Whiplash wrote:Thanks! I will be in touch! I want to get it here soon. I also need to get a replacement side cover and a set of the new gears for my brothers bike..
Ypedal wrote:I cleaned up in here a bit... Miuan dude, show some respect.. we let just about everything slide in this place but the In the Market area we try to keep it clean.. if someone points out a scam that's fine but pissing on an asking price is not cool.. moving on..
veloman wrote:I know the newer version Mac has better gears and such, but other than that, are there other differences between the new and the older(silver) ones?
Does anyone know the limits of the older version? (Not that I'm pushing them now, but for future consideration).
I should of got the newer version from ya, Cellman.
gensem wrote:Paul, do you happen to have any news about a bigger geared motor? Sized like a clyt HS hub motor, but geared.
o00scorpion00o wrote:That sounds cool Paul!![]()
Do you think there could be a wqay for them to water cool a motor and maybe install a temp sensor?
I would imagine a motor like that to sell in very large numbers, the extra development costs might actually make something like that worth while!
Mark
cell_man wrote:o00scorpion00o wrote:That sounds cool Paul!![]()
Mark
I was planning to buy some thermocouple cable and start running some in with some bigger phase wires. Recently I've been playing with a slightly bigger hole in the axle and running 6 pcs of 2mm^2 phase wire (double up the standard wires). You can just about squeeze it in the standard axle but it's very tight, when slightly oversized it's not so bad. I would like to use either thermocouple cable or maybe a thermistor for the temperature sensing.
I've thought about water cooling but there are a couple of hurdles, firstly the only place you could bring in the pipes are the other side of the axle and then there is not much space to bring it out of the axle and into the structure, even then the pipes would have to be very small, I'm not sure they would be big enough to do much meaningful cooling. You could use a non standard disk and bring stuff through an oversized bearing on the disk side, but then you'd need to get the pipes past the clutch, or change the motor so the clutch goes on the freewheel side rather than the disk side. Then you need a way to pass pipes or some kind of heat transfer device, to draw heat out of the stator. All in all it's not easy, the disk and freewheel don't help.
cell_man wrote:Yeah water cooling would be nice, but can't see it happening just yet, it would be very involved. I will try to get some bigger Mac motors built, but just some samples initially and it is at least a few months off I'm afraid. A wider motor based on the same stator design and yoke but double width is very possible. I am often discussing it with the engineer in Mac so hopefully they'll give in some time soon and give me what i want![]()
I may also have a few things up my sleeve for the standard Mac, but don't want to say too much until it's closer to reality.
Thanks guys for the support
o00scorpion00o wrote:Again I don't think there would be any need for the clutch and free wheel and that should save some space. I doubt anyone would be concerned about free wheeling, that's where the current mac comes in!
neptronix wrote:
Liquid cooling coming out of the freewheel side would take my vote. The space required for the coolant tank and 'radiator' would be quite minimal. Just look at any high performance PC liquid cooling setup.. quite compact.
neptronix wrote:No, i'm talking about having the liquid cooling on the outside of the motor - the only place where it is effective!
veloman wrote:I think the Mac motor as it is, is great for an E-*BIKE*. Not too many people need to go 30mph up mountains.
Not saying don't develop stuff, but I am saying I'm very happy with my Mac, even on 1000 watts.
Return to Items for Sale - New
Users browsing this forum: No registered users and 8 guests
