24 x 4115 MOSFET 84-132V Freeway Speed Controller $349
wojtek   10 kW
Re: 24 x 4115 MOSFET 84-132V Freeway Speed Controller $349
Post by wojtek » Apr 19 2012 3:41pm
just wanted to say BIG THANK YOU to Lyen for taking his time to go thought the controller wiring and explaining me how it all works [i have no background in this stuff whatsoever so it took a while !!!]
appreciate your time and efford and will be soon posting a video of my KMX Cobra with 5405 26'' rear wheel and 100v battery pack and this very controller !!!
WIRES AND CONNECTORS
http://www.endless-sphere.com/forums/vi ... 31&t=30176
http://endless-sphere.com/forums/viewto ... 31&t=32244
KMX Cobra with Xlyte 5403
Go-One Evo with Cromotor
BATMOBILE - in progress
Giant CRS Alliance - SOLD
3Element Espire - SOLD
Custom built Specialized BigHit with BBS02 - SOLD
Velokraft e-VK3 SOLD
Steintrike Mungo Sport HS3540-SOLD
Scorpion FS HS3540-SOLD
Kona Dawg BMC v2-SOLD
jmirabil   10 µW
10 µW
Post by jmirabil » Oct 03 2015 4:17pm
Hi there...
I just purchased a bike with the Lyen "24 fet 4115 mosfet" controller, looks lke this one from the description. I see a USB connector, but I dont know what software to use--can I get a link to download this monitoring and configuring software--looks very interesting! I'm curious what I can see and adjust and save with this interface. Where's the software and a link on how tomuse it - OS compatibility, etc... THX!!! -Jonathan
NeilP   10 GW
Post by NeilP » Oct 03 2015 4:33pm
Ummm
Well don't remembef a USB connector on mine.
There is a black multipin connector, that mates to the USB prorgamming lead.
If it is like I describe, then you need to search the forum for XPD software.
:) Only Irish coffee provides in a glass all four essential food groups: alcohol, caffeine, sugar, and fat :)
altermontrealiste   1 W
1 W
Post by altermontrealiste » Jan 28 2016 9:21pm
Hi lyen (and others that could help) ;
I have a infineon eb324 board and would like to know the pads signals (ie where to plus throttle, brake, speedometer, anti-theft) to upgrade a chinese electric scooter
thanks
NeilP   10 GW
Post by NeilP » Jan 29 2016 4:26am
I do not have pictures of a 24 FET, but all the pad labels are the same across most of these boards. I can't easily find and attach the picture to this post, from my phone, SO... Send me a PM...with your e-mail and I will e-mail you pictures of the back of an 18 FET with some of the pads labelled up........but....
Umm, your question raises lots more questions thatI'd like answers to, like:
You have a board with no wires... where from ?, why no wires? Why can't the supplier of the board help you?
You have just a board ? What ? no case or heatsink.. so do you have just the board or a complete controller...if a complete controller...why is it not already wired up ... If not, why not, who supplied an unwired board
Please post photo in large resolution, of the back and front of the board , and if I get time I'll try and label it
PM Sent to you
felcinger   100 µW
100 µW
Post by felcinger » Aug 22 2016 2:11am
Whether this controller is capable to work with the sensorless motor?
Shred120v   1 µW
Post by Shred120v » May 12 2019 10:22pm
In running 120v on a crystalyte the crown 80
I wanna max it out. I'm running a 5000 watt Lyen 50 amp. What are some options?
Thanks.
I'm looking for speed controll update to be specific. With cycle analyst plug too.
Lyen   10 kW
Post by Lyen » May 13 2019 3:49pm
Hi Shred,
Thanks for your inquiry. For 5000 watts at 120V, the recommend controller is the 24 FET 4115 MOSFET 84-132V Freeway Speed LYEN Edition Controller ($349).
Here is the preliminary recommend itemized total:
24 FET 4115 MOSFET 84-132V Freeway Speed LYEN Edition Controller $349
Cycle Analyst connector $4
Shipping via USPS Priority Mail Service (2-3 days) $18
total: 371
Optional controller add-on:
Cycle Analyst connector, external USB-TTL connector for USB-TTL programming adapter, regenerative braking enable/disable jumper $10
USB-TTL programming adapter $15
Cruise control module $19
PAS (Pedal Assist System) module $15
Three speed switch $15
I currently have the following electric bike parts:
Half Twist Throttle $15
Full Twist Throttle $15
Thumb Throttle $15
LEFT Side (custom made) Half Twist Throttle $25
LEFT Side (custom made) Thumb Throttle $25
Electric Brake Levers (sold in pair in black color only) $15
Electric Brake Magnetic Sensing Switches (sold in pair) $25
DC-DC Multi-Purpose Voltage Converter (up to 60V only) $16
Electric Bike Controller/Motor/Throttle Tester $29
On/Off Switch (with installation) $10
On/Off Key Switch (2 keys included & with installation) $15
Emergency kill switch (handlebar mount type) $15
Hall sensor (Honeywell SS41) $3
Planetary hardened steel gear sprocket for BMC/Puma/MAC motor $25
Planetary hardened composite gear sprocket for BMC/Puma/MAC motor $16
Multi-function switch $20
Torque arm (angle adjustable) $23
Special items:
Large Screen Direct Plug-in Cycle Analyst with Speedometer Cable, Version 2.30 (compatible with all motors) $100
Large Screen Direct Plug-in Cycle Analyst (for direct drive hub motor only, not gear motor or sensorless compatible), Version 2.30 $95
Large Screen Direct Plug-in Cycle Analyst with Speedometer Cable, Version 3 (compatible with all motors) $130
Large Screen Direct Plug-in Cycle Analyst (for direct drive hub motor only, not gear motor or sensorless compatible), Version 3 $125
MAC 1000W medium speed gear hub motor (sensored rear, black color, plain motor only) $299
Crystalyte HT3525 direct drive hub motor (high torque/low speed, sensored rear, black color, plain motor only) $349
Crystalyte HS3540 direct drive hub motor (medium torque/medium speed, sensored rear, black color, plain motor only) $349
________________________________________________________________
Here is a brief descriptions for the items mentioned above:
The Cycle Analyst connector is for interfacing with the Cycle Analyst e-bike unit. For information on the Cycle Analyst, click below:
http://www.ebikes.ca/drainbrain.shtml
The external USB-TTL connector is a plug that is needed to interface with the optional USB-TTL programming adapter.
The regenerative braking enable-disable jumper (for direct drive hub motor only) allows you to enable or disable the regenerative braking without the need to open the controller case.
The USB-TTL programming adapter is to be used to make controller parameter & setting changes via your PC.
The cruise control module is a handlebar mounted switch that allows you to hold the speed without keeping your hand on the throttle.
http://lyen.com/Products/Product_Photos ... Module.JPG
The PAS (Pedal Assist System) module is a crank mount sensor that spins the motor when it senses the pedaling movement.
The three-way speed switch is a handlebar mounted unit that allows you to limit the maximum speed with three different settings. For example, speed mode 1 = long range, speed mode 2 = legal limit, speed mode 3 = maximum or turbo.
http://lyen.com/Products/Product_Photos ... Switch.JPG
The Half Twist Throttle is to control the speed of the motor.
http://www.lyen.com/Products/Product_Ph ... e_W%20.JPG
The Full Twist Throttle is to control the speed of the motor.
http://www.lyen.com/Products/Product_Ph ... rottle.JPG
The Thumb Throttle is to control the speed of the motor.
The electric brake lever(s) consists of momentary on/off switch. When the brake lever is applied, it signals to the controller to stop the motor from turning.
http://lyen.com/Products/Product_Photos ... Levers.JPG
Electric Brake Magnetic Sensing Switches are to be mounted underneath the brake levers, which allow you to use your existing brake levers especially useful if you have hydraulic disc brakes.
http://lyen.com/Products/Product_Photos ... e_Pic1.JPG
http://lyen.com/Products/Product_Photos ... e_Pic2.JPG
The DC-DC Multi-Purpose Voltage Converter is a versatile device to downconvert voltages for recharge your PDA phone, running flashlight from your e-bike battery. For more, click below:
https://endless-sphere.com/forums/viewt ... 31&t=96611
The Electric Bike Controller/Motor/Throttle Tester is for troubleshooting e-bike electrical issues. For more, click below:
http://endless-sphere.com/forums/viewto ... 31&t=20413
The Hall sensor (Honeywell SS41) is for e-bike motor faulty hall sensors replacement or RC motor to e-bike implementation. For more, click below:
http://endless-sphere.com/forums/viewto ... 31&t=20410
The Planetary hardened steel gear sprocket for BMC/Puma/MAC motor is the enhanced gear sprocket for higher torque and speed. For more, click below:
http://endless-sphere.com/forums/viewto ... 31&t=18732
The multi-function switch which consists of an SPDT switch for left/right turn signal, a momentary switch for horn and an on/off switch for the light. You may use the light switch for the controller on/off, the horn switch for regen, and the left/right switch for other functions such as speed limit settings. But a little electronic knowledge is required on the wiring. Click here to see the picture of the unit.
http://www.lyen.com/Products/Product_Ph ... Switch.jpg
The Torque arm (angle adjustable) is for strengthening the dropout to avoid damages to the bike frame due to the torque produced by the hub motor.
Please let me know your email address, and if you have any other questions and would like to purchase the add-on or accessories mentioned above, I will calculate the total and email you a PayPal invoice to purchase. Thank you!
*** Be aware I am currently out of town and will not be able to process your order until I returned at the end of May. ***
Best regards,
Edward Lyen
Shred120v wrote:
May 12 2019 10:22pm
Thanks.
Items For Sale
Please sign up here and donate your marrow to save life.
coolbobjoe   1 W
1 W
Post by coolbobjoe » May 29 2019 9:53am
Looking for a 24 x 4110 controller. Able to supply?
