Zenid wrote:I bought the 12-FET versiion of this controller about a week ago, and with the exception of one minor gripe I've been very happy with it so far.
On my initial test drive, though, with the controller set to 50A/125A rated/phase. I noticed something odd just now and again: I found that this was if I tried to start from a dead stop - or very slow - with the throttle wide open. There would be a 'thunk' as power to the motor would cut off. It wouldn't pull power unless I opened the throttle more gradually, then fully once I was moving.
However this seemed to go away after the first journey. Yesterday, though I raised the current to 55A/135A, and the problem came back with a vengeance - clearly there is some kind of current limitation in operation here. Lyen said the controller was capable of pulling 65A continuous in its existing form, but clearly things aren't set up right or another modification needs to be made to enable this to happen.
I'm hearing lots of talk about "shunt values", and the fact that they sometimes have to be changed to enable you to draw more current. Am I going to have to make a change here too?
If so, then this doesn't sit easy with Lyen's assurance that the I can draw 65A from this controller in its current form, as that clearly does not appear to be the case...
icecube57 wrote:I would have strongly advise you to upgrade to an 18fet right away. It seems like you need alot of current to feed you hungry motor and the 12fet isnt up to the job in its stock condition it has to be really beefed up. It seems like the performance you are after and the motor you have... you are going to need 75-100A to get the going for a dead stop without it hitting the current limit of the controller. One thing about these low turn motors is they arent very forgiving. They only think of themselves in operation. They want all the current they can take and dont care if the controller can keep pace with it or not. Everything else will die before the motor will. Ive ran a low turn count motor and its a blast when fed properly but its a pain in the ass and its a costly road to walk to find that butterzone to where you and the motor is happy.
{...} Oh yeah.... keep playing around and bumping the current limit up you will surely kill your controller. I personally dont go above 45-125 myself.
aaronski wrote:my Lyen 12 fet is set to 65/65, with no issues. when I set the phase currents that high I also see it cutting out to protect the controller if I floor it from a dead stop. I actually have it on my "to Do" list to try every phase setting at 65 amp battery settings and see where the limits are. With any luck I'll have that info on Saturday to give everyone a feel for where this controller freaks out.
also, thanks for the Block time info. if it's unlimited, won't it trip just like it does when phase amps are set too high?
Zenid wrote:You're using 65A for both rated AND phase current? Everybody else I know is using a phase current of around 2.5 times the rated current (such as 30/75A, 50/125A etc.). How do we decide what multiple to use, and with what kind of motor? Is it just trial and error, or is there some reasoning behind this multiple. Nobody I've asked seems to understand why this figure (2.5) is used and what can happen if others are used instead, except that there can be 'odd effects'...
Zenid wrote:There would be a 'thunk' as power to the motor would cut off. It wouldn't pull power unless I opened the throttle more gradually, then fully once I was moving.
bmxed wrote:Hi Zenid,
This is probably no fault of the Lyen controller. See if you have a BMS in your battery pack and what the current rating is. It might be sensing an over-current condition and is shutting down to prevent damage to the battery.
bigbore wrote:I need a standard mode running within laws in case you are catched by the cops and a "turbo" mode with a speed of 55-65 Km/h. The standard mode must be switched very quickly and not to be reversed in case you are got by the cops while running a "little fast". I want a jumper that I can pull and hide in my trouser pocket so without the jumper the bike runs at 15mph and the motor is powered only if the pedals are spinning.
How does the controller recognize the spinning pedals? Do I need a sensor?
icecube57 wrote:This isnt going to end well for you. You insist on pushing the boundary limits of the controller....
icecube57 wrote:Even with my 5303 which is a very hard motor to drive I didnt have overcurrent issues with it cutting out but it did blow mosfets even on an 18fet. You keep bumping the current and trying to get more amps out of a stock unit without beefing it up it will end in a FAIL. Controllers are expensive and in your case LYEN is not local enough for you to send it to him for repair.
skeetab5780 wrote:i can probably guarantee this is not your issue, but even if your cable is rated at 170Amps it looks like your still using 30Amp rated crimp-on style ring/fork terminals on all of your phase wires. It looks nice and clean, but they're rated for a reason.
skeetab5780 wrote:hook a Voltage meter up to your SLA bank while ur riding it, and within 1 minute you'll know if its voltage sag causing the problem or not. Process of elimination FTW.
skeetab5780 wrote:if its not the Voltage sag the next bet is hitting the Max Amp setting on the controller, from a stand-still moving all that weight can spike a ridiculous amount of Amperage.
I have the Lyen 72v 30A controller and have not had an issue like this..but i also ride a converted mountain bike and im not that heavy (180lb)
Good luck trouble-shooting your issue! keep us posted on the solution.
Zenid wrote: I was assuming that three phase wires in parallel with a 30A limit means 90A total limit.
amberwolf wrote:Zenid wrote: I was assuming that three phase wires in parallel with a 30A limit means 90A total limit.
Unfortunatley, no, they're not actually in parallel. Instead, they're in series (or rather, two at a time are, with the third unused at that moment).
So 30A is all you get thru there, if that's the limit of the phase wires and/or connectors and or windings themselves.
Zenid wrote:Well, hang on, from my limited understanding of how that PWM stuff works, doesn't it fire a very quick burst down each phase wire consecutively (or something like that) but always such that a single wire is off most of the time? You say 'two at a time' - is that right? Whatever it is, then surely you have to factor in the 'off' time as a running average...![]()
So how do you factor that into the guage of the phase wires & connectors you should have for a particular system?
amberwolf wrote:Same as if only one were in use, keeping in mind that you have twice the wire length involved at any one moment that you thought you did.
Zenid wrote:Ah I see. But doesn't the third of the time that a single wire is in its 'off' state, effectively introduce a factor of two-thirds into the amperage rating that the phase to have to support the power? For example, a 50A rated setting would only require 33.3A rated phase wires, and so on?
amberwolf wrote:Well, no, becuase if you want ot put a certain current thru a wire, it should be sized for the max current you're going to push thru it (it doesn't have to be, but it'll get hotter if it's not than if it is)
Return to Items for Sale - New
Users browsing this forum: Gregory, themadhatter106 and 5 guests
