Custom 11, 12, 13, 14, 15 gauge spokes and Handbuilt Wheels
Re: Custom 11, 12, 13, 14, 15 gauge spokes and Handbuilt Whe
Postby Hardcarve1 » Fri Feb 10, 2012 3:56 pm
John,
Just placed an order for 80 x 13/14g silver spokes but there was some problem with the bpay so I sent a message through your online help. Just though I may mention it on here as well as I need to get my wheels repaired. I just get too many broken spokes when I use straigh 13g and have read a lot about how the wheel may be not flexing to absorb the bumps.
Alex
When in doubt, REV!! it out.
MTB - HXT80-130 direct drive through staton 1:18.75 gerbox, HV160 ecs, Nuvinci hub, 12s A123 9.2ah (retired)
MTB - 9C stock, 12 fet Lyen, 9 speed, 16s A123 20.0ah, 2000lm LED ebike lights.
Line trimmer - HXT80-130, HV110 ecs 12s A123 2.3ah
Hardcarve1
Postby johnrobholmes » Fri Feb 10, 2012 4:50 pm
Alan,
Hit me up through my website, or check out the Ebike section for the details on sending parts my way.
dscline,https://sss-web.usps.com/cns/landing.do
I recommend 13/14 butted spokes for sure, or else regular 14ga spokes.
Fractal,
Glad you like them! Should be a blast to ride! How did the packaging hold up? Its a long way for 20 kilos of box!
Neil,
I mostly use 12ga and 13ga for moped rims. Have you thought about drilling your rims for a thicker spoke to work with your machine?
My 11/12 butted spokes will be 11ga at the head and 12ga at the thread.
A 17x 2.5 gazelle is just at 22" tall if I recall properly.
Hardcave,
You can send a payment for goods direct to paypal@holmeshobbies.com, or else place a new order and I will cancel the other. Please reference the order number in the payment.
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
Postby NeilP » Tue Apr 24, 2012 2:37 am
johnrobholmes wrote:Neil,
I do not think I would need to drill the rim for bigger spokes, it would be more a case of drilling the hub to take the bigger spokes. Will have to wait for the 5405 to arrive. I think I had seen the review thread that said the holes in these hubs were bigger anyway.
But will not even order the spokes till I have both hub and rim in hand and I can make my own measurements. Need to see about offset too, before i can work out lengths needed. I have gone for a 150mm axle, and think it is going to ge mounted in a custom rear swing arm..so o idea yet if any offset it going to be needed yet. Depends on my torque clamp and swing arm setup
Mongoose frame, Fox F100 forks,26x2.3 tyres
180mm disks
100V 20Ah LiPo
Lyen 18 FET 65 Amp,5304 in 26 inch Mavic rim
To illustrate the vain conceit that the universe must be somehow pre-ordained for us, because we are so well-suited to live in it, he mimed a wonderfully funny imitation of a puddle of water, fitting itself snugly into a depression in the ground, the depression uncannily being exactly the same shape as the puddle."
-- Richard Dawkins, in "Lament for Douglas" (14 May 2001)
NeilP
Postby johnrobholmes » Tue May 01, 2012 6:43 pm
The 11/12 swaged spokes are here, and I am leaving the country for a week tonight :lol: I'll try to get a product made while on the lamb, but it will probably have to wait until I get back.
I'll be back late next week, pardon my absence.
Volt up, gear down!
johnrobholmes
Postby ohzee » Tue May 01, 2012 6:58 pm
What you doing on your trip if I may ask ? Business or Pleasure ???
ohzee
Postby johnrobholmes » Sun May 06, 2012 2:55 am
Both. Taking a Honeymoon with my wife and visiting a factory that supplies about 1/2 of my livelyhood, in Japan. Spoke orders are on hold, but all other orders are going out normally.
Volt up, gear down!
johnrobholmes
Postby Xrain » Sat May 12, 2012 12:45 am
Hey John, when you get back from your honeymoon, I am looking at finally getting some spokes to lace up my hub with.
Could you give me spoke gauge/length recommendations for:
- Alex DX32 26" 36H wheel
- Crystalite HS3540 Hub
Thanks!
Xrain
Postby johnrobholmes » Tue May 15, 2012 5:00 pm
I don't have the measurements for the hs35 hubs here, I laced a few and totally forgot to record them.
Sorry for being hard to get ahold of lately, I still haven't caught up from my travels and there are still about 400 emails left to finish.
Volt up, gear down!
johnrobholmes
Postby voicecoils » Wed May 16, 2012 2:29 am
Xrain wrote:Hey John, when you get back from your honeymoon, I am looking at finally getting some spokes to lace up my hub with.
Thanks!
You can calculate spoke length your self by first measuring rim ERD and then using the hub details in the http://ebikes.ca/SpokeCalc.shtml (check measurements yourself of course).
To find ERD, use the tutorial here:
http://www.bikeschool.com/tools/spoke-length-calculator
(Click on 'Spoke Length Tutorial')
Cheers.
voicecoils
Postby Hobbit » Wed May 16, 2012 6:36 pm
Yeah but how was Japan?
"The Precious"
Rans Fusion, Crystalyte H4080, Crystalyte 75V 50A stock controller,
66.6V 18s3p 24Ah zippy lipo.
http://endless-sphere.com/forums/viewtopic.php?f=6&t=37934
Love.
Hobbit
Postby 7lions » Fri May 18, 2012 10:18 pm
I just failed the stock 20" rim provided with an HS35. I knew it was going to go, but didn't expect it this soon (around 200 miles). I'd like to fix this just once, so I'd love to get your recommendation on rim and spokes to lace up in a radial pattern. 12ga are unfortunately necessary, as the holes in the flanges are HUGE. I'm not opposed to going moped/DOT, but I do need to keep the total diameter under 20".
7lions
Postby pchen92 » Sat May 19, 2012 7:53 am
Hi,
I have sent you 2 mails but still hasn't got any answer.
I received your spokes a couple weeks ago. They look really strong :D and they are pretty good quality but I received the wrong size :?
I ordered 141mm and just after I order, I notice the rim I was looking for was out of stock so I change for 137mm. You said it was ok and you have changed the order.
But I received too long spokes... Looks like they are 143mm or so.
Giant DH Team
Cromotor 18s3p Kelly KEB72101
viewtopic.php?f=6&t=41896
pchen92
Postby pchen92 » Mon May 21, 2012 4:34 pm
Up :? :oops:
Giant DH Team
pchen92
Postby johnrobholmes » Mon May 21, 2012 5:23 pm
Paul,
email your way. Apolgies for the latent response, I'm still really buried from my trip and things aren't getting much better by the day :oops:
7lions,
12ga spokes laced into a 16" moped rim would be my personal choice. You could get away with one cross like this.
Volt up, gear down!
johnrobholmes
Postby GCinDC » Tue May 22, 2012 7:46 am
JRH, can you define spoke length?
is it measured from thread end to center of butt end, as in:
Youtube channel, 2011 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (10Ah), hs3540, 72V 45A 12FET, 900W BMSBattery charger.
GT I-Drive, 20s lipo, 9C, 72V 45A 12FET.
GCinDC
1.21 GW
1.21 GW
Postby johnrobholmes » Tue May 22, 2012 8:30 am
I just hook them over a ruler, which is the way I have heard from all other bicycle mechanics. From the inside of the elbow on the head. This is also how the spokes come measured from Sapim. Hook them over a ruler and it is dead nuts what they are labeled. It doesn't make more than a mm difference, not enough to throw a build off unless the spokes are already way off.
Spokecalc probably measures from the center of the spoke head, but I've never noticed a difference enough to catch my attention.
Volt up, gear down!
johnrobholmes
Postby voicecoils » Tue May 22, 2012 8:42 am
Spoke rulers make measuring slightly faster, but will give a similar result to the way JRH describes:
Spoke is measured from the inside of the bend, see another ruler here:
voicecoils
Postby johnrobholmes » Tue May 22, 2012 8:54 am
I see the zero starts at the bend of the spoke on those rulers too, so hooking it over a ruler seems acceptable.
Volt up, gear down!
johnrobholmes
Postby Mad » Thu May 24, 2012 1:35 pm
Hi John,
Send you a PM but didn't get answer :cry:
Hi,
I just bought a coupple of this rims for my build
http://www.ebay.com/itm/280715200570?ss ... _500wt_927
Rear wheel is for Cromotor and front for DMR Revolver hub
I'm interested in spokes and nipples, in black if possible
Do you know the rim's exactely size or you need me to tell you (I must ask for them)?
Which spoke gauge do you recmmend? Is for DH frame (8" rear travel and 170mm front travel)
Thanks
I'll really appreciate your help
Thanks
Mad
Postby ROG130 » Fri May 25, 2012 12:07 am
how much for 2 sets
40 x 12g 165mm long
and a set of
40 x 11g 165mm long
and posted to united kingdom thanks roger
ROG130
Postby johnrobholmes » Tue May 29, 2012 12:24 pm
My site calculates all the costs, please use it for me.
I have a stack of PMs here and have been slammed with work. Orders for spokes are going out as normal, but I don't have the time for helping on this forum at the moment. My apologies! Once I get caught back up on orders I will do my best to help out here again, but until then I won't be around much and I can't calculate spoke lengths for you. It just takes more time than I have right now. I suggest using the calculator on Ebike.ca 's website, it works extremely well.
Thanks for the interest, I'll try to be back around as soon as possible!
Volt up, gear down!
johnrobholmes
Postby johnrobholmes » Fri Jun 08, 2012 12:43 pm
A marathon week of lacing in my spare time. Halfway through the wheels needing lacing!
Volt up, gear down!
johnrobholmes
Postby GCinDC » Fri Jun 08, 2012 12:47 pm
moonshine, far right? woohoo! enjoy that! nice work, john.
GCinDC
1.21 GW
1.21 GW
Postby johnrobholmes » Fri Jun 08, 2012 1:12 pm
Yep! that cromotor with large marge is a svelt 26lb 12 ounces. By far my favorite combo I have laced, just a really nice wheel and I hope Moonshine enjoys it!
Volt up, gear down!
johnrobholmes
Postby moonshine » Fri Jun 08, 2012 1:47 pm
Jrh,
DUDE. I'm gonna lose it when it arrives at my door!!! I'm so beyond amped right now!!!! I just got my 18fet controller back from Lyen too! I'll have to mess around with the settings so I don't kill myself. That wheel build looks ridiculous!!! It's gonna put my 5404 with its cheap rim to shame!!!! The wheel should also fit nicely in my new swingarm(hopefully). All around EXTREMELY satisfied with the build and I don't even have it yet!!!! Thanks john! You are AWESOME.
-pat
03 Giant DH comp w/ 05 swingarm, cromotor in 26" large marge, Kelly KBL96251, 24s4p
Build Thread: viewtopic.php?f=6&t=40031
moonshine
PreviousNext
Return to Items for Sale - New
Who is online
Users browsing this forum: Ebikebert and 5 guests
