BMC hub motor Ebike conversion kits from $400
Re: BMC motor, Crystalyte 35A controller, Cycle Analyst $690
Postby nightowlgk » Thu Sep 17, 2009 12:16 am
Ilia built a kit for me and it is very nice. He was extremely responsive to all my emails and painted the hub black to match my bike.
Finally got batteries to handle the controller amp draw. My DIY, patent Pending "Bosch Torpedo Fatpack". http://www.endless-sphere.com/forums/viewtopic.php?f=14&t=13037&p=193145#p193145
The basic Throttle is not as smooth as I would like....I will try to switch to a Magura I have if i can get the wiring right.
My rides have been totally fun and it eats up most of the hills in Ventura County. Easily gets to 25mph on the flats. Not very noisy at all.
I LOVE IT! Thanks Ilia. :D
DAHON MATRIX 2009 26" folding MTB w/ Thudbuster, Origin 8 spacebars.
BMC V2 speed model from Ilia Brouk w/ 7 sp. freewheel
CLYTE 36-72v 35 amp analog controller CLYTE Twist Throttle
Cycle Analyst 2.1
Ping 15ah 36v BMS set to 40amps continuous- mounted in triangle.
Also: Torpedo Battery. 3- Bosch Fatpacks in plastic tube.
Previous bikes:
Wavecrest Tidal Force M-750X, S-750X
Currie I-Zip Cruiser Enlightened Nimh - smooth and light but underpowered
WE-600w brushless SLA
nightowlgk
1 W
1 W
Postby toddcarpenter » Thu Sep 17, 2009 8:30 am
You absolutely can't go wrong with ilia and his kits. I had some issues with mine and he was always quick with e-mails and educated me a lot in e-bikes and what to expect from this kit and how to make it last. I highly recommend buying from him. You won't be sorry.
Todd
5304 with 12fet 35amp controller on Haro Heartland Comfort bike
5305 with supposed 45amp controller on Haro Heartland Comfort bike that won't pull over 30amps for some reason.
Golden Motor Front on a Walmart Next bike that runs pretty well, but the bike isn't that comfy
2 9c fronts and a future 5306 rear for a trike project
toddcarpenter
Postby oatnet » Thu Oct 22, 2009 8:47 pm
I'd hate to see this thread scroll off so I'll give it a bump.
-JD
oatnet
Postby Crash Machine » Thu Oct 22, 2009 9:11 pm
Will a front version of the V2-T be available? If so I might be interested. It's hilly where I live and I need to haul my BOB trailer. If so put me down for one in about a month or whenever I trash another gear(which I just replaced one today). It's time for me to upgrade. I'll only be running at 48v so...
5304 front disc motor/4840 controller on
Mongoose full suspension MTB
48v 10 Ah headway battery/48v 15 Ah Ping battery
Recently completed 2000 mile tour of Southeast United States.
"If you don't stand for something, you will fall for anything."
Crash Machine
Postby Canis Lupus » Sat Oct 24, 2009 9:58 am
I've bookmarked this thread. I'm interested.
Do you post internationally, to Greece? If not, how much would postage cost to Florida, my brother's address?
It's basically the same kit I was looking at putting together although I did want the option of eventually running a 72 volt combination sometimes. The controller provided would need to be upgraded for me to do this.
Canis Lupus
Postby nicobie » Sat Oct 24, 2009 1:23 pm
I believe the controller that Ilia ships is a 72v one.
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: viewtopic.php?f=6&t=23701
nicobie
Postby TPA » Sat Oct 24, 2009 1:46 pm
I purchased the controller and CA that Ilia sells. The controller is the 24-72v Crystalyte analog start immediate controller. He even calibrated the CA to the controller for me. Fabulous stuff!
Ilia has not posted since august, but I see he logged in today. He also puts the motors for sale on ebay at times.
One of these days, I plan on getting the entire kit from page 1. I hope he offers the kit again at that price, it's a steal.
My Ebike is built with a hub motor purchased from www.ebikes.ca
It has performed flawlessly since it was installed. I cannot
recommend the professional folks there enough.
TPA
Postby Guest » Sat Oct 24, 2009 7:21 pm
Is this still available?
Guest
Postby Canis Lupus » Sat Oct 24, 2009 7:59 pm
nicobie wrote:I believe the controller that Ilia ships is a 72v one.
So it is, even better. Thanks. :D
Canis Lupus
Postby oatnet » Sat Oct 24, 2009 9:55 pm
It is, I just bought one of the 72v35a analog xlyte controllers from Ilia, I am a repeat customer. I'd contact him directly.
-JD
oatnet
Postby Canis Lupus » Sat Oct 24, 2009 10:07 pm
^ Done. Thanks
Canis Lupus
Postby ebikes-sf » Sat Nov 07, 2009 12:22 pm
Thanks for your comments everyone!
I sill have 600W kits with speed or torque motors (see 1st post).
Also available BMC 1000W motors for $495
ebikes-sf
Postby TPA » Sat Nov 07, 2009 7:11 pm
Is that crystalyte digital controller working with the 1000w motor?
TPA
Postby jesuss » Wed Nov 25, 2009 1:39 pm
hello can you send this to spain? how much is the shipping? thank you
jesuss
Postby ebikes-sf » Sun Nov 29, 2009 5:06 pm
TPA wrote:Is that crystalyte digital controller working with the 1000w motor?
Just did a few road tests with BMC 1000W motor. Well, the results are not impressive. At 50V there is no difference in performance between Crystalyte 35A analog and 50A digital controllers, except that with digital, motor is jerky on take offs (between 0 and 3 mph), and with analog controller, take offs are very smooth. So I'm no longer offering Crystalyte digital controllers.
At full throttle, on take off motor consumes 15 amps, 10mph - 20amps, 15mph - 25amps, above 25mph 29-32amps.
Also, it seems 600w speed is slightly slower but has more torque than 1000w.
BMC claims that V3 motor goes 40mph with their new 50amp acontroller, I will have those controllers available around mid December. V3's are available for $495.
ebikes-sf
Postby ebikes-sf » Mon Dec 21, 2009 4:21 pm
There was some delay in production of BMC 50A controllers, I should have them after January 10th.
ebikes-sf
Postby ebikes-sf » Mon Jan 11, 2010 1:11 am
To address questions from a few people about differences between different BMC motor models (to my best knowledge):
600 w torque (V2T)
Coils are made out of thinner wire and have more turns therefore motor has more torque at lower speeds but has lower top speed than V2S or V3. Top speed in 26 inch rim @ 50V 30A is about 24-26mph. Motor tends to heat more than V2S and V3 while climbing hills (at lower speeds).
600 w speed (V2S)
Coils are made out of thicker wire and have less turns than V2T - this is the only difference. Top speed in 26 inch rim @ 50V 30A is about 29-31mph.
1000W (V3)
Coils are made out of thicker wire and have less turns than V2S. Gear/clutch assembly mounting has improved from V2. Top speed in 26 inch rim @ 50V 30A is about 30-32mph. This motor is able to withdraw more current/energy (at higher speeds) than all other BMC motors. I have not yet tested it with new 48v 40A controller - i should be able to do so and post results around Jan 17th.
ebikes-sf
Postby dannyboyohyeah » Mon Jan 11, 2010 12:06 pm
I see this is a rather old post. Wondering if this kit is still available???? It's exactly what I've wanted ...but I have one question...between the torque version and the speed version, would you say the speed version is still capable of climbing hills well? What are the top speeds (on the flat) for each of these for example, at 48v? Thanks
dannyboyohyeah
Postby The Mighty Volt » Mon Jan 11, 2010 12:42 pm
Hi there
I own a 48v 20 AH duct-tape battery and a 36v 20Ah battery.
I am looking for a very torquey but also very reliable rear brushless hub with internal gearing.
I would be grateful to hear of any offers you have that suit my batteries
Is the original offer still available, and will it suit my battery packs?
Many thanks :mrgreen:
PS do you ship to Ireland?
The Mighty Volt
Postby ebikes-sf » Tue Jan 12, 2010 7:51 pm
Yes, I have BMC 400W (V1) front. BMC 600W (V2) Torque or Speed rear, and V3 motors and kits available. I can ship worlwide. For your batteries I recommend a kit with BMC V2 speed or torque motor, I prefer speed motor - less torque at lower speed (still plenty to deal with hills) but higher top speed. The original offer still stands please see first page of this thread for details.
ebikes-sf
Postby HTB_Terry » Wed Jan 13, 2010 3:01 am
I just tested one Ilia's bikes on some San Francisco hills. He had his daily commuter bike, a rather clunky looking rig consisting of an old frame with the extra cycle attachment. I was not exactly blown away by the looks. Hidden under the pannier bags was the BMC 600W speed version. What a sleeper! The acceleration off the line was quick. I flew up the first hill, maybe 10 deg. The next hill was a little steeper, maybe 15%, and again it cruised up with light pedaling. I was getting impressed. Then we came to a real steep hill, maybe 18%, maybe even 20%. It made it up with moderate pedaling in a mid to high gear. Very impressive indeed. What was interesting, it only seemed to be drawing 20-25 amps on the hills. It was a 48V pack topped off at 50V so it was pumping quite a bit of power, but seemed to be satisfied with that and demanded no more. As we hit a straight away, I hit the throttle and the current jumped to 30-35 amps during acceleration. The speed was scary and I was too chicken to go full throttle. The torque of this motor was exceptional and I personally would have no need for the torque model. Maybe if you weighed 250 pounds and carried a huge cargo, you should consider it. I would like to see how it performs with a 36V pack. Ilia said he was working on a new cargo/commuter bike which sounded perfect for SF. I'm sure I will end up purchasing a few of these kits for some high end builds. I can recommend the BMC600-S for those killer hills and also Ilia who is the resident expert on them.
HTB_Terry
Postby Canis Lupus » Wed Jan 13, 2010 3:21 am
HTB_Terry wrote:I just tested one Ilia's bikes on some San Francisco hills. He had his daily commuter bike, a rather clunky looking rig consisting of an old frame with the extra cycle attachment. I was not exactly blown away by the looks. Hidden under the pannier bags was the BMC 600W speed version. What a sleeper! The acceleration off the line was quick. I flew up the first hill, maybe 10 deg. The next hill was a little steeper, maybe 15%, and again it cruised up with light pedaling. I was getting impressed. Then we came to a real steep hill, maybe 18%, maybe even 20%. It made it up with moderate pedaling in a mid to high gear. Very impressive indeed. What was interesting, it only seemed to be drawing 20-25 amps on the hills. It was a 48V pack topped off at 50V so it was pumping quite a bit of power, but seemed to be satisfied with that and demanded no more. As we hit a straight away, I hit the throttle and the current jumped to 30-35 amps during acceleration. The speed was scary and I was too chicken to go full throttle. The torque of this motor was exceptional and I personally would have no need for the torque model. Maybe if you weighed 250 pounds and carried a huge cargo, you should consider it. I would like to see how it performs with a 36V pack. Ilia said he was working on a new cargo/commuter bike which sounded perfect for SF. I'm sure I will end up purchasing a few of these kits for some high end builds. I can recommend the BMC600-S for those killer hills and also Ilia who is the resident expert on them.
What was the wheel size? I have a 20" rear wheel. It sounds as if I ought to be going with the speed version given the smaller wheel size will help with torque in any case.
Canis Lupus
Postby The Mighty Volt » Wed Jan 13, 2010 2:09 pm
Is spoking these things difficult? What sort of spokes and alloy combination could I use?
The Mighty Volt
Postby nicobie » Wed Jan 13, 2010 2:20 pm
The Mighty Volt wrote:Is spoking these things difficult? What sort of spokes and alloy combination could I use?
I'd take it to a bike shop and have them do it. It's not that expensive.
For a 2X pattern I think the spoke length is 216mm in a sun rhyno lite 26" rim, but Ilia can help you on that.
nicobie
Postby The Mighty Volt » Wed Jan 13, 2010 2:56 pm
Would you believe, I was trying to avoid taking ANY of my ebike stuff near any bike shop........let them get their own sales ideas!! Also, they happen to do all the work for the Police in my area {we have Police on bikes in Urban areas, they patrol pedestrian walkways etc}..and I dont want attention drawn to myself.
That said, thanks for the response. :lol: :lol:
The Mighty Volt
PreviousNext
Return to Items for Sale - New
Who is online
Users browsing this forum: bra and 5 guests
