TPA wrote:As far as I can tell, Ilia only checks this forum occasionally. Send him a PM. This will also go to his email, which gets checked more frequently.
nicobie wrote:I have a different controller with the same motor and at 1000w for ½ mile the motor isn't even warm. I run mine @1500w all the time with no heat problems. Max watts shown on my watts-up is 2400![]()
Nick
ebikes-sf wrote:Some cons and pros of geared hub vs direct drive hub like crystlyte, tidal force, golden motor, A2B, etc.
Pros:Higher torque especially at low RPMs
More top speed
More efficiency due to higher motor speed
More power per weight ratio
Freewheeling
Cons:More moving parts = less reliablility
Higher cost
No regeneration (because of freewheeling) - however regenration from smaller hub is insignificant anyway
Not for heavy offroad use
General user experience after trying geared motor like BMC is: going back to direct drive is a big step down regardless of cons listed above.
scriewy wrote:can any 1 tell me ilias paypal ?
thanks
scriewy wrote:
he rarely checks PMs as mentioned in this thread.
.png)
auraslip wrote:Sorry I'm late, and this maybe a question that should be obvious but; what type of performance could I expect from this kit when limited to 35amps?
With 48v 20ah lifepo4 cells what would be full throttle speed on the flats?
What about 36v 20ah?
Return to Items for Sale - New
Users browsing this forum: bowlofsalad and 1 guest
