomax 150 which claims 9.8kW, and a PowerVelocity 15kW bike controller with regen. Will these pair well together? (I may need to add a hall effect sensor to the motor) From my reading they seem to, but before I spend $900 I figured I should check.
I hate being the new guy asking possibly obvious questions, but I did search this forum before I made the post...
Turnigy Rotomax 150 motor
https://hobbyking.com/en_us/turnigy-rotomax-150cc-size-brushless-outrunner-motor.html
Spec.
Battery: 14 Cell / 51.8V
RPM: 150kv
Max current: 190A
Watts: 9800w
No load current: 51.8V/5.2A
Internal resistance: 0.011 ohm
Weight: 2530g
Diameter of shaft: 10mm
Winding: 8T
Stator Pole: 24
Motor Pole: 20
Stator Diameter: 101
Lamination Tickness: 0.2mm
Suggested ESC: 250A 14S Compatible
PowerVelocity 15kW controller
http://powervelocity.com/index.php?id_product=55&controller=product
Spec.
Sinewave power modulation makes motor run very quietly and vibration free
A wide range of features programmable wirelessly from an Android or iOS/iPhone device
Voltage operating range 24-100v, 36-120v or 70-150v
Battery currents up to 150A
Phase currents up to 300A
24 Genuine low resistance (RDS) MOSFETs
Finely adjustable regenerative brake force
Input for 3-position speed or power level switch
Cruise control input
Configurable hard or soft start options
Larger and stronger box for better heat dissipation and performance
Adjustable magnetic flux weakening for higher speeds and efficiency
Tested top unloaded speed with flux weakening enabled: 130mph at 100v
Size 250 x 120 x 70 mm
Weight - 2.3kg
Bluetooth programming via Android/iOS is now included standard
Spec.
RPM: 150kv
Max current: 190A
Watts: 9800w
Weight: 2530g
Winding: 8T
Stator Pole: 24
Motor Pole: 20
Spec.
Weight - 2.3kg
