6x4110 Mini Monster Programmable Controller LYEN Edition $79
Josh K.
Location: 517A North Link Lane, Fort Collins, Colorado 80524
Re: 6x4110 Mini Monster Programmable Controller LYEN Edition
Post by Josh K. » Aug 03, 2012 11:25 am
Hello,
We are looking to get a replacement controller for a 500 watt, 48 volt E bike kit system.
Needs to pull a Pedicab around burningmann....
Can I order one still?
Thanks, Josh K.
Custom E bike designer, Mechanic, and electric diagnostics expert.
http://www.electric-cycle.com
Climbed Mnt. Washington twice, Pikes peak twice, PIR, First Electric Cyclist to Ride the Rockies 2012, All on handbuilt pedal assist E bikes.
Lyen
Post by Lyen » Aug 03, 2012 1:03 pm
Josh K. wrote:Hello,
Thanks, Josh K.
Email replied. Thanks!
Items For Sale
Please sign up here and donate your marrow to save life.
rossasaurus
Post by rossasaurus » Aug 15, 2012 9:59 pm
Hi Edward, any Mini's left?
thanks
R
EV Retailer; e-Recumbents, e-Cargo Bikes, Mountain-Trikes, e-Scooters, e-Motos, LSV's, Ag e-Vehicles, Components, e-Social Club, e-Asylum;
http://emotors.biz
http://veloverde.net
h0tr0d
Post by h0tr0d » Oct 21, 2012 9:18 pm
Hey Lyen and everyone!
What about this controller (and call it Mini ULTRA Monster) with:
IRFP 4368
75V
ID 195A (package limited)
ID silicon limited 350A
RDS ON typ 1.46mR, max 1.85mR
datasheet http://www.irf.com/product-info/datashe ... 368pbf.pdf
or
IRFP 4468
100V
ID silicon limited 290A
RDS ON typ 2mR, max 2.6mR
datasheet http://www.irf.com/product-info/datashe ... 468pbf.pdf
Thank you Justin! Life is so much sweeter with this forum... ;)
rafeh1
1 W
1 W
Post by rafeh1 » Mar 20, 2013 5:01 pm
Hi Ed
I have a 48V 10 ah battery with oetoma motor.
I want to buy one of your controllers and add some circuitry and programming modes. Is it possible to get schematic of it prior to buying it.
If it is proprietary I apologize I don’t want to ask for anything proprietary
My goal is to add blue tooth and show motor battery status on a cell phone if that helps any
I am embedded system engineer so i know my way around this stuff.
Rafe
Lyen
Post by Lyen » Mar 20, 2013 8:17 pm
rafeh1 wrote:Hi Ed
Rafe
Hi Rafe,
Thanks for your inquiry. I will replied directly to your email address.
Regards,
Edward Lyen
Items For Sale
quamau
Post by quamau » Sep 14, 2013 8:27 am
Hi Ed,
apologies in advance for the dumb question. How do I switch this controller on? Is it with the small red wire to be connected to the + of the battery (through a switch)?
Can you give me some estimates of the power consumption of the controller when idle/off?
Thanks,
Maurizio
olivier_fr
Post by olivier_fr » Feb 25, 2014 12:39 pm
I recently buy a 4110 mini monster programmable controller SENSORED for 72V.
I cumulate the bugs with it:
- no power, no torque under 60V.=> increase the parameter of phase current to 80A (between 2 and 3 times the rated current)
- with the new phase current value, it seems to be working fine, but after 500 meter, the controller is out of order. i checked the DC level on the throttle, 3 speed switch, everythings seem to be OK, but the wheel is not supplied at all.
Does somebody have an idea of the issue?
I think to change the MOSFET, but before doing it i want to be sure.
I'm also looking for the schematic of the EB312 version of the controller. so that i could repair it by myself.
thank you for your answer.
programmer001
Post by programmer001 » Mar 02, 2014 6:00 am
Hi, how about shipping this controller to Russia?
Or the price $79 includes the shipping cost?
Where can I get a device with switches to restrict currency
from controller to the motor (I don't know it's exact name,
if such thing exists in e-bike world)
Thanks
Lyen
Post by Lyen » Mar 02, 2014 9:55 pm
Hi Programmer001,
Thanks for your inquiry. Can you tell me the brand and the model of the motor you have? Also, what is your battery voltage? I will configure the controller for your battery prior I ship it out.
The shipping cost for the controller to Russia is only $19.95 via USPS First Class Mail Service. I will pay the extra if it costs more to ship. I will also declare the package as gift and declare the lowest custom value. This way, you should not have to pay the extra custom or VAT fees.
As for the device you are referring to, the closest would the the three speed switch ($15). The lower the speed, the lower the current would be.
Here is the preliminary itemized total:
6 FET 4110 Mini Monster Programmable Controller LYEN Edition $79
Shipping to First Class Russia via USPS Mail Service $19.95
total: 98.95
Optional controller add-on:
Cycle Analyst connector, external USB-TTL connector for USB-TTL programming adapter, regenerative braking enable/disable jumper $10
USB-TTL programming adapter $15
Cruise control module $19
PAS (Pedal Assist System) module $15
Three speed switch $15
I currently have the following electric bike parts:
Half Twist Throttle $15
Full Twist Throttle $15
Thumb Throttle $15
LEFT Side (custom made) Half Twist Throttle $25
Electric Brake Levers (sold in pair in black color only) $15
Electric Brake Magnetic Sensing Switches (sold in pair) $25
DC-DC Multi-Purpose Voltage Converter $14.98
Electric Bike Controller/Motor/Throttle Tester $29
Hall sensor (Honeywell SS41) $3
Planetary harden steel gear sprocket for BMC/Puma/MAC motor $25
Planetary harden composite gear sprocket for BMC/Puma/MAC motor $16
Multi-function switch $20
Torque arm (angle adjustable) $23
Special items:
Large Screen Direct Plug-in Cycle Analyst with Speedometer Cable, Version 2.30 (compatible with all motors) $125
Large Screen Direct Plug-in Cycle Analyst (for direct drive hub motor only, not gear motor or sensorless compatible), Version 2.30 $120
________________________________________________________________
Here are the quick descriptions for the items mentioned above:
The Cycle Analyst connector is for interfacing with the Cycle Analyst ebike unit. For information on the Cycle Analyst, click below:
http://www.ebikes.ca/drainbrain.shtml
The external USB-TTL connector is a plug that is needed to interface with the optional USB-TTL programming adapter.
The regenerative braking enable/disable jumper (for direct drive hub motor only) allows you to enable or disable the regenerative braking without the need to open the controller case.
The USB-TTL programming adapter is to be use to make controller parameter & setting changes via your PC.
The cruise control module is a handlebar mounted switch that allows you to hold the speed without keeping your hand on the throttle.
http://imageshack.us/photo/my-images/70 ... ntrol.jpg/
The PAS (Pedal Assist System) module is a crank mount sensor that spins the motor when it senses the pedaling movement.
The three way speed switch a is handlebar mount unit that allows you to limit the maximum speed with three difference settings. For example, speed mode 1 = long range, speed mode 2 = legal limit, speed mode 3 = maximum or turbo.
http://imageshack.us/photo/my-images/70 ... witch.jpg/
The torque arm is meant for electric bicycle with aluminum frame to prevent the drop out area on the frame from excessive torque damage by the hub motor.
The Half Twist Throttle is to control the speed of the motor.
http://www.lyen.com/Products/Product_Ph ... e_W%20.JPG
The Full Twist Throttle is to control the speed of the motor.
http://www.lyen.com/Products/Product_Ph ... rottle.JPG
The Thumb Throttle is to control the speed of the motor.
The electric brake lever(s) consists of momentary on/off switch. When the brake lever is applied, it signals to the controller to stop the motor from turning.
http://lyen.com/Products/Product_Photos ... Levers.JPG
Electric Brake Magnetic Sensing Switches are to be mounted underneath the brake levers, which allow you to use your existing brake levers especially useful if you have hydraulic disc brakes.
http://www.lyen.com/Pictures/Brake_Magn ... ting_Info/
The DC-DC Multi-Purpose Voltage Converter is a versatile device to down convert voltages for recharge your PDA phone, running flashlight from your ebike battery. For more, click below:
https://endless-sphere.com/forums/viewto ... 31&t=21459
The Electric Bike Controller/Motor/Throttle Tester is for troubleshoot ebike electrical issues. For more, click below:
https://endless-sphere.com/forums/viewto ... 31&t=20413
The Hall sensor (Honeywell SS41) is for ebike motor faulty hall sensors replacement or RC motor to ebike implementation. For more, click below:
https://endless-sphere.com/forums/viewto ... 31&t=20410
The Planetary harden steel gear sprocket for BMC/Puma/MAC motor is the enhanced gear sprocket for higher torque and speed. For more, click below:
https://endless-sphere.com/forums/viewto ... 31&t=18732
The multi-function switch which consists of a SPDT switch for left/right turn signal, a momentary switch for horn, and an on/off switch for light. You may use the light switch for controller on/off, the horn switch for regen, and the left/right switch for other functions such as speed limit settings. But a little electronic knowledge is required on the wiring. Click here to see the picture of the unit.
http://www.lyen.com/Products/Product_Ph ... Switch.jpg
The Torque arm (angle adjustable) is for strengthen the dropout to avoid damages to the bike frame due to the torque produced from the hub motor.
Please let me know your email address, and if you have any other questions and would like to purchase the add-on or accessories mentioned above, I will calculate the total and email you a PayPal invoice to purchase. Thank you!
Best Regards,
Edward Lyen
programmer001 wrote:Hi, how about shipping this controller to Russia?
Thanks
Items For Sale
Kagamoosha
1 W
1 W
Post by Kagamoosha » May 28, 2015 10:57 am
What is the high voltage cutoff for this controller? I Have two 13s batteries I wanted to put in series, but I don't want to fry my controller. I will reprogram the controller also.
Like E Bike-E
Post by Like E Bike-E » Nov 21, 2015 11:47 am
Hi Ed,
Are you still selling controllers? As my username suggests, I have a Bike-E semi-recumbent and I'm converting it into an E Bike-E. I bought a 48 V battery and motor, and I'm looking for a 20 A controller. I'm not putting on any extras, not even a brake connection. So I'm just looking for a simple inexpensive controller at 48V 20A, and I live in Toronto, Canada. I hope to hear from you!
Cheers,
Joe
amberwolf
Post by amberwolf » Nov 21, 2015 2:53 pm
Have you looked at the other Bike-E builds here to see what they use and where they got them? ;)
Lyen
Post by Lyen » Nov 21, 2015 5:08 pm
Hi Joe,
Thanks for your inquiry. Yes, I still selling controllers. Can you tell me the brand and model of the motor you plan to use? The better controller for your application is the 6 FET 3077 Mini Monster Programmable LYEN Edition Controller ($79). The 3077 (it is referred to the IRFB3077 MOSFET high power transistor) is a better choice for you if you do not need to go over 75V. The IRFB3077 has lower internal resistance for higher power and/or lower temperature at the same power level of the 4110. I will configure the controller for your 48V battery voltage prior I ship it out.
Here's the preliminary recommend itemized total:
6 FET 3077 Mini Monster Programmable LYEN Edition Controller $79
Shipping Toronto, Canada via USPS Air Mail Service $12.95
total: 91.95
Thumb Throttle $15
LEFT Side (custom made) Thumb Throttle $25
DC-DC Multi-Purpose Voltage Converter (up to 60V only) $14.98
Planetary hardened steel gear sprocket for BMC/Puma/MAC motor $25
Planetary hardened composite gear sprocket for BMC/Puma/MAC motor $16
Special items:
Large Screen Direct Plug-in Cycle Analyst with Speedometer Cable, Version 3 (compatible with all motors) $155
Large Screen Direct Plug-in Cycle Analyst (for direct drive hub motor only, not gear motor or sensorless compatible), Version 3 $150
MAC 1000W medium speed gear hub motor (sensored rear, black color, plain motor only) $299
Crystalyte HT3525 direct drive hub motor (high torque/low speed, sensored rear, black color, plain motor only) $349
Crystalyte HS3540 direct drive hub motor (medium torque/medium speed, sensored rear, black color, plain motor only) $349
Here is a brief descriptions for the items mentioned above:
http://lyen.com/Products/Product_Photos ... Module.JPG
The three way speed switch a is handlebar mounted unit that allows you to limit the maximum speed with three difference settings. For example, speed mode 1 = long range, speed mode 2 = legal limit, speed mode 3 = maximum or turbo.
http://lyen.com/Products/Product_Photos ... Switch.JPG
http://lyen.com/Products/Product_Photos ... e_Pic1.JPG
http://lyen.com/Products/Product_Photos ... e_Pic2.JPG
The Planetary hardened steel gear sprocket for BMC/Puma/MAC motor is the enhanced gear sprocket for higher torque and speed. For more, click below:
Best regards,
Edward Lyen
Like E Bike-E wrote:Hi Ed,
Cheers,
Joe
Items For Sale
Like E Bike-E
Post by Like E Bike-E » Dec 06, 2015 12:47 pm
Hi Ed,
Sorry I took a while to respond. I have an Outrider high rpm version geared 48V hub motor with 3-pin hall less setup (sensorless) and I'm at joe.witkin for my gmail. Thanks for the nice response. Let me know what you recommend for a barebones setup.
Cheers,
Joe
Like E Bike-E
Post by Like E Bike-E » Jun 17, 2016 7:06 pm
Hi Ed,
I got a 6 FET 3077 HSL Mini Monster Sensorless LYEN Edition Controller ($89) last year. It was programed for 20A, but I think you said max voltage is 60V. Is that rated voltage or absolute max. I'm building a lithium ion 18650 battery that theoretically has an absolute max voltage of 67V. However, I'm getting a charger that will have a lower voltage than that because I want the battery to last. What is the absolute max voltage my controller can take? Technically my battery will be a rated 59V battery.
Thanks!
Joe
