Front hub motor cable inlet protection?
wilca428
I search for front hub motor cable inlet protection, that can withstand some rough handling. Maybe I lack the right words for it. Anybody?
Only for motors w/ 10 m/m axles;
http://www.ebikes.ca/shop/electric-bicycle-parts/u-bracket.html
I need someting bigger that protects the cables from the u-turn and some 5 centimeters up on the fork. When the u-turn part is unprotected it gets snagged in.
I found the Grin part very effective. Simple and extremely strong.
I haven't tested mine :D , but if it won't protect the cable, something isn't routed right.
I have a similar question: where can one get the spring/strain relief that commonly comes slipped over the phase wires where they exit the axle on hub motors. I seem to have lost mine.
@ -dg ; 302 stainless steel extension spring stock https://www.mcmaster.com/#coil-springs/=1cmsfka
